Truck bed shaking
Discussion in '3rd Gen Tundras (2022+)' started by Mattster74, Mar 17, 2022.
  1. Aug 11, 2022 at 7:06 PM
    pauls22trdpro
    pauls22trdpro 2022 trdpro tundra
    2022 lunar rock tundra trd pro
    My 2022trd pro does it and from what I seen I believe it’s the rear tailgate…if u drop it down on the passenger this hinge has sooo much wiggle room and that seems to be the bouncing on the rear tailgate passenger side…I had my dad on the back seat with the rear window down and I was driving on bouncy roads and he was watching that corner of the bed on passenger side bounce around and making that noise
  2. Sep 7, 2022 at 12:52 AM
    Tundra@Guam
    Tundra@Guam New Member
    2022 SR5 Tundra CrewMax
    Thanks for your comment. After taking my truck back to the dealer for the annoying rattling for the 3rd time, they tell me they are ordering a new tailgate. They did say the problem is with the hinge. I do hope that's the solution.
    I still feel something has to be done with the suspension. There is so much bounce in the bed area.
  3. Sep 7, 2022 at 5:05 AM
    outlaw.taco
    outlaw.taco New Member
    Houston
    OP
    When you quote
    [ QUOTE="Mattster74, post: 2689105, member: 75968"]Ok, I'm already in the market for a leveling kit just a 1.75 up front.and I'm thinking about a spray on bed liner and bed cover. So maybe that will help.[/ QUOTE]
    “Insert Comments“
    then hit Post Reply
    15whtrd likes this.
  4. Sep 7, 2022 at 10:54 AM
    pauls22trdpro
    U hear it more with the rear window down…and also when u go over bumps bumpy roads and potholes …also 2 guys from Toyota came to my dealership to look at my truck and reported it to Toyota of North America….so eventually this will be a recall/bulletin on it…
    And also my dealership gave me a loaner 2022 tundra sr5 and did the exact same thing so I knew rite off the bat it’s a Toyota Tundra issue for the 2022 models…
  5. Sep 9, 2022 at 5:19 PM
    Northern1
    Northern1 New Member
    Travis
    2022 Red 1794
    I’ve noticed that my bed is bouncing and rattling as I drive down my dirt road. It appeared to be moving quite a bit looking at it in my mirrors. I thought that it looked like the entire thing and not just the tailgate.
  6. Sep 10, 2022 at 5:02 AM
    pauls22trdpro
    Yes it make loud noises when u go over bumps bumpy roads this is a Toyota issue they already reported my issue to Toyota of North America so eventually will be a recall/bulletin once they fig they issue to resolve it ….also my dealership gave me a 2022 sr5 tundra with 500 miles on it as a service loaner and it did the exact same thing…so rite from there I knew this is a tundra issue not just my 2022 tundra trd pro
  7. Sep 10, 2022 at 5:13 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I was just thinking if the whole bed is flopping around because the frame is flexy like the 2nd gens, and if the new Sequoia shares the same frame design, how is its cab going to hold up over time if the frame underneath it is flexing like crazy?
  8. Sep 10, 2022 at 5:54 AM
    pauls22trdpro
    Rite I think also cause it’s a composite aluminum bed so there is a lot of flexibility…now if it was steel then I don’t this would happen ..,yes we all know steel will rot out and composite aluminum won’t so u can’t win I guess ‍♂️
  9. Sep 10, 2022 at 7:12 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Stupid question but how do you tighten the bed bolts. Do you do it from under the truck?
    Kagisexton likes this.
  10. Sep 10, 2022 at 9:36 AM
    outlaw.taco
    Houston
    If you have to ask, leave it to the professional.
  11. Sep 10, 2022 at 9:39 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    I know there are the hex bolts in the bed floor but didn’t know if they tap in or if there are nuts under the bed. Just asking thanks
  12. Sep 10, 2022 at 11:12 AM
    pauls22trdpro
    U just retorque them from the top of the bed …your tailgate also moves around a lot if u have it on a 45 degree from the passenger side I had to put rubber garments ….cause it’s so lose but I did a lot of stuff to try to eliminate noises it’s a little better but still does the noises …there will be a recall or bulletin on it once the engineers figure out the solution to fix it ….this is an tundra issue on a lot of most tundras for sure ….but like I said b4 I think it has a lot to do with aluminum composite bed ….the dealership did tighten my hex bolts but still does it ….
  13. Sep 10, 2022 at 11:22 AM
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    My truck is currently at the dealer for the tailgate rattle/loose they said the rubber on the hinges are crushed and order new ones he said Toyota knows about this issue.
    Also at the same time they looking at an oil leak between the engine and the hybrid motor so my truck is down for god knows how long they open a case with Toyota and apparently Toyota is sending techs to look at my truck.
