Truck Died on I-70.
Discussion in '2nd Gen Tundras (2007-2013)' started by Dag3, Apr 24, 2021.
  1. Apr 24, 2021 at 5:43 AM
    Dag3
    Dag3 [OP] New Member
    David
    Vail, Colorado
    2012 crew max limited
    Driving home from DIA with my family yesterday and realized my truck (2012 limited)suddenly had no power/stalled. Pulled on to the shoulder and shut it off. Check engine and battery light came on. After 10 minutes I started it up and it drove fine. Took it to the dealer to check it out and they said it stalled 4 more times. thoughts?
  2. Apr 24, 2021 at 5:48 AM
    18" TRD Off Road Wheels
    Fuel Pump?
    JohnLakeman, Danny3737 and Dag3[OP] like this.
  3. Apr 24, 2021 at 6:00 AM
    Dag3
    David
    Vail, Colorado
    That’s my guess, but I don’t know.
    GODZILLA[QUOTED] likes this.
  4. Apr 24, 2021 at 6:04 AM
    timsp8
    NY
    I assume dealer still has it? Did they tell you what the CEL code was?
  5. Apr 24, 2021 at 6:10 AM
    Dag3
    David
    Vail, Colorado
    Yeah, left it at the dealer. They said the code just showed “stalled”.
    We had to rent a car and then got stuck in a pile up at the tunnel for an hour and a half, great day.
  6. Apr 24, 2021 at 6:10 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Do the basics, fuse box? Relays? Fuel pump working? Spark,..ign wires, etc.
  7. Apr 24, 2021 at 6:11 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Well, that's helpful (sarcasm)
    Hope you get it sorted.
    SPP
    Dag3[QUOTED][OP] likes this.
  8. Apr 24, 2021 at 6:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Uhhhh........who know what code number = "stalled?"
    SMH.
    I might replace the battery. Would also want to know miles on truck to contemplate the alternator brushes.
    Dag3[OP] likes this.
  9. Apr 24, 2021 at 9:46 AM
    Dr_Al
    Dr_Al New Member
    Al
    Where I work we have codes for tools that make our products. We use them for things like "normal production" and "down for maintenance". The names have been in use for decades. One of them is "gone to lunch". "Stalled" seems like someone just put it in there with the idea that it would be replaced later in the software design process. If the dealer can't figure it out I would get a OBDII scanner that can display data. If the fuel pump is cutting out or the pressure regulator is dying then there should be data. The O2 sensors will pick up (but it could be too quick between starting to happen and engine dying to throw a code) a lean condition. If there's a fuel pressure sensor that'll pick it up. Just throwing parts at it will get expensive as it could be a number of things that could cause it to stall.
  10. Apr 24, 2021 at 9:50 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Ask them what the check engine code was, not the description, but the actual number. If they won't provide that to you, then you should consider whether they are qualified to even work on your vehicle.
  11. Apr 24, 2021 at 2:15 PM
    Eisenhower?
    Dag3[QUOTED][OP] and Black Wolf like this.
  12. Apr 24, 2021 at 2:18 PM
    I'm guessing yep. I heard that there was a multiple car pileup yesterday because of snow/ice near the tunnel. Spring time in CO!
    Booney and Dag3[OP] like this.
  13. Apr 24, 2021 at 2:21 PM
    Think it happened around an hour after us. There was some snow..slick roads
    Dag3[OP] and Black Wolf[QUOTED] like this.
  14. Apr 24, 2021 at 6:51 PM
    Dag3
    David
    Vail, Colorado
    Update.
    Got a call that they can’t find anything wrong with it and I can pick it up. Drive the 2 hours back to Denver and pick it up. Decided to drive East on 70 for a little to make sure it’s okay. 10 minutes down the road a same thing happens again. Truck dies on the pecos off ramp. Try to restart it and it cranks but won’t start. Let it sit for a few minutes and it starts. Drive it a couple hundred yards and it dies again. Repeated this process for an hour and half until I got it back to the dealer. Drove back in my rental Corolla again.
  15. Apr 24, 2021 at 7:04 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Uh...Bought any bad gas lately? Rare, but it can happen.
