Troubleshooting a P2441 code on my 2013 tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by SanAntonioKid12, Nov 17, 2020.
  1. Nov 17, 2020 at 5:10 PM
    SanAntonioKid12
    SanAntonioKid12 [OP] New Member
    Andres
    2013 White Tundra Texas Edition
    Tyger Bull bar
    I had my Check Engine and Trac Off indicators come on while driving. I took it to autozone to get a quick diagnostic check. The code that came up was P2441 which means my Secondary Air Injection system is messing up on me. I did. Little research on this, and found out that tundras and sequoias have had this problem for a while. Toyota extended warranty for AIP for only certain years from 2008-2010. I really don’t want to pay over $2000 to have it fixed. I have read about a bypass that’s available for this. Has anyone used the Hewitt bypass for a 2013 tundra before? Would appreciate feedback. Thanks
  2. Nov 17, 2020 at 5:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Did you double check with a dealer that they didn’t extend the warranty to the ‘13 as well? I thought they extended all the gen 2’s but could be wrong.
    as for the Hewitt setup - a coworker did it on his 2008 and it’s been working fine. I know the blank-off plate install was a bitch, but a lot less than paying to having the work done to replace everything.
  3. Nov 17, 2020 at 5:45 PM
    SanAntonioKid12
    Andres
    Tyger Bull bar
    I’m taking it to the dealer tomorrow. I was on the phone with A so called Toyota “Brand Ambassador“ for about an hour asking about why the warranty doesn’t extend to anything after 2010s, and she kept on saying that not enough people have reported the problem
    once I know exactly what it is tomorrow, I’m gonna see about getting the bypass. Thanks for the response
  4. Nov 17, 2020 at 7:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Don’t be afraid to call corporate and push on them as well
  5. Nov 18, 2020 at 5:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Someone on here just cleaned them as preventative with like $60 DIY parts from Oreillys... His has been fine, I've yet to do the same, but if it came down to it I'd do that first.... I would suggest you try that first, if it doesn't work you can always bypass it if your county allows that...
  6. Nov 18, 2020 at 10:20 PM
    FWD Tundra
    FWD Tundra New Member
    Washington
    2013 Tundra 4WD Double Cab
    Do you have the link for the cleaning?
  7. Nov 19, 2020 at 5:23 AM
    blackdemon_tt
  8. Nov 21, 2020 at 5:14 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    @SanAntonioKid12 just a couple weeks ago I bypassed mine for $20 based on another thread here somewhere... will try and find it and add link.
  9. Nov 21, 2020 at 5:21 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    I’ve had the Hewitt on my 07 for almost 3 yrs passed 3 inspections no problems
    This is very common and costly issue I say do the bypass and be done with it
  10. Nov 21, 2020 at 5:40 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    @SanAntonioKid12 if you don’t have luck at the dealer and don’t want to spend $600 you can find the instructions on post #24 here to fix for $20-30... https://www.tundras.com/threads/aip-bypass-help.26552/ thanks to @koditten for sharing these instructions. I think they are based on threads from the TundraSolutions forum.
    I am planning to do a write up on what I did which is a little different than these instructions.
    Also, I did not install a block off plate and so far so good. Rather than a block off plate couldn’t one just plug the air tubes (who cares about the valves if they are bad and unused anyway?
  11. Dec 2, 2020 at 5:38 PM
    nu2tundra
    nu2tundra New Member
    Oscar
    2010 SR5
    I had the same issue with my SR5 4.6. Installed the Hewitt bypass module, with block off plates. The passenger side was the real pain for me. Doesn't help being only 5'5" and only using a regular ladder to work in the engine bay. I've since bought some Gorilla platforms from HD.