  14. Sep 10, 2022 at 11:28 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited *sold*
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    It's just the 3rd gen of the tundra twerk, it's fine lmao
  15. Sep 10, 2022 at 2:52 PM
    porterbc
    porterbc New Member
    Brandon
    2022 Tundra Crewmax Limited TRD OFF-ROAD
    Open the tailgate, loosen bolts on the u-shaped posts that the tailgate latches too and slide them forward about 1/8”-1/4” on both side.. did mine the other day. Made huge improvement, took about 90% of the racket away except for the big bumps.. and didn’t make it any harder to open or close
    AND, 15whtrd, batman900 and 1 other person like this.
  16. Sep 10, 2022 at 3:59 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    Thank you Paul22. That’s all I was asking :)
  17. Sep 11, 2022 at 2:03 PM
    TTund16
    TTund16 New Member
    didn't know bed was alum!
    I recall Chevy commercials dropping rocks or a tool box on to the bed of a Ford and ripping a hole and I think Ford changed the design after that ...
    Most likely Toyota composite is stronger.
  18. Sep 11, 2022 at 2:32 PM
    porterbc
    porterbc New Member
    Brandon
    Just the painted side panels are aluminum.. the rest is composite. Haven’t had any issues with my taco composite bed and as per the engineering Dept, these tundras are supposed to be stronger. Rust free in Atlantic Canada is a win in my books by far, beside who in there right mind just launches heavy steel items in the bed with no regard for damaging something except for employees with a company truck they didn’t pay for.. :rofl:
    TTund16[QUOTED] likes this.
  19. Sep 11, 2022 at 2:38 PM
    #49
    BaldMenace
    BaldMenace New Member
    2022 Tundra SR5 Double cab
    I noticed a bouncing sensation in the rear when going over speed bumps. I'm guessing it's the bed shake you guys are talking about. My truck is a DC TRD OffRoad
  20. Sep 11, 2022 at 2:41 PM
    #50
    porterbc
    porterbc New Member
    Brandon
    Everything back there has to flex and move a little other wise you’ll have stress fractures all over the place…
  21. Sep 14, 2022 at 1:34 PM
    #51
    the4rdan
    the4rdan New Member
    Pennsylvania
    2025 WCP Ltd. TRD OR CrewMax
    Have you had the replacement rubber/bushing on the hinges replaced yet? Curious your observations; think I've observed the same.
  22. Sep 14, 2022 at 1:43 PM
    #52
    Tundrafarm
    my truck still at the dealership (for the oil leak issue) and according to my service rep the bushings on the tailgate were replaced and fixed the issue, I have not seen the truck yet so I’ll report back on this once I get the truck back.
    Troyboy84 and the4rdan[QUOTED] like this.
  23. Sep 21, 2022 at 2:38 PM
    #53
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    This has come up a couple of times now with others experiencing what you describe. If you can get a video I'm sure it would help people move forward.
    TopTierToyo likes this.
  24. Sep 21, 2022 at 2:43 PM
    #54
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
  25. Sep 22, 2022 at 10:56 AM
    #55
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    My bed defiantly rattles a bit. The loud banging, I get is from the tailgate, passenger side. You can lift up on the gate and feel the gap in the hinge. When I took it in for its first service I had them take a look at it. They said it was normal. I asked to speak to the GM and showed him the gap in the hinge and a video I had taken. We walked the dealership and found 3 of the 4 Tundra's on the lot did the same thing. He called me a week later and said Toyota is aware of the issue and is now making a new hinge set for the tailgate. He is waiting for the part number so they can order it. Was told they should have the parts in a week or so. Good News!
    Troyboy84 likes this.
  26. Oct 5, 2022 at 3:10 AM
    #56
    the4rdan
    the4rdan New Member
    Pennsylvania
    Circling back to see if you've gotten any update on the new hinge set for the tailgate?
  27. Oct 5, 2022 at 2:20 PM
    #57
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    Left a message with the service manager. I'll let you know when he calls back...................Our labs could be related
  28. Jan 24, 2023 at 4:37 PM
    #58
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    Finally got the rattle fixed. Took 4 months for the parts. Both hinges replaced with upgraded parts.
    AND likes this.
  29. Jan 24, 2023 at 4:40 PM
    #59
    AND
    AND New Member
    Washington, PNW
    What upgraded parts are we talking about? is there a part number?
    I have taken mine in several times for them to joy ride and they always say its normal.
    the4rdan likes this.
  30. Jan 24, 2023 at 6:00 PM
    #60
    Ruger19
    Ruger19 New Member
    Bill
    2022 Tundra
    No, it's not normal. The first time I took it in for the rattle/banging, the service guy blew me off and said it was the same as other new Tundra's on the lot. Told him it was bullshit and asked for the head of the service department. I walked the lot with the boss and checked 3 other trucks, 2 of them had the same issue, 1 did not. He said he would get back to me. A few weeks later he said that Toyota is aware of it and is working on getting the upgraded hinges. Took 4 months of waiting but it is done and does not rattle/bang every time you hit a small bump. Here is the part number.
    1TBvSVf2Ff-pKLMT1_6DauCboRrMvaZxLnNwgiQw_b6b7232d1359ef0558ba4af13c2ad371bd4d24ab.jpg
