Secondary Air Injection Pump failure
Discussion in '2nd Gen Tundras (2007-2013)' started by jtx0741, Feb 27, 2019.
  1. Feb 19, 2020 at 8:21 AM
    #91
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    The bypass was life saver for me. The stealership wanted $1600 to fix the aip and my go to shop wanted $1200. I thought I only paid $200 for the bypass kit but I could be mistaken
    RyanTundra12[QUOTED] likes this.
  2. Feb 19, 2020 at 9:08 AM
    #92
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    How does that answer my question when you’ve previously stated “how is anyone supposed to answer that question?” Always one of you on every forum.
    RyanTundra12 likes this.
  3. Feb 19, 2020 at 9:16 AM
    #93
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Always one of you too.
    Googling aip failures will enable you to educate yourself about the system and get a general idea of how they fail
    It will also connect you with people who have had this failure and you can ask them questions about it
    There is plenty of information out there on this topic. But asking us "What is the likelihood of the AIP system failing?" no one can answer that question. You will just have to decide for yourself how likely it is. One way you can help yourself to make that decision is to GOOGLE
  4. Feb 19, 2020 at 9:21 AM
    #94
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    If your pumps are working when the bypass is installed there is no need to install the blockoff plates. The blockoff plates are only required if the pump has already failed stuck open and not repaired. Given that yours was just repaired, it's a great time to plug and play the bypass, ignore the blockoffs, and never worry about this issue again. There are other cheaper options to save some dough if $400 is the only downside, I run slyfox homemade system for under $50 on my 07 with no blockoffs, buddies 4.7 with no blockoffs, and my old 07 4runner 4.7 with blockoffs only because I had the headers off, same idea as the $15 relay people are talking about above.
  5. Feb 19, 2020 at 10:28 AM
    #95
    RyanTundra12
    RyanTundra12 New Member
    Ryan
    2012 Tundra DC 4x4 4.6
    Thank you Leo, I was looking for an answer like that. As far as Focal’s question, I think he’s wondering the same thing as I am, if we bypass the system and the SAIS is unused for a period of time, if we then want to return the vehicle to stock and remove the bypass for one reason or another, can the system have failed while it was bypassed and now we are stuck needing a repair anyway?
    Leo's first and focal like this.
  6. Feb 21, 2020 at 5:43 AM
    #96
    tonyh1307
    tonyh1307 New Member
    tony
    2007 Tundra 5.7 SR5 DCab
    I dont mean to post this as an "end all to beat all" solution but I had this issue on my 2007. Code P2442. Read all the threads and saw where the real solution is $2500 or more and a bypass hit was about $200. Didn't have the cash lying around for the real deal repair but I had this little code reader by Veepeak so I reset the codes and the truck ran fine till the next day when the codes returned and limp mode started back up. So I reset the codes again, several times over the next day or two. That was close to two weeks ago and the codes have not returned. No idea how long it will last but for $20 for a code reader that you need on hand anyway it is worth a try.
  7. Feb 21, 2020 at 3:14 PM
    #97
    RyanTundra12
    Ryan
    The first time I reset the code I got six weeks out of it, then a week, then a couple days and then everyday. I think once it throws a code it’s only a matter of time.
    tonyh1307 likes this.
  8. Feb 29, 2020 at 2:18 PM
    #98
    RyanTundra12
    Ryan
    Quick update for anyone interested. I ordered and received my Gen 2 bypass kit this week and installed it today. Overall it wasn’t too difficult, but the instructions and diagrams show a Lexus install which is different from a Tundra. Some vehicle specific instructions or added notes would cut down on the second guessing for some. Like one of the first steps
    Is to remove the AIP control/driver. Well the diagram shows one driver with two plugs. My truck has two drivers and four plugs. Which one do I remove? Well both of them is the answer and replace them with the single unit in the kit. But that isn’t explained, I just had to second guess myself, google it and find nothing, continue with the install and hope for the best.
    The block off plates have been left for another day. I attempted to install and was surprised at how easy the bolts came off, but man those stainless steel pipes are rigid and do not have much give even with the bracket removed. I almost had one in but the bolt seemed to be going in at a bad angle. I was loosing daylight and my hands were going numb from the cold so I decided to abort mission since my system is actually working fine at the moment and this is a pre emotive strike.
