Truck MOD or Colt AR?
Discussion in 'General Tundra Discussion' started by geno0506, Feb 23, 2018.
  1. Feb 24, 2018 at 3:47 PM
    #121
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    No bad they don't say "Restricted Military/Government Law Enforcement Use Only" anymore, those are worth big $$$.
    geno0506[OP] likes this.
  2. Feb 24, 2018 at 4:00 PM
    #122
    geno0506
    geno0506 [OP] New Member
    Michael
    Is there any reason why they are not in production anymore, the only thing its missing is the A1 stamp, whats the A1 mean, is that a negative!
  3. Feb 24, 2018 at 4:10 PM
    #123
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
  4. Feb 24, 2018 at 4:35 PM
    #124
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    The A1 designates the SOCOM profile which is heavier under the handguard.
    Those M4A1 marked lowers command a premium these days.
    geno0506[QUOTED][OP] likes this.
  5. Feb 24, 2018 at 5:17 PM
    #125
    geno0506
    Michael
    Thanks
    Does the non heavier lower make it any less in quality!
    Thanks
  6. Feb 24, 2018 at 5:18 PM
    #126
    pinellasjoe
    pinellasjoe New Member
    Seminole, FL
    2017 TRD Pro
    This is the one I picked up from grabagun in November. The one from gun pro should have the same markings. I will let you know as soon as it comes in.4C765D78-D667-4EA2-BA3C-21964A95F289.jpg
  7. Feb 24, 2018 at 5:21 PM
    #127
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    The lower is identical other than the engraving. The difference is the barrel profile.
    SOCOM M4A1 on top, standard “government” profile M4 on bottom.
  8. Feb 24, 2018 at 5:29 PM
    #128
    geno0506
    Michael
    Thanks
  9. Feb 24, 2018 at 5:51 PM
    #129
    geno0506
    Michael
    Thanks for the info!
  10. Feb 24, 2018 at 6:40 PM
    #130
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Palmetto state armory
  11. Feb 24, 2018 at 7:08 PM
    #131
    Rngr188
    Chad
    Harrison AR
    Is the difference between the two because of M203 launcher capability?
  12. Feb 24, 2018 at 8:01 PM
    #132
    geno0506
    Michael
    So is it pretty much the same Barrel but one being heavier
  13. Feb 24, 2018 at 8:15 PM
    #133
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Both are M203 capable with the right rail. The heavier profile is to help with sustained automatic fire. There have been a few instances where the regular profile was pushed too hard in combat and caused failures.
    As a civilian with a semiauto rifle the need for the heavy profile really isn’t there. However the heavier profile barrels have shown slightly better accuracy.
    In my opinion the lighter profile will suit the average user better and be easier to carry for extended periods such as LE work or hunting.
    Noodle and geno0506[QUOTED][OP] like this.
  14. Feb 24, 2018 at 8:20 PM
    #134
    geno0506
    Michael
    Makes sense, thanks for the explanation!
    Upgrayedd[QUOTED] likes this.
  15. Feb 24, 2018 at 8:20 PM
    #135
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I only have one heavy barrel AR, and it’s actually Canada’s heavier profile military barrel, the C8 SFW. It’s a good shooter but I’d rather not have to carry it for extended periods.
  16. Feb 24, 2018 at 8:23 PM
    #136
    Noodle
    Noodle That Guy
    Files creek
    ^^ this man knows of what he speaks. If you ever want to try out some commie guns hit me up Josh. I might have a couple. Wasn’t it you who posted pics of a FAL/HK in another thread?
  17. Feb 24, 2018 at 8:25 PM
    #137
    geno0506
    Michael
    If I choose to build can I buy the Colt heavy barrel and build on the LE6920 or should I look for a Colt Socom 6920 used that has the heavy barrel, I would use this only for CQ not hunting!
  18. Feb 24, 2018 at 8:26 PM
    #138
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Thanks. Yeah I have an HK91 as well. Hopefully I’ll add a FAL to the collection at some point. Really want one of those. And I’m definitely down for a range day.
    Noodle[QUOTED] likes this.
  19. Feb 24, 2018 at 8:29 PM
    #139
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Yeah definitely. You can usually find 14.5” Colt SOCOM barrels for $250 or so. If you don’t want to go the SBR route you can have an extended flash hider welded in place to bring the overall length over 16”. Colt 16” SOCOM barrels are kinda rare these days. But BCM sells them in both 14.5” and 16” length.
    Realistically though the SOCOM profile is not needed unless you have a rifle with a fun switch and plan on running a lot of rounds through it fast.
    geno0506[QUOTED][OP] and Noodle like this.
  20. Feb 24, 2018 at 8:35 PM
    #140
    geno0506
    Michael
    Thanks for the great info, can I hit you up if I choose to build! :cheers:
    Noodle and Upgrayedd[QUOTED] like this.
  21. Feb 24, 2018 at 8:39 PM
    #141
    Noodle
    Noodle That Guy
    Files creek
    Hell yeah, I’m in Richmond but work in Williamsburg let’s plan a range day sometime. It was your HK 91 I seen in another thread. I have a commie gun in .308 too. Those HK91s are fucking sweet weapons.
  22. Feb 24, 2018 at 8:39 PM
    #142
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Yeah definitely. I have built most of mine except for my SBR. It’s easy if you have the right tools and follow the correct assembly procedures.
  23. Feb 24, 2018 at 8:42 PM
    #143
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Nice. That a Saiga?
    The 91 is an awesome rifle.
  24. Feb 24, 2018 at 8:50 PM
    #144
    Noodle
    Noodle That Guy
    Files creek
    Yeah, it started life as a sporterized version and I converted it. Pics pre conversion,
  25. Feb 24, 2018 at 11:14 PM
    #145
    Noodle
    Noodle That Guy
    Files creek
    @geno0506 i apologize for shitting all over your AR thread with commie guns
  26. Feb 24, 2018 at 11:20 PM
    #146
    geno0506
    Michael
    No apology needed brother, You had some good info, I've never owned anything but a Colt AR, so other options are good to know!
    Cheers :cheers:
    ColoradoTJ and Noodle[QUOTED] like this.
  27. Feb 24, 2018 at 11:33 PM
    #147
    Noodle
    Noodle That Guy
    Files creek
    I tried to contribute some pertinent info and got off track. Good luck with your decision, if I can be of any help let me know.
  28. Feb 24, 2018 at 11:56 PM
    #148
    geno0506
    Michael
    Thanks, I'll hit you up if I get confused with a build if I go that route but the basic Colt LE6920 sounds good!
    ColoradoTJ likes this.
