Truck lasted 3 weeks
Discussion in '2nd Gen Tundras (2007-2013)' started by Thesandaddict, Apr 22, 2019.
  1. Apr 22, 2019 at 7:43 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    Could be bad vvti cam gear. When they start to go they can clack just like rod knock. Question is can a vvti sensor shutdown the motor? It will likely be an easy diag for Longo, if no codes they will pull valve covers and then if nothing is found they will scope it.
    5.7s are in the used parts network for a decent price so it shouldnt get too crazy expensive.
    equin likes this.
  2. Apr 22, 2019 at 7:43 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    Could be a rod bearing, but the truck shut down. If it was a rod than I would think at those speeds the bottom of the engine would have a new vent in it and oil would be everywhere. Without being able to see or hear it then we could make all kinds of comments on what it could be. But I’m hoping that it’s something simple so you aren’t looking at a $5000 plus bill.
    Thesandaddict[OP] likes this.
  3. Apr 22, 2019 at 7:46 PM
    Thesandaddict
    Thesandaddict [OP] The dude
    Harley
    2010 DC
    Bilsteins, methods
    I dont see a vvti cam gear failing at 63k miles...
  4. Apr 22, 2019 at 7:47 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    That's what I was thinking, unless the connecting rod snapped while on up stroke and just mated the piston to the head.
  5. Apr 22, 2019 at 7:52 PM
    pickeledpigsfeet
    Kings & Icons
    I have seen them fail in almost all models of vvti motors by 50k usually due to lack of oil changes. Toyota has done multiple TSBs on the smaller car motors for vvti gear replacements due to locking in advance and clacking. The hydraulic holes are so small that vvti issues are usually the first system to fail. They introduced removable vvti screens but now those just plug up and starve the front cam journal of oil.
    Did you check to see if this tsb for vvti has been performed on your truck?
    https://tundraheadquarters.com/2010-toyota-tundra-gear-tsb/
    equin and GNTundra like this.
  6. Apr 22, 2019 at 7:54 PM
    Trpl7
    Rob
    Washington
    Super White 07
    If it started but was noisy, could it be that only half the engine was running? I’m just trying to figure out why it shut down. I hope your problem is more electrical over mechanical. I personally have not seen an engine that broke a rod at somewhere in the neighborhood of 2000 rpm and just died. Quietly.
  7. Apr 22, 2019 at 7:56 PM
    Trpl7
    Rob
    Washington
    Super White 07
    I think pickeledpigsfeet is on the right track
  8. Apr 22, 2019 at 8:14 PM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    I have 19 oil changes on carfax. That puts me at the appropriate mileage
  9. Apr 22, 2019 at 8:15 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Curious to hear what happened? Wondering how it was driven before you took ownership of it??
  10. Apr 23, 2019 at 8:46 AM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Toyota called. They said fuel sending unit failed. They cant replicate the noises. Will investigate after work.
    equin and 15whtrd like this.
  11. Apr 23, 2019 at 8:54 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Huh. A lot better than a busted engine.
    TheBeast likes this.
  12. Apr 23, 2019 at 8:56 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe it was the sound of your fuel injectors running dry.
    equin likes this.
  13. Apr 23, 2019 at 9:40 AM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Well they can't replicate the noise because it won't run. Well see what happens after the new unit gets dropped in
    15whtrd and TheBeast like this.
  14. Apr 23, 2019 at 9:57 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Fuel pump is not getting power. or it's dead.
  15. Apr 23, 2019 at 10:05 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    This is all very interesting I'm just here for the ride. Curious to hear the outcome. Good luck and hopefully its something cheap
  16. Apr 23, 2019 at 10:13 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    Don't give up on that beast yet, prolly just had a bad day and she will give you many more years of good service. Hopefully it won't come at a hefty price due to crappy maintenance on the POs part.
  17. Apr 23, 2019 at 11:28 AM
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Fuel pump is 100% dead. But I had a very chaotic metal on metal sound when attempting to restart the truck. Which they cannot replicate because, as stated, fuel pump and sending unit are junk. So once the unit is replaced well know of any further potential issues
    Rex Kramer[QUOTED], 15whtrd and equin like this.
