TruckyTruck's Build
Discussion in '2nd Gen Builds (2007-2013)' started by TruckyTruck, Jan 7, 2014.
  1. May 10, 2015 at 5:46 PM
    #151
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    The whistle drives me crazy!!
  2. May 10, 2015 at 6:13 PM
    #152
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    If you haven't noticed a drop in low end tq, just leave it! For me it was a big difference... I also have dual exhaust so that could play a big factor in how much difference the drop in filter changed things.
  3. May 10, 2015 at 6:15 PM
    #153
    TruckyTruck
    Gary
    That whistle drove me absolutely crazy. You don't hear it as bad with the paper filter. You could buy a new gasket without the whiffle or just cut the whiffle out of the gasket you have. Either way will get rid of that sound
  4. May 10, 2015 at 6:30 PM
    #154
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I cut mine out. Fixed the whistle. Easy to do.
  5. May 10, 2015 at 6:49 PM
    #155
    Virgils12
    Where is it at and what do I need to do to cut it out?
  6. May 10, 2015 at 7:02 PM
    #156
    TruckyTruck
    Gary
    Some type of metal snips. Take a look at the picture on my original post and make the whiffle one look like the one without. This gasket is behind the throttle body. When you tighten the throttle body back up the bolts should be 7 ft-lbs tq.
  7. May 24, 2015 at 3:31 PM
    #157
    TruckyTruck
    Gary
    Updated original post with seat covers.
  8. May 24, 2015 at 7:33 PM
    #158
    csuviper
    Broomfield, CO
    What is the material of those covers? Similar wet suit style as wet okle?
  9. May 24, 2015 at 7:52 PM
    #159
    TruckyTruck
    Gary
    Yes, neoprene. I have some wetsuits and was worried id hat the covers. Some of my suits are rubbery feeling and would make terrible seat covers. These are really soft and I'm pretty happy with them. These days I get pretty nasty at work and needed something to make sure my seats didn't get ruined.
  10. May 24, 2015 at 7:53 PM
    #160
    TruckyTruck
    Gary
    They have covers made out of cloth material that I almost bought. I would have if I still worked in an office.
  11. Jun 1, 2015 at 7:59 PM
    #161
    TruckyTruck
    Gary
    I've got the 10th and 11th free so I'll finally be installing my lift. Coilovers, uca's, shackles and poly bushings. Giving myself 2 full days to get it done and hopefully get the alignment done the next day. Anyone have an online guide or tips for the install? I've researched it and have been looking at my truck to map out what I'm doing, but I wouldn't turn away any tips. I'm pretty excited about finally getting the lift on.
    rons23 and tat2ude39 like this.
  12. Jun 1, 2015 at 8:34 PM
    #162
    Take ur time.
    Be prepared to do some trimming if needed
    Use a BFH when all else fails.
    TruckyTruck[OP] likes this.
  13. Jun 1, 2015 at 9:47 PM
    #163
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    I'm going to throw this question at you because your about to install some shackles on you truck. So I was looking at the Coachbuilder shackles, just researching... and those are some beefy parts compared to stock. Very Nice indeed! So to my understanding, they will add some lift depending on size... what if a person would like those shackles, but doesn't want lift? OR you just want to add a leaf? In what scenarios, do you or don't you add shackles? Then what about the front? PROS or CONS with shackles? :) Thanks!
  14. Jun 2, 2015 at 2:56 PM
    #164
    TruckyTruck
    Gary
    I think he makes some that don't give you lift. The ones I got give 1.5 - 1.75 inches in the rear. I choose these over an extra leaf spring to retain the flexibility of the factory leafs. The shackles give more control in the ride and stop any bed bounce. I've just got stock factory coilovers in the front and I'm replacing them with adjustable coilovers with stiffer springs. The only thing I would do if I had a pro would maybe get shackles that don't lift it any. I would probably just leave it stock. Thats a pretty nice set up from the factory.
  15. Jun 2, 2015 at 4:45 PM
    #165
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    Thanks Gary... I totally agree about the PRO suspension, as I don't plan to change anything there until it fails. I do want to see though about a replacement shackle that doesn't include a lift, just an oem replacement.
  16. Jun 10, 2015 at 8:17 PM
    #166
    TruckyTruck
    Gary
    Well, today I installed my lift. I'm completely beat! It was dark when I got the last wheel back on, so I didn't really get to sit back and look at it lifted or make more than one "after" measurement. It looked a little high so I heard my phone on for some light and took a measurement of the passenger front. 4 3/4 inches lifted on that side! Yikes... So I'll have to make some adjustments tomorrow after I find out how many turns of the coilover is an inch. Here is a list of parts that got put on:
    -Fat bobs coilovers
    -One coachbuilder shim on each coilover. Each gives half inch so I don't have to preload my coilover as much. My goal is 3.5 inches of front lift
    -light racing uca's
    -coachbuilder carrier bearing drop
    -Coachbuilder +3 shackles, got about 1 3/4 lift in the rear
    -coachbuilder polyurethane bushings for the rear of the leaf spring
    I still need to install the diff drop tomorrow, tighten back up the front sway bar and skid plate. After that I'm taking it to get aligned at 4wheel parts, unless anyone has a better suggestion.
  17. Jun 10, 2015 at 8:22 PM
    #167
    TruckyTruck
    Gary
    By the way guys, coachbuilder1 is a vendor here now. Not only is everything I bought from him top notch, but today when I needed a little help on my install, I called and he helped me over the phone.
    tat2ude39 likes this.
  18. Jun 10, 2015 at 8:23 PM
    #168
    ODSteve
    ODSteve New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    That's awesome
  19. Jun 10, 2015 at 8:23 PM
    #169
    Sounds like a nice setup. Can't wait to see some pics when you git er done
  20. Jun 10, 2015 at 9:02 PM
    #170
    :worthless:
  21. Jun 10, 2015 at 11:22 PM
    #171
    TruckyTruck
    Gary
    T-Rex266[QUOTED] and Black Wolf like this.
  22. Jun 11, 2015 at 6:13 AM
    #172
    Nothing better than "game used" truck pics.
    zcarpenter92 likes this.
  23. Jun 11, 2015 at 12:56 PM
    #173
    TruckyTruck
    Gary
  24. Jun 11, 2015 at 2:06 PM
    #174
  25. Jun 11, 2015 at 4:02 PM
    #175
    Ditto. Looking good. real good. Cost estimate please?
  26. Jun 11, 2015 at 4:19 PM
    #176
    TruckyTruck
    Gary
    Thanks! Right at 1100 dollars
  27. Jun 11, 2015 at 4:36 PM
    #177
    That seems to be pretty reasonable for what you did. Good job on that. How did the final lift measurements turn out?
  28. Jun 11, 2015 at 4:54 PM
    #178
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    LOVE that LIFT, Beautiful MOD!
  29. Jun 11, 2015 at 6:34 PM
    #179
    TruckyTruck
    Gary
    I got 1 3/4 in the rear and 3 1/2 in the front. had to adjust the coilovers a couple times to get what I was looking for.
  30. Jun 11, 2015 at 10:29 PM
    #180
    csuviper
    Broomfield, CO
    Looking good underneath. How do you like the feel of the ride?
    Lets see some side pics of the truck.
