Truxedo Pro x15 Cover?
Discussion in 'Tonneau Covers, Caps and Shells' started by knoxville36, Dec 18, 2018.
  1. Dec 18, 2018 at 9:26 AM
    knoxville36
    knoxville36 [OP] New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Hey guys, did a search and seems like these covers get good reviews on here. It is going on my 19 Platinum with Deck rails. Also has Line-X Premium installed in bed.
    I am looking at the roll ups just because I do not want to spend $1500+ on a good retractable cover right now. Not a huge fan of the tri folds for some reason and these roll ups look like a really good and cheaper alternative for about $500.
    What is everyone's thoughts on this cover?
    https://truxedo.com/pro-x15/2019/toyota/tundra
    Ronin likes this.
  2. Dec 18, 2018 at 9:59 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    I considered a reinforced roll-up like this for my 2019 CM 1794. My worry was the possibility of getting punctures in the fabric which would cause leaks. For this reason, I got the BakFlip MX4. But it's a tri-fold. It came with adapter plates to lower the deck rail system a bit. It suits my needs perfectly.
    This is just my opinion. Good luck with whichever tonneau you decide to get!
    equin likes this.
  3. Dec 19, 2018 at 6:35 PM
    tgo
    tgo New Member
    Central VA
    2018 Limited CM Silver Sky
    Lurking....
  4. Dec 20, 2018 at 4:09 PM
    knoxville36
    Knoxville, TN
    Hey guys, I ended up ordering this cover tonight. I am getting my line x installed next Thursday. Give it a couple days to cure up nicely then install this cover. It is suppose to be a thicker and more durable material like a convertible top. Here in a week or so I will post some pictures and how it went.
  5. Dec 22, 2018 at 11:54 AM
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    I put mine on a couple of days ago! It's a wait and see kinda thing,went on real easy,looks great,see what happens after first rain event.
  6. Jan 7, 2019 at 9:05 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    How does it look? What are your impressions?
  7. Jan 7, 2019 at 11:31 AM
    r1-superstar
    DB
    UTAH
    I'm also looking into this as well. Don't want that big box the roll ups roll into. Won't be able to haul dirt bikes. So onto the next dilemma...My wife was going to get the Pro X15 for me for my birthday next week. It looks like the deck rail cleats are rendered useless with this system. What good is a truck bed cover if I can't haul my dirt bikes in it?
  8. Jan 7, 2019 at 5:59 PM
    knoxville36
    Knoxville, TN
    Have not put it on yet. Really busy with work, holidays, family, etc.... still sitting in the box but Nighthawk posted pictures and looks great!!!
  9. Jan 7, 2019 at 6:54 PM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I’m seriously considering one too. Father in law has a Lo Pro QT that he is strongly recommending. The X15 is tempting tho...
  10. Jan 16, 2019 at 1:37 PM
    r1-superstar
    DB
    UTAH
    Installed my Truxedo Pro X15 yesterday.
  11. Jan 16, 2019 at 4:41 PM
    flying dave
    flying dave New Member
    NC
    Any pics of it rolled up?? Looks like a nice cover.
  12. Jan 16, 2019 at 5:13 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I have the Sentry Pro which is the hard-roll-up version of the X15. When I put my bike in I take it off, it just has 2 clips in the front, the rails stay on.
  13. Jan 16, 2019 at 7:07 PM
    r1-superstar
    DB
    UTAH
    She was looking to get me that one. I asked kindly not to. The difference in cost between your cover and mine is going towards my Ray 10s. ;)
    Yzed608[QUOTED] likes this.
  14. Jan 16, 2019 at 7:20 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Good trade-off :thumbsup:.
    r1-superstar likes this.
  15. Jan 17, 2019 at 7:05 AM
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    @r1-superstar Did you install washers to get the rails level? I've been meaning to do it with mine because I think it will help with the cover latching.
  16. Jan 17, 2019 at 9:17 AM
    r1-superstar
    DB
    UTAH
    Not yet. I did try one clamp to see if it helped. I'm unsure if the washers need to be installed with the clamps. Here is a picture I got from the internet showing someone using a round spacer. It looks like it will put more even pressure on the top part of the clamp and leveling the rail.
    Here is my truck showing no spacer and the latch.
    With one spacer
    And one spacer with adding two more washers. The second picture (just one spacer) looks to be the best as the clamp teeth is flush and the latch is raised a bit.
    I'm thinking one spacer works best to keep the clamp plumb. But as you can see in my pictures, the rail is still not level. Perhaps a shim is needed between the Truxedo rail edge and the bed?
    2018TundraLimited likes this.
  17. Jan 17, 2019 at 10:27 AM
    JDHolliday27
    2018 CM
    Thanks that's helpful. What are you using for a spacer in the pics above? I think I'll end up using a round spacer like the one in the 1st pic.
  18. Jan 17, 2019 at 10:37 AM
    r1-superstar
    DB
    UTAH
    It was a part from my kids go-kart seat belt. lol I will go to Lowes and find a rectangle block of some sort. That way there is even pressure and clamping surface.
  19. Jan 27, 2019 at 1:18 PM
    NCSkeeter
    Having some trouble getting mine level too...I’m going to find some scrap aluminum and make some shims for the clamps.
  20. Jan 28, 2019 at 7:43 AM
    r1-superstar
    DB
    UTAH
    I used these. I could not find scrap aluminum and the lengths they sell at Lowes was too spendy.
