Truck is a liar - mpg
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra280AI, Nov 22, 2016.
  1. Nov 23, 2016 at 6:03 AM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    I would like to see the data list at idle.
  2. Nov 23, 2016 at 6:05 AM
    Benni
    Benni New Member
    2016 Limited
    ................actually it is 5 gallons not 8, unless not all years have the same reserve capacity, anyway it's a truck & trucks are workhorses not go to the mall experiences. I take down trees for firewood on my property in some of the most godawful conditions you can imagine. Since I bought my '16 Limited I've had to utilize it to pull down two 80' trees that would otherwise have been hung up on each other for 5 or 10 years, I couldn't do this with the Taco.
  3. Nov 23, 2016 at 6:51 AM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    280AI, hey, you're gonna get called a troll if you come to a Tundra forum and spew negativity. Just ask the damn question. There's no reason to get everyone up in arms. I promise insulting members intelligence wont help either. In fact, it's against the code of conduct which could ban you. JUST SAYIN!
    As for your fuel economy this isn't just a Tundra thing. Just about every car with available distance and consumption computer functions is wrong. The idea behind the tool was based on approximations from many data points.
    Check out the following articles, perhaps they might be able to shed light on this particular issue for you.
    http://www.edmunds.com/fuel-economy/your-fuel-economy-gauge-is-fibbing.html
    http://blog.caranddriver.com/why-yo...ving-accurate-mpg-readings-and-how-to-fix-it/
    kritsana21 likes this.
  4. Nov 23, 2016 at 7:11 AM
    My tank "reserve' is definitely 6 gallons on my 07. As mentioned, indicated mileage is a reference only. My indicated mileage pretty much stays near 11.3. For the last year and then some. I know I get as much as 15 or more average when I go to my property. I just don't worry about it at all. Ever. It's a big truck. Gas is cheap.
  5. Nov 23, 2016 at 7:14 AM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    And maybe you weren't taught how to speak to people nicely. Try not being negative or condescending.
  6. Nov 23, 2016 at 7:18 AM
    cdkenne
    Corey
    KS
    I kind of thought this summed it up well, but what do I know.
  7. Nov 23, 2016 at 8:13 AM
    Tundra280AI
    Tundra280AI [OP] New Member
    COS
    '17 Tacoma TRD OR
    I made a legit post abut the difference in indicated vs actual and get called a troll. Heaven forbid you make a negative post about a truck you own
    I know my 2014.5 Camry SE Sport i took to Germany got right around the same indicated vs actual. So why can Toyota get that right but the Tundra is so far off every tank? If they can do it for one, why not the other? Unless it's intentional
  8. Nov 23, 2016 at 8:40 AM
    cdkenne
    Corey
    KS
    Well I didn't call you a troll.
    Anyhow, a V8 will have more cylinder variance than a 4 or 6 cylinder. When only 1 cylinder is being monitored this allows more room for error on the other cylinders when more cylinders are present. If cylinder 1 uses the least amount of fuel, there will be a significant variance on a V8. On a 4 cylinder, this won't be as noticeable.
    Also, if cylinder 1 fuel injector is leaking, the ECM will shorten the pulse to compensate and correct the Air/Fuel ratio. The average fuel economy will pick that up as the vehicle is not using much fuel because the pulse is shortened. This is just another example of what could be going on.
    Once again, Toyota does not even remotely claim this is accurate. It specifically states to use this as a reference. This is noted on Page 91 of the 2016 Tundra Owner's Manual.
    kritsana21 and joonbug like this.
  9. Nov 23, 2016 at 8:41 AM
    cdkenne
    Corey
    KS
    Unintenional post
  10. Nov 23, 2016 at 8:43 AM
    Tundra280AI
    COS
    '17 Tacoma TRD OR
    Thanks for the positive replies
  11. Nov 23, 2016 at 12:05 PM
    kritsana21
    kritsana21 New Member
    Hi, I'm not complaining about the gas mileage. I'm just wondering why the onboard computer it's so off. When other people are within +/- 0.5. Mine is off by 5 mi per gal. I just wanted to figure out if there something wrong with the sensors without taking it in to the dealership and get charge $120/hr for diagnosing.
    bama1302 likes this.
