TruckyTruck's Build
Discussion in '2nd Gen Builds (2007-2013)' started by TruckyTruck, Jan 7, 2014.
  1. Oct 18, 2015 at 8:42 PM
    #301
    I think it's mentioned in here, somewhere but with the BD tuner, what mode do you have it on?
    Edit: still running it in trail mode?
  2. Oct 18, 2015 at 9:01 PM
    #302
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    Yes, trail tune, performance shifting and performance throttle. I'm still so impressed by it too.
  3. Oct 18, 2015 at 9:03 PM
    #303
    TxTundraGuy89
    TxTundraGuy89 New Member
    Korwin
    Yeah I have to even admit myself sometimes it's just a thrill hit and open road and punch the throttle and just hear the beast roar!! What's your mpgs like with the trail tune?
  4. Oct 19, 2015 at 7:31 PM
    #304
    TruckyTruck
    Gary
    I have been avg 13.5 but with a very heavy foot. Tonight I had to make a 90 mile drive and decided to see what my mpg would be if I didn't run it hard. I avg 65-70 mph and came thru several towns that had stop signs and lights. I drove reasonable with acceleration, but on the lighter side. My ending avg mpg was 15.9
    Not bad for 35s that weigh 80 pounds a piece.
    TxTundraGuy89 and T-Rex266 like this.
  5. Oct 19, 2015 at 7:34 PM
    #305
    TxTundraGuy89
    Korwin
    Dang that's pretty dang impressive if you ask me!!
    I know it's been mentioned but what all upgrades you have done to yours man?
  6. Oct 19, 2015 at 8:00 PM
    #306
    TruckyTruck
    Gary
    The only real performance upgrade I've made is true dual exhaust. And basically, the exhaust by itself does virtually nothing for performance except for a little better overall 0-60 time. I bought the duals thinking one day I would do headers. That was about 2 years ago.
    But I'm wondering if the duals went well with the tuner. It's such a big difference in overall torque and mpg gain.
    I bought the tuner specifically for headers that I plan on installing. This particular tune was developed for having headers and safe afr numbers.
    TxTundraGuy89[QUOTED] likes this.
  7. Oct 19, 2015 at 8:06 PM
    #307
    With the tuner in trail mode, are you able to :burnrubber: easier with those tires?
  8. Oct 19, 2015 at 8:14 PM
    #308
    TxTundraGuy89
    Korwin
    Yeah I've been thinking of doing a true dual set up myself. I think it did work well with the tuner reason I say that is because I live in Houston been in Corpus for work. And all the times I've driven it thus far best I've seen is 17mpg, and my truck is all stock, with a bad cat and tow mirrors. And tow tune.
    TruckyTruck[OP] likes this.
  9. Oct 19, 2015 at 8:54 PM
    #309
    TruckyTruck
    Gary
    Yes!
  10. Oct 21, 2015 at 2:32 PM
    #310
    BD GT tuner installed today :cool:
  11. Oct 21, 2015 at 4:05 PM
    #311
    TruckyTruck
    Gary
    Nice! What settings?
    I also reset my transmission learning pattern, did the zpc, and one click lock and unlock for the doors.
    TxTundraGuy89 likes this.
  12. Oct 21, 2015 at 4:07 PM
    #312
    TxTundraGuy89
    Korwin
    That's what i love about the BD. So many things to mess with haha
  13. Oct 21, 2015 at 4:21 PM
    #313
    Kept it on trail mode with performance shifting for now. Haven't messed with everything else.
    I shouldn't need a battery charger on it if I plug it back in and adjust the settings, right? Just during initial install?
  14. Oct 21, 2015 at 4:27 PM
    #314
    TxTundraGuy89
    Korwin
    Best to always plug up to battery charger honestly just to ensure it doesn't drain the battery.
  15. Oct 21, 2015 at 5:43 PM
    #315
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Do you need to do the hyper tech speedo fixer thing if you do the bully dog?
  16. Oct 21, 2015 at 5:55 PM
    #316
    TxTundraGuy89
    Korwin
    No, only time you would need a speedo calibrator is if you did lift, tires, or both.
  17. Oct 21, 2015 at 6:05 PM
    #317
    Virgils12
    I have both
  18. Oct 21, 2015 at 6:08 PM
    #318
    TxTundraGuy89
    Korwin
    Then yes you technically need the speedo calibrator but only if you want accuracy mph other than that you can put a bully dog on it and it will be fine.
    It may do more than just adjust the speedo but as far as putting a bully dog on it you can do it and be fine.
  19. Oct 21, 2015 at 7:22 PM
    #319
    So in my case, I would need both? I still have the HT speedometer calibrator, just not installed- yet.
  20. Oct 21, 2015 at 7:28 PM
    #320
    TxTundraGuy89
    Korwin
    Well funny Sean your the one that told me to look into it for my truck. Lol
    To me personally it's a matter of opinion of what you really want, I personally would just go with a BD tuner cause I mean afterall we're not buying these trucks for economy purposes lmao
    T-Rex266[QUOTED] likes this.
  21. Oct 21, 2015 at 7:33 PM
    #321
    TruckyTruck
    Gary
    The bullydog adjusts shift points, so if your shift points are wrong in the first place from 35s, which they will be, you probably should use the hypertech. I installed both.
    tat2ude39, T-Rex266 and TxTundraGuy89 like this.
  22. Oct 21, 2015 at 7:36 PM
    #322
    TruckyTruck
    Gary
    Yeah I would use the charger every time too. Sean, did you set the throttle to performance? I'm liking it that way.
    Have you had a chance to get on it since the install?
  23. Oct 21, 2015 at 7:36 PM
    #323
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Without the speedometer calibrator your speedo and mileage will be incorrect.
  24. Oct 21, 2015 at 7:46 PM
    #324
    Just the shift point. What setting did u put at throttle?
    Kinda...spun on some corners decently, but it's also raining in Denver so not a fair review.
  25. Oct 21, 2015 at 7:49 PM
    #325
    TxTundraGuy89
    Korwin
    It's always hard for me to stay out of it when it's on performance for throttle cause you know the power is there.
    When you have the shift in performance does it shift firmer or anything? Just curious cause now I am thinking of doing the trail tune haha
  26. Oct 21, 2015 at 8:17 PM
    #326
    TruckyTruck
    Gary
    I tried it first with stock throttle, but switched to performance. It's a little more touchy than stock but not much.
  27. Oct 21, 2015 at 8:19 PM
    #327
    TruckyTruck
    Gary
    Yes!!! If you had this tuner with all settings stock and performance shift alone, it would be worth doing. Firm shifts and no lazy feeling.
  28. Oct 21, 2015 at 8:21 PM
    #328
    Where can you get the best deal on a BD?
  29. Oct 21, 2015 at 8:21 PM
    #329
    TruckyTruck
    Gary
    Amazon was the best I could find
  30. Oct 21, 2015 at 8:23 PM
    #330
    TxTundraGuy89
    Korwin
    Hmmmm.....may have to check it out then.