  16. Apr 24, 2021 at 7:10 PM
    I think it’s fuel related to some sort. Any new mods / work on it as of late?
    pnw tall trees likes this.
  17. Apr 24, 2021 at 7:45 PM
    Dag3
    David
    Vail, Colorado
    Nothing, it’s been parked at the airport for the last week. It has 145k miles and has never given me a problem.
  18. Apr 24, 2021 at 7:48 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    If it runs fine when it does run, I’m guessing it’s electrical.
  19. Apr 24, 2021 at 7:51 PM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    Parked at DIA?! I don’t know about you but my truck has a locking after market gas cap. Like others have indicated it could be a fuel issue. Hopefully your fuel wasn’t tampered with since I know these tundras don’t have locking gas caps.
    TheBeast likes this.
  20. Apr 24, 2021 at 8:22 PM
    Dia did have a rabbit issue a few years back. Fucked up a LOT of vehicles
  21. Apr 24, 2021 at 9:22 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    There was a pileup in the tunnel so they diverted to Hwy 6 which still had snow on it and then there was an accident on 6 and that got all clogged up. I-70 is evil.
  22. Apr 24, 2021 at 9:24 PM
    Booney
    Booney New Member
    Might be fuel starvation like from a bad fuel filter or line that is not quite fully clogged.
  23. Apr 24, 2021 at 9:29 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Is it sputtering to a stall or instantly cutout like someone shutoff the ignition?
  24. Apr 24, 2021 at 9:49 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Timing can do that, fuel pumps have a way of doing that, as do loose connections. Coil packs will do that when they get hot sometimes but usually you’ll get a misfire instead of a stall. Also, bad gas will do that as well. I would want to know what the fuel pressure is when it stalls out.
    Are the dash lights still on and bright when it dies?
    I can tell you that my GMC used to do this on the regular, from New. It turned out to be battery cables rotting from the inside out and causing a random bad ground scenario. It had all kinds of fun electrical problems related to that issue.
    Mwray8909 likes this.
  25. Apr 24, 2021 at 10:33 PM
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
    I too would be suspicious of a fuel system issue. Bad gas, water, condensation, fuel pump, clogged fuel line. But the intermittent/recurring aspect is weird.
    The other bothersome aspect of your experience is that it really sounds like the dealership has been either incompetent or disinterested in solving your issue. Totally unacceptable. My understanding is that the Toyota corporation keeps tabs on dealership service and will follow through if one of its dealerships is half-assing it. A stalling vehicle is absolutely a big safety issue and there’s no excuse for a DEALERSHIP to be mailing it in. That’s BS.
    I wish you luck and hope it gets solved pronto.
    Dag3[OP] and AircareTundra like this.
  26. Apr 25, 2021 at 4:28 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I upgraded my fuel pump with an aeromotive pump, when I bypassed the internal fuel filter and drained it all kinds of nasty stuff came out, I'm thinking either the pump is going bad or the internal filter is clogged. I wouldn't rule out electrical issues though.
    JohnLakeman likes this.
  27. Apr 25, 2021 at 9:14 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    It only stalls while driving it right? What are the odds you’re grounding out the pump when you hit a bump? Maybe, due to a loose wire or a wire that might be rubbing through to a metal component? I have had that happen before with an aeromotive pump until I cleaned up someone else’s wiring job.
    T-Rex266 likes this.
  28. Apr 25, 2021 at 10:51 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I had a 1977 Fiat 131 that died on me occasionally for no obvious reason. It took me about 2 months to find the issue, it was a bad set of points (points, what are they???). I carried a multi meter with me and took various measurements every time it died and finally found the problem. Points - boy, do I feel old!
  29. Apr 25, 2021 at 5:50 PM
    Dag3
    David
    Vail, Colorado
    It just dies while driving it or if I stop at a light it will slowly sputter out and die. Also if I try to restart it immediately, it will crank for awhile but not turn over. After sitting for a few minutes it will fire right up.
  30. Apr 25, 2021 at 5:51 PM
    Dag3
    David
    Vail, Colorado
    Yeah, they told me they “spent a few hours on it and couldn’t reproduce the problem” ten minutes after driving away I could.
    ZappBrannigan and bleach like this.
