TruckyTruck's Build
Discussion in '2nd Gen Builds (2007-2013)' started by TruckyTruck, Jan 7, 2014.
  1. Sep 29, 2015 at 8:48 PM
    #271
    I have the tow package w/cooler. Haven't heard 8.5 qts ever until now. My my oil changes always average 7 qts. Probably 8 qts with a full flush which I will never do. Not necessary IMO.
  2. Sep 29, 2015 at 8:53 PM
    #272
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    The only thing I did was drain at the pan and replace the filter... I wonder if they changed the cooler size. I put 7 in at first, ran, then checked and it barely touched the dipstick. So I went up by half a quart until I was at 8 finally.
  3. Sep 29, 2015 at 8:57 PM
    #273
    It's crazy how much difference it is between oil changes here. Clearly the tow package will make a difference. Best opinion here on this would be from Jace. (What was you engine temp? Big diff if engine is cool or hot. Maybe a qt?)
  4. Sep 29, 2015 at 9:26 PM
    #274
    If a company installed this, sounds like they would be buying some new engines for their customers.
  5. Sep 29, 2015 at 9:52 PM
    #275
    TruckyTruck
    Gary
    I'm not sure of any company would install an aftermarket tune like this for you...
    By the way, I meant when the dealer flashes your ecu with their own stock tunes, they hook the battery up to a charger. Just like you would when flashing a BD tune on your own.
  6. Sep 30, 2015 at 5:39 AM
    #276
    I thought you were referring to the the SC :anonymous:
  7. Sep 30, 2015 at 11:13 AM
    #277
    I'm sure it's in here somewhere, but are you running 35's?
  8. Sep 30, 2015 at 11:19 AM
    #278
    Arjuarezusmarine
    Arjuarezusmarine New Member
    Joe
    Does the bully dog adjust for what new gears would do? Iam feeling a lot of power loss and Rpms while shifting is off. Once I added my lift and 35"s
  9. Sep 30, 2015 at 2:59 PM
    #279
    TruckyTruck
    Gary
    Yes, 35 12.5 20s... They are actually 34.5 inches though
    T-Rex266[QUOTED] likes this.
  10. Sep 30, 2015 at 4:34 PM
    #280
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Well Sean, it's a good thing when you find someone you can trust, especially a Toyota Master Tech at that. I get mine done by a family owned oil and lube. They are very professional and good at what they do, also I'm able to talk and watch the tech, just in case he breaks out the impact. No No!
  11. Sep 30, 2015 at 4:38 PM
    #281
    TruckyTruck
    Gary
    The bully dog tuner can change your shift points.... But, that's not what you need first.
    You need two things first:
    1. You need to reset your zero point calibration, ZPC. If you haven't of course.
    2. You need a hypertech speedometer calibrator. This will not only correct your speedometer with the larger tires, but it will correct your shift points.
    Then... Look at a tuner for extra power, mph and so on.
  12. Sep 30, 2015 at 4:50 PM
    #282
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    My truck takes 8.5 quarts every time.
  13. Sep 30, 2015 at 6:08 PM
    #283
    TruckyTruck
    Gary
    Where does it register on the dipstick? I read all these posts about older 2nd gens only needing 7. Makes me think the oil cooler is larger now
  14. Sep 30, 2015 at 6:09 PM
    #284
    Virgils12
    Right at the full make.
  15. Sep 30, 2015 at 6:10 PM
    #285
    TruckyTruck
    Gary
    Ok gotcha. 8 put me right in the middle of the two dots.
  16. Sep 30, 2015 at 6:12 PM
    #286
    Virgils12
    Ya that's where 8 would put me to but to me that top dot is there for a reason. So that's why I put the other half in.
  17. Sep 30, 2015 at 6:14 PM
    #287
    TruckyTruck
    Gary
    Yeah that makes sense. I just use the middle because it's where I've seen it every time the service department did the change.
  18. Sep 30, 2015 at 6:41 PM
    #288
    As long as you have someone you can trust, that's all that matters to me in my book!
  19. Oct 7, 2015 at 4:46 AM
    #289
    TxTundraGuy89
    TxTundraGuy89 New Member
    Korwin
    @TruckyTruck I love my BD tuner didn't have the speedo recalibrator but don't need it now I had level kit and 34's with my tow tune I was bringing in about 16-18mpg hwy and roughly 12-14mpg city. I had an all performance tune and mpgs went down big time.
    I do agree everyones truck will have there own sweet spot mine was fine with the performance but my shifting felt off so I put it back to my tow tune and it's running great!
    Now the truck due to a costly repair bill is all stock now, and I'm getting great results still.
    I have to agree with TruckyTruck if you do get a BD just make sure to follow the instructions and you'll be fine. I advise personally to always have a battery charger hooked up to your battery even if it's brand new just so you don't drain yours.
    TruckyTruck[OP] likes this.
  20. Oct 7, 2015 at 9:56 AM
    #290
    Mike Tread lightly.
    south carolina
    Why is my name in this?:boom:
    My understanding is the Line has been added and it cant be taken out unless the ecm is totally reflashed or replaced ECM. It would be very very dangerous to flash just to remove a line of code. Without double checking checksums on both units its very risky and bricking will and can happen. I dont think the unit would have the entire firmware on the bullydog loaded into the unit. Tho with no password access flashing will be a mood point. Im so glad toyota is not stupid and give people access to the password on the ecm's like the big 3 do.
  21. Oct 10, 2015 at 1:37 PM
    #291
    TruckyTruck
    Gary
    I've been getting this terrible itch to buy an old scout or something 4x4 to restore, fuel injected motor etc, basically an older vehicle made to run like something new and sell the tundra.... Really hoping this itch goes away. I just got my tundra just where I want it and now this! I love this truck and its the perfect combination of bad ass and family friendly. Maybe its a prelude to a midlife... :goingcrazy:
  22. Oct 10, 2015 at 7:33 PM
    #292
    TruckyTruck
    Gary
    Nevermind, took the truck out and romped on it a bunch. Too badass to get rid of! Headers and mid pipes next
    T-Rex266 and rons23 like this.
  23. Oct 10, 2015 at 7:46 PM
    #293
    Surfthetundra
    Surfthetundra New Member
    SouthEast US.
    2015 toyota tundra
    3" Toytec Lift, 20" Mayhem Wheels (8090) 34.1" Tires. More to come.
    Pretty much everything i want to do to mine. Its the perfect build.
  24. Oct 10, 2015 at 7:49 PM
    #294
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Lol
  25. Oct 10, 2015 at 8:10 PM
    #295
    TruckyTruck
    Gary
    Do it! Thanks man
  26. Oct 11, 2015 at 6:31 PM
    #296
    https://www.tacomaworld.com/threads/fs-1970-scout-800-a-304-auto-las-vegas-nv.393812/
  27. Oct 11, 2015 at 6:40 PM
    #297
    TruckyTruck
    Gary
  28. Oct 11, 2015 at 6:44 PM
    #298
    :stirthepot:
  29. Oct 11, 2015 at 6:56 PM
    #299
    TruckyTruck
    Gary
    I need to start checking the for sale section over there. It's better than craigslist!
  30. Oct 11, 2015 at 7:27 PM
    #300
    That Scout is nice, but if you really want one, go for the Scout II with the 345 (5.7L). They are out there.