  18. Apr 23, 2019 at 11:34 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Please keep us posted with ultimate resolution.
    Stormtrooper81 likes this.
  19. Apr 23, 2019 at 11:35 AM
    #49
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That’s odd. So fuel sending unit as in the fuel gauge/level unit that’s inside the tank? I remember the older cars would just show empty on the cluster gauge if one of those went out. Weird that something like that would cause the whole truck to shut off.
    Either way, thanks for the update. Still very curious to know what else they say.
  20. Apr 23, 2019 at 11:36 AM
    #50
    equin
    Ed
    DFW, TX
    Oh, so both the pump and fuel gauge sending unit are dead? That makes more sense if the pump also died.
  21. Apr 23, 2019 at 11:48 AM
    #51
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Yes. Just odd timing i guess. Still have to see what the other noises were
    equin[QUOTED] likes this.
  22. Apr 23, 2019 at 11:52 AM
    #52
    equin
    Ed
    DFW, TX
    Wondering what made both go bad? As for the noises, I think the other suggestion about the injectors going dry sounds plausible, but who knows? You said it sounded like metal clacking. Not sure if dry injectors would make that sound. Hopefully the tech will figure it out once the truck is running again.
  23. Apr 24, 2019 at 8:56 AM
    #53
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    So picked up the truck. Runs fine. Bad pump and bad sending unit. Service tech couldnt get any replication of what I heard. Now I'm second guessing myself and wonder if it was something else completely unrelated.
    Regardless big props to Longo Toyota for not only getting it done in one day but helping me out with the price. Wanted to charge $984 for everything and 5.5hrs of labor, knocked it down to 2.5hrs as a good faith move. This is my 6th Toyota and 5th Toyota truck and the first issue I've ever had with any Toyota vehicle.
  24. Apr 24, 2019 at 10:49 AM
    #54
    NWExplorer
    NWExplorer this guy
    Washington
    2010 CM Platinum 4x4
    Glad it worked out. Funny how our minds go to the most expensive and extreme thoughts for what is wrong. I had a noise in my 80 series Land Cruiser that I heard through the oil pan and thought it was a crank bearing going out. Turned out to be the AC tensioner pulley dying.
  25. Apr 24, 2019 at 12:26 PM
    #55
    equin
    Ed
    DFW, TX
    Thanks again for the update.
  26. Apr 25, 2019 at 5:12 AM
    #56
    Dr_Al
    Dr_Al New Member
    Al
    Could have been worse. I think the fuel pump and sending unit are just one combined unit. As for the noise, it could have been pre-ignition from a lean condition. As the pressure dropped in the fuel line the injectors were putting less fuel into the cylinders. Just a guess but hopefully all is well now.
  27. Apr 25, 2019 at 5:37 AM
    #57
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Congrats. For a 2010, that's a great result, and Toyota did right by you. After hearing all the strange noises and experiencing surprising symptoms on shutdown, a newby convert from Ford would have been ready to throw Yoda under the bus. ;)
  28. Apr 25, 2019 at 6:14 AM
    #58
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Having had a fuel pump die while driving...the engine can make some real shitty noises when its as @Dr_Al mentioned running on low fuel pressure.
  29. Apr 25, 2019 at 6:17 AM
    #59
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    great ending...rock on!
  30. Apr 25, 2019 at 6:18 AM
    #60
    Thesandaddict
    Harley
    2010 DC
    Bilsteins, methods
    Thanks again peeps. Definitely a strange situation that I'm glad worked out. I did have mechanical breakdown insurance through mercury that I purchased because I didnt trust this 3rd party dealer, and man did it work out. I will always be a Toyota fan and this didnt sway me at all. Just an odd situation I guess. The noises tripped me out for sure. I had a Silverado that had a pump fail and it just shut down, no noises or anything, so this didnt come to mind
    equin and Boerseun like this.
