Truck staying in "trailer mode" after disconnected
Discussion in '3rd Gen Tundras (2022+)' started by 4genRunner, Jan 24, 2023.
  1. Jan 24, 2023 at 5:06 PM
    4genRunner
    4genRunner [OP] New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    First two times I have hooked up to our travel trailer, I have noticed something strange. When you connect the trailer and it recognizes there's a trailer back there, it turns off RCTA, sets BSM to trailer mode, etc. Great, that's what it's supposed to do. Problem is, once the trailer is disconnected the truck continues to say the same thing at startup, even with no trailer connected.
    Trailer detected
    BSM trailer mode
    RCTA off
    And you can even turn RCTA back on through the center console. After a day or so it all goes away and everything is back to normal. Has anyone else seen this issue?
  2. Jan 24, 2023 at 6:24 PM
    earlwright239
    earlwright239 New Member
    2022 Army Green Tundra SR5 TRD Sport
    Yup same issue last week when I used our 17ft open trailer to haul our SxS to the shop. And went away on the next drive.
  3. Jan 25, 2023 at 8:10 AM
    4genRunner
    Southwestern MO
    Both times I have had the trailer hooked up, for the remainder of that day after the trailer was disconnected, the truck was in trailer mode. I don't recall making a long drive after disconnecting, but one of the two times I did make multiple short drives.
  4. Jan 25, 2023 at 1:55 PM
    flatlandclimber
    flatlandclimber New Member
    2022 DC
    Mine stays in trailer mode for a minute or two the first time I start it after disconnecting, but it clears pretty quickly.
  5. Jan 27, 2023 at 3:38 PM
    Limited 23SC
    Limited 23SC New Member
    2023 Limited
    After i tow my little 5x8 trailer and disconnect it, the trailer mode goes away before i make it to the next street.
  6. Feb 27, 2023 at 3:25 AM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    You can go into the trailer menu and deselect the trailer, the system will go back to normal.