    At one time in life I was an entry level mechanic and always a back yard extraordinaire lol. Maybe my skills have dropped off, but I’ll get those plates in someday when the weather is warmer, even though it seems I don’t need them. Hopefully this is it for me with this ridiculous issue. Thanks to everyone who chimed in.
  9. Feb 29, 2020 at 2:24 PM
    #99
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I think you got the wrong set of instructions mine were spot on
    In any case, on the block plates, I attached a ratchet strap to the tube and that made it a lot easier to separate it just enough to slip the plate in
    But I have jba headers, I don't remember what the oem headers look like for the block off plate
  10. Feb 29, 2020 at 2:33 PM
    #100
    RyanTundra12
    Ryan
    If yours were spot on then mine were definitely wrong. They actually showed a Lexus engine cover in mine. Judging by the method you used for the block offs I’m guessing you have a 5.7 motor. Mine is the 4.6 which might explain the different instructions. On the 4.6 the block offs are both above the valve covers, right at the Air Injector Valves.
    osidepunker likes this.
  11. Mar 2, 2020 at 4:54 AM
    #101
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Fired up the Truck yesterday. No codes and no sucking sounds from the pumps haha
    @hewitttech kit works great :thumbsup:
  12. Mar 2, 2020 at 5:01 AM
    #102
    RyanTundra12
    Ryan
    I noticed this morning no sucking sound from the pumps. First time the truck has been that quiet on a cold startup. It was noticeable
    Leo's first, focal and osidepunker like this.
  13. Mar 16, 2020 at 10:24 AM
    #103
    wmcran
    wmcran New Member
    I'm reaching out to the community for help in Northern New Jersey. I have a 2008 Sequoia with 99,700 miles that has the SAIS problem that started two weeks ago. This truck has been good to me and since I'm a big guy, it fits me well. I'm kind of lucky (so far) that my code is P2443, valve stuck closed but that can change. I got the Hewitt kit and the built quality is nice.
    My problem is that I'm somewhat disable and can't put the kit in. I'm not capable of getting back behind the intake manifold or bend to do the plates. I have been to 12 different garages, called 4-wheel places, etc. and no one will do it.
    I'm asking if anyone knows of someone who can help me with this. I'm not looking for charity and am willing and happy to pay for your or anyones time.
    Thanks in advance.
  14. Mar 16, 2020 at 10:33 AM
    #104
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Those connectors are a real PITA haha
    I would do it for you but I live in SoCal. I'm sure there is someone on this site close to you who would be willing to help out.
    I would suggest calling small independent mechanics that are familiar with Toyotas. A small shop might be willing to help
    wmcran[QUOTED] likes this.
  15. Mar 16, 2020 at 10:37 AM
    #105
    wmcran
    wmcran New Member
    Thanks osidepunker, I appreciate the gesture.
  16. Mar 22, 2020 at 7:44 AM
    #106
    007CamperHauler
    007CamperHauler New Member
    Buddy
    2007 Tundra SR5 TRD DBL CAB 4.7
    JTX,
    I bought my tundra in limp mode because of the same issue you’re having. I bought the kit from Hewitt Tech and have been driving the truck for 2 years with ZERO issues and no more codes or check engine light! I highly recommend their bypass kit!
  17. Apr 28, 2020 at 9:45 AM
    #107
    wutevs
    wutevs New Member
    Eric
    2012 Tundra SR-work package DBL cab 4.6l
    Fuzzy dice.
    I did the trumpet delete mod. Added about 13 ponies off the line. You can really feel the .8oz weight savings.
    P0TA8plxSnpiJc66fy-p2BopXoFmzNRBd6Hr_UiU_8915cc84e8354d9cdd1a9e44e4eb8c2ff671a536.jpg
  18. Jun 4, 2020 at 2:13 PM
    #108
    hammockking
    hammockking New Member
    Scotts Valley, Ca
    2012 Tundra Platinum 4x4
    Workin' on em
    How long have you been running it this way?
  19. Jun 4, 2020 at 2:51 PM
    #109
    wutevs
    wutevs New Member
    Eric
    Fuzzy dice.
