truck partially submerged
Discussion in 'General Tundra Discussion' started by Jeffro22, Aug 11, 2020.
  1. Aug 11, 2020 at 6:22 AM
    Jeffro22
    Jeffro22 [OP] New Member
    2013 platinum crewmax 4x4
    Truck got caught in a flood and i am 90% sure the water was above both differentials. Going to go ahead an drain and refill both differentials. Appears to me that the TCase and the transmission should be fine. Wondering if I will need to do the drain and refill the diffs a couple times of if once will be sufficient?
    I pulled fill plug on rear and oil looked OK but was overfilled and maybe 1/2 qt-1 qt drained out so I am guessing that overfill is from water coming in through the vent
    Only other issue I see if possibly the alternator being so low and maybe having it fail later on
  2. Aug 11, 2020 at 6:32 AM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    If you have insurance, I wouldn't do anything until you call them and see if they want to send out an adjuster. Just my 2 cents!
  3. Aug 11, 2020 at 6:38 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Even if it was flooded above the differentials, it does not mean that they are filled with water. Only a small amount, if any, would enter the differential, so I would say one oil change would suffice. If you drain the oil and it is obvious that there is a lot of water in there then a second oil change might be justified, but I doubt that.
    Check for other components like the alternator - if it is apparent that it got flooded also then maybe get your insurance to look at it.
    NewImprovedRon likes this.
  4. Aug 11, 2020 at 6:46 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    I had my Tacoma in some pretty deep water (middle way of the doors) during a hurricane we had here in NC several years ago. The differentials were to totally fine. Water didn’t even get inside the truck when this happened either. I was shocked honestly. Now the tundra might be different so take this info how ever you like.
  5. Aug 11, 2020 at 7:00 AM
    Jeffro22
    insurance has already been involved and I will be "salvaging" the truck. Unfortunately it was saltwater, which I am sure will cause some issue later on.
    The rear oil looked clean when I opened up fill plug but was overfilled which I am guessing indicates water? I assume the water has probably settled to the bottom. I am going to go pick up enough gear oil for front and rear and go ahead swap out.
    Ill keep yall updated
  6. Aug 11, 2020 at 7:03 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, salt water adds to the concern for sure.
    YardBird likes this.
  7. Aug 11, 2020 at 7:33 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    "There's nothing that salt water and a sailor can't screw up."
    ~ Unknown YardBird working in ship repair for the Navy ~
  8. Aug 11, 2020 at 7:56 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    Isn't the front diff and transfer case breathers mounted up high on the firewall? I bet the front is ok, and unless you have relocated the rear diff breather, you have water in there. I would start spraying everything down with water displacement spray, and start relubricating everything underneath the truck. Especially the brakes, and any wiring connections.
    Good luck!!
  9. Aug 22, 2020 at 4:34 AM
    Jeffro22
    When I drained the rear I didn’t see any indication of water.
    Haven’t checked front or transfer case yet
  10. Aug 22, 2020 at 4:37 AM
    timsp8
    NY
    Yeah, front breathers are higher up in the engine bay. Did you also hose it off really good underneath? We have long winters here and I go to the car wash at least every 2 weeks to get the salt build up off.
