Truck won’t go beyond 90mph after 5.29 Nitro Gear installed
Discussion in 'Performance and Tuning' started by Tundi1020proformdys, Apr 21, 2021.
  1. Apr 22, 2021 at 11:54 AM
    Tundi1020proformdys
    Tundi1020proformdys [OP] New Member
    Fort Lauderdale
    18 TRD PRO
    I just ordered my HP Tuner as well. Game on!
    Vizsla likes this.
  2. Apr 22, 2021 at 12:18 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    I have nitro 5.29 gears installed with 33" tires and I hit the limiter at around 102 mph. My truck is supercharged but that shouldn't make a difference for when the limiter kicks in.
  3. Apr 22, 2021 at 12:22 PM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Didn’t your SC tuner remove the governor due to the SC? Are you planning to remove the governor?
  4. Apr 22, 2021 at 12:26 PM
    pvmike
    Los Angeles
    I have a TRD branded Magnusson and hence the TRD tune. I would have removed the limiter if that was an option.
  5. Apr 22, 2021 at 12:30 PM
    pvmike
    Los Angeles
    The limiter cuts gas and it feels like it; it's like hitting a wall. It doesn't hold at a particular speed like in your description.
  6. Apr 22, 2021 at 12:56 PM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Ok, now I understand. The reason why I were inquiring is that I have looked into getting the Magnuson SC in recent months. Their website stated that their tuner would allow customers to remove the governor and rev limiter. So, that’s why I thought that it would be a standard option with all sc for Tundras.
    thanks for the clarification.
  7. Apr 22, 2021 at 1:01 PM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    I see. I’ve always hit the governor with my trucks. I have a lead foot. :) The experiences that I have been having with this particular upgrade is consistent with the governor. But it is more pronounced than prior to regearing. It sorta felt like when my VSC kicks in and the truck is being pulled back.
  8. Apr 22, 2021 at 1:07 PM
    Vizsla
    Vizsla 2 = 2.5
    Yes, think the speed limit needs raised but not sure, just did it. For wheeling my tune is corrected for gears and tires, speed limiter raised, 4 LO limits removed, aip limp mode disabled, redline and knock system raised 200 rpm(fun to make ricer noises), with a few transmission tweaks to smooth out shifting.
    No issues for me. Raising it not removing.
  9. Apr 22, 2021 at 2:56 PM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    That’s cool as hell. Keep us posted.
  10. May 1, 2021 at 7:35 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    OMFG!!!! My truck is back baby! Flashed it this morning and just came back from a test drive. Mashed that skinny pedal with no issues and the speedometer is on the money too. Can't wait to test bumping the truck in 4Lo. Best $500 spent.
  11. May 1, 2021 at 7:58 AM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Just curious for those of you running 37's or 39's. Have you ever checked the speed rating for those tires?
    You're going to go on a hell of a ride if a 39 came apart north of 100. Hopefully no one else will be in your way.
  12. May 1, 2021 at 8:07 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    My previous set of 37s were Cooper STT Pros and they're rated at 99mph but I've gone higher than that for long periods of time (driving to Vegas) and never had problems. Although I did blow out a tire going 65mph :notsure:
  13. May 1, 2021 at 8:42 AM
    Vizsla
    Vizsla 2 = 2.5
    Hell yeah buddy!:burnrubber: The 4LO limits removed is really nice.
  14. May 1, 2021 at 9:54 AM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    I just got mine in today. Getting ready to do the update to the program, then tune my truck.
    did you have to add credits to your tuner before updating the tuner?
  15. May 1, 2021 at 10:05 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I purchased the credits at the same time I bought the unit. When you go to write to the ECU is when you use the credits.
  16. May 1, 2021 at 10:07 AM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    I have been told by a manager at Tire Kingdom that the speed ratings on tires are the limits on the tires for the maximum speed driven continuously for a minimum of one hour. Therefore, unless you’re driving on the autobahn where there are no speed limits and no cops to pull you over, it’s highly unlikely that you can drive any vehicle at say 99mph continuously for one hour straight.
    speed ratings are guidelines for the tires.
  17. May 1, 2021 at 10:08 AM
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    How many credits did you need to get it done?
  18. May 1, 2021 at 10:09 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    4
  19. May 1, 2021 at 10:11 AM
    #49
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Ok, thanks. I need to purchase some credits first.
  20. May 1, 2021 at 10:35 AM
    #50
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    So with the gear ratio change and tire size, even though your speedo says 90 its most likely 105 mph ... check with GPS data to confirm
  21. May 1, 2021 at 2:57 PM
    #51
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    My Garmin says that I’m doing 93mph whenever my Speedo say that I’m doing 88mph. So, I think that I’m about 5mph faster than my Speedo with 5.29 gears and 35” tires.
    papasmurf[QUOTED] likes this.
  22. May 2, 2021 at 6:34 AM
    #52
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Yeah never mind its backwards... you go faster on speedo than GPS I'm retarded LOL it was a long week I'm tired lol
  23. May 2, 2021 at 9:22 AM
    #53
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Lol.
  24. May 2, 2021 at 9:38 AM
    #54
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Your Speedo is always going to give you a slower speed than what you’re actually doing whenever you go bigger tires than stock. From my experience, the GPS is usually a bit more accurate than the speedo at that point in time. I may get a calibrator or something like that in the future.
  25. May 2, 2021 at 9:43 AM
    #55
    Cruzer
    Cruz
    Sunnyvale, CA
    You won’t need a calibrator once you enter the correct tire radius and gear ratio with the HPT.
  26. May 2, 2021 at 9:48 AM
    #56
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    Yes, you’re correct. I totally forgot about that. Thanks.
    Cruzer[QUOTED] likes this.
  27. May 2, 2021 at 4:07 PM
    #57
    Vizsla
    Vizsla 2 = 2.5
    My speedometer is off, not sure how much. Need to check I guess, but truck is down for repairs this week. This is the owner of HP Tuners for reference -
    https://forum.hptuners.com/showthread.php?78762-Tundra-speedometer-calibration
  28. May 2, 2021 at 4:43 PM
    #58
    Tundi1020proformdys
    Fort Lauderdale
    18 TRD PRO
    I have both an aftermarket stereo head unit and a Garmin gps/lane departure/dashcam. Both the stereo gps (Pioneer) and the Garmin are within 1mph of each other. Sometimes they are identical to each other. That’s usually whenever the sky is crystal clear and without any other interference from other objects.
    however, my stock Speedo is never correct. So, I’m planning on using my HP Tuners to recalibrate that as well. I’ll do so later on in the week.