    Since early April, 2020. My problem was bank 2 valve stuck open. Thanks to this forum and others, I got a general idea of the problem (crappy air filter leads to corrosion and/or gunk in valve). So I started with the air pumps. They weren't throwing codes, but they were nasty looking. In the picture, you can see the red/brown filter gunk and a chipped impeller tooth.
    n8_qs8I95Shy4yLmEI6h3t4qbNd5Klvg9ugdveul_59720b000e71c52a5d14fef7b9b37595495defc0.jpg
    So, knowing that my pumps' filter had disintegrated, I jerry rigged a breather filter from OreillyZone. Pump issue resolved (I hope).
    Then the valve. See below.
    CSE6gAu9xVy_ErTU98Oha1qq7CjOyT4zy48aIgHG_05769148898cdffc5c67d1dbdfc1da313dc0bd60.jpg
    I didn't do the bypass kit. I replaced the valve. One of the local Oreillyzones had it in stock.
    Cleared the codes and been problem free ever since. Knock on wood.
    rons23 and Black Wolf like this.
  20. Jun 4, 2020 at 3:18 PM
    #110
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Nice, may look into doing something like this for upkeep... I haven't seen this issue, knock on wood, and I've done some off the wall stuff, like splashing through large puddles, and mudding (3cm of standing water on dirt LOL).. can't hurt to clean it out and do preventative maintenance... mind sharing the valve part number from Oreilly's??
    Black Wolf likes this.
  21. Jun 4, 2020 at 3:24 PM
    #111
    I like your ingenuity. I bought a new SDHQ relocation kit from @T-Rex266 for a sweet price. My AIP's were still good. The SDHQ kit does pretty much what you did but the kit comes with adapters and aircraft grade hoses with little K&N's that get routed up into the engine bay and attached behind the washer fluid tank. Much quieter when relocated inside the engine bay...
    porkitt, Wallygator and T-Rex266 like this.
  22. Jun 4, 2020 at 3:34 PM
    #112
    There used to be a YouTube vid where a guy took his AIP's apart. Strangely enough it's usually only one pump that gets fouled. Forget which one. Yep...sometimes a good cleaning can restore the pumps to working condition. That's my plan if that issue ever comes up. Don't really expect it to. Knock on wood...
    blackdemon_tt likes this.
  23. Jun 4, 2020 at 3:38 PM
    #113
    blackdemon_tt
    makes 2
  24. Jun 4, 2020 at 3:41 PM
    #114
    Wallygator
    This kit is not on their website. At least I couldn't find it. Maybe it's under a different model than the Tundra? Has it been discontinued for some reason?
  25. Jun 4, 2020 at 3:44 PM
    #115
    I would call them. If you Google SDHQ Tundra AIP Relocation kit it comes up with a link to where it's located on their website. Weird....
    Wallygator[QUOTED] likes this.
  26. Jun 4, 2020 at 3:54 PM
    #116
    blackdemon_tt
  27. Jun 4, 2020 at 3:55 PM
    #117
    Wallygator
  28. Jun 4, 2020 at 4:16 PM
    #118
    It's a pricey kit but made of high quality materials and keeps you legal for those that worry about that. Some states are pretty strict about modifying emission systems and the fine can be yuge. Colorado isn't too bad now, but we will be adhering to Kali's emissions soon enough. Playing it safe and glad I did it.
    Edit......waiting for clarification on the "legal" definition from SDHQ. I'm not concerned at all here in CO but Kali for example is quite strict when it comes to emission systems. It comes down to what "modification" is.......this particular kit doesn't affect the AIP system function per se since it only relocates the two pump's air intakes into the engine bay with air filters and "should" improve longevity of the AIP system, especially when the pump's original air intake location is highly susceptible when exposed to severe humidity, or offroading in wet conditions, etc. It certainly doesn't degrade the system. To me....a flaw that needed to be corrected by Toyota.
  29. Jun 4, 2020 at 4:18 PM
    #119
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Its not legal in a state like CA. Modifying any component of an emission system with a part that is not CARB approved renders the whole system not legal
  30. Jun 4, 2020 at 4:21 PM
    #120
    That's why it's best to call SDHQ to see if the kit is compliant with your state. A total bypass kit fooling the ECM would definitely fail in most states if caught.
