Truck wont start need help
Discussion in '1st Gen Tundras (2000-2006)' started by Marco05Tundy, Jan 19, 2022.
  1. Jan 20, 2022 at 9:07 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    That was true for older vehicles. But modern vehicles the electronics and computers are far more sensitive to input voltage and shut down before the battery is dead enough to just “create spark”.
    Jack McCarthy likes this.
  2. Jan 20, 2022 at 1:45 PM
    Marco05Tundy
    Marco05Tundy [OP] New Member
    Marco
    So I still had warranty and went to exchange the battery at Walmart , put in new battery , tried starting and heard a loud screeching noise , now truck is doing the same thing just one click no start .
  3. Jan 20, 2022 at 1:50 PM
    Marco05Tundy
    Marco
    Another note to add, my battery died last year in march , swapped it with new battery and everything was fine , maybe the alternator finally gave out ??
  4. Jan 20, 2022 at 2:39 PM
    Aerindel
    Aerindel New Member
    Montana
    Look at what subforum your in.....
  5. Jan 20, 2022 at 2:44 PM
    Aerindel
    Aerindel New Member
    Montana
    Okay...thats not great....
    You need to get under the hood and start taking things apart.
    This is spitballing....but I wonder if your alternator bearings are seized and what you heard was the engine pulley trying to turn a belt and slipping. That could explain everything...alternator going bad, stops charging, letting battery get low...then burns up, seizes up...and brings you to a stop with a belt.
    Either way I think you need to take all the belts off make sure everything moves...including putting a socket on your engine and making sure its not seized from a slipping timing belt or something.
    And again...try jumping it with the ground directly to the engine block...preferably with someone watching under the hood to see what happens.
  6. Jan 20, 2022 at 2:49 PM
    Marco05Tundy
    Marco
    Yeah that makes a lot of sense , gonna have to do that early Saturday morning
  7. Jan 20, 2022 at 2:54 PM
    Marco05Tundy
    Marco
    Do you think the truck should start if I try jumping it with another vehicle even if alternator is bad ?
  8. Jan 20, 2022 at 3:09 PM
    Aerindel
    Aerindel New Member
    Montana
    Absolutely. You could start and run the truck with no battery, and no alternator on jumper cables as long as nothing else was wrong. (At least until you reached the end of the cables :) )
    Remember, the alternator is just a battery charger. It doesn't even start putting out power until the engine is running so the only way an alternator stops you from starting is if its seized up and physically keeping the engine from turning.
    Your truck can run for a good hour or more, with a fully charged battery and no alternator (depending on what else you have on, like headlights, fans, AC, etc) just from battery power alone as your coils and fuel pump don't pull very much power.
    shifty` likes this.
  9. Jan 20, 2022 at 6:59 PM
    ScenicRoute
    You’re right. For some reason I thought this was a 2019. I stand corrected.
    Leo's first and Aerindel[QUOTED] like this.
  10. Jan 20, 2022 at 7:57 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I second the seized alternator check. Take the belt off and make sure you don't have anything seized. I've replaced a starter and turned out to be a stuck A/C compressor.
  11. Jan 21, 2022 at 2:50 PM
    Marco05Tundy
    Marco
    tested both alternator and starter and they’re both good fml
  12. Jan 21, 2022 at 3:34 PM
    Aerindel
    Aerindel New Member
    Montana
    Okay, well, you have to find out what is screeching...I'd take all the belts off and try again. Power steering and AC can seize on you too.
    Nothing should be screeching so whatever that is, is where your problem is.
  13. Jan 21, 2022 at 4:43 PM
    I mean, it could still be a cable issue. I still suspect there's a larger problem here, and now the starter, the alternator, and the battery are ruled out, that leaves what ... bad cable - either the positive batt cable, the line from the alternator to the batt, or the jumper from the positive batt cable to the in-engine fuse/relay box.
    But yeah, sounds like there's a pulley or tensioner that caused the loud ass squeal. Not sure that's what's up, though.
    @Marco05Tundy do this. Can you have someone try to turn the truck over while you jiggle the thinner cable that goes from the positive side of the battery to the fuse/relay box? Then have them try to turn it over while you jiggle the positive battery cable and the negative battery cable? If you get any extra action out of it, maybe a sign. But this is NOT a definitive "if it doesn't work, your cables are good" test.
    Aerindel[QUOTED] likes this.
  14. Jan 24, 2022 at 6:22 AM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    I disconnect the negative cable to check for alt condition, forget why
    alb1k[QUOTED] likes this.
  15. Jan 1, 2023 at 8:57 PM
    Marco05Tundy
    Marco
    Engine ended up being seized , replaced it with a 06 sequoia engine . $3,400 dollars later
  16. Jan 2, 2023 at 5:27 AM
    Aerindel
    Aerindel New Member
    Montana
    Thanks for the update. Thats unfortunate. Any idea why it seized?
  17. Jan 2, 2023 at 12:46 PM
    Marco05Tundy
    Marco
    Quick little background story , I bought this truck as my first truck for 6k , test drove it and everything seemed fine , after a few months I had a guy come look at it and he mentioned there was a significant amount of frame damage . I wanna say the previous owner crashed it and it overheated on him? I had done regular maintenance on it and it still took a shit.
    Fast forward to now , I replaced the engine and everything seems to be running fine , I fell in love with the truck again !
    Leo's first likes this.
  18. Jan 2, 2023 at 12:48 PM
    Marco05Tundy
    Marco
    Also ! It was smoking from my battery cause the starter was trying so hard to turn the engine over and it never could . Crazy shit lol
  19. Jan 2, 2023 at 9:06 PM
    #49
    NickB_01TRD
    Nick
    KY
    How old was the timing belt?
  20. Jan 3, 2023 at 7:56 AM
    #50
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    This sucks! Glad you got it fixed but damn. Good trouble shooting tips in here though. More sticky material for sure. I need to test my alternator now for fear of it failing and catching fire!
  21. Jan 11, 2023 at 9:32 PM
    #51
    Marco05Tundy
    Marco
    on old engine ? Idk man . Current engine has a new one though
  22. Jan 11, 2023 at 9:39 PM
    #52
    NickB_01TRD
    Nick
    KY
    Just wondering if it was just a broken timing belt that caused your engine lockup.
  23. May 3, 2024 at 7:20 AM
    #53
    Jmun2987
    Jmun2987 New Member
    02 tundra
    Mine did the same thing. Mine actually died while driving. It ended up being the ground wire from the negative terminal post to the body of the truck. Could have came off while driving I don’t know. Once I hooked up that little wire everything was good. 2002 Tundra.