  12. Nov 23, 2016 at 12:06 PM
    kritsana21
    Thank you!
  13. Nov 23, 2016 at 12:10 PM
    cdkenne
    Corey
    KS
    If you don't have a check engine light then there aren't any sensors malfunctioning. Based on the system description, your transmission speed sensor would have to be bad or cylinder 1 would have to be misfiring for the inputs to the cluster to be incorrect/malfunctioning.
    It is just an estimate, not actual fuel mileage.
  14. Nov 23, 2016 at 12:29 PM
    kritsana21
    Thank you.
  15. Nov 23, 2016 at 2:50 PM
    cdkenne
    Corey
    KS
    I'm offended by your apology :stirthepot:
    Black Wolf and GNTundra like this.
  16. Nov 23, 2016 at 2:59 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Group hug :duel:
    GNTundra likes this.
  17. Nov 23, 2016 at 3:18 PM
    cdkenne
    Corey
    KS
    Good times but not at someone elses expense!!
    HAPPY THANKSGIVING TO ALL!![/QUOTE]
    And to all a good night
  18. Nov 23, 2016 at 5:09 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    OP made 2 comments:
    First, that the tundra is the worst rated truck.
    I asked by who? This is a troll comment if not supported.
    Second, he implies that Toyota is indulging in deceptive practices because his mathematical skills differ from the on board computer. Again, clearly another troll comment.
    Then, rather than attempt to support or justify either point he indulged in juvenile and childish attacks. Pretty impressive!
  19. Nov 23, 2016 at 5:13 PM
    #49
    cdkenne
    Corey
    KS
    I like to think I've got a pretty good handle on how Toyota does business. They are one of the cleanest companies I've had the pleasure of working for.
    gosolo[QUOTED] likes this.
  20. Nov 23, 2016 at 5:24 PM
    #50
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    cdkenne, at one place I worked we were acquainted with business management practices called lean thinking that I understand originated with Toyota. Are you familiar with this and was it part of your training at Toyota?
  21. Nov 23, 2016 at 5:29 PM
    #51
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    You can try resetting the MPG estimate display, just press and hold for a few seconds the "DISP" button in your steering wheel until your screen reset. I do it always when refueling my truck.
  22. Nov 23, 2016 at 5:55 PM
    #52
    kritsana21
    Yes sir, every time I filled up.
    iHacker[QUOTED] likes this.
  23. Nov 23, 2016 at 6:09 PM
    #53
    I get offended by people who get offended.:frusty:
  24. Nov 23, 2016 at 6:14 PM
    #54
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Is it more offensive to be offended or the offender, pretty confusing.
  25. Nov 23, 2016 at 6:18 PM
    #55
    I just got more offended. I think. I'll need another brewski to clear my mind.
  26. Nov 23, 2016 at 7:15 PM
    #56
    cdkenne
    Corey
    KS
    I don't recall the terminology but it was likely part of the online courses I took when I started.
    A lot of Toyota's core beliefs and sayings are in Japanese, so you'll have to excuse me if I don't recall them, or their translations.
  27. Nov 23, 2016 at 7:18 PM
    #57
    GmP. Sigma 6.
  28. Nov 23, 2016 at 7:54 PM
    #58
    Good Manufacturing Processes. ISO requirement. Especially if you want to be the best.
  29. Nov 23, 2016 at 7:59 PM
    #59
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good ol GMPs
  30. Nov 23, 2016 at 8:00 PM
    #60
    csuviper
    Broomfield, CO
    I posted a long list of my comparison between gauge and calculation over a 2 year period on another thread. Search MPG and you might find it.
    kritsana21 and gosolo like this.
