Trouble pumping gas, Help!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra174x4, Mar 13, 2020.
  1. Mar 13, 2020 at 4:08 PM
    Tundra174x4
    Tundra174x4 [OP] New Member
    Cody
    2017 tundra sr5 trd off-road 4x4
    I have a 2017 crew max 5.7. The last few times I have tried to pump gas I can only pump like 10 cents before it stops!! Anyone have this issue? I have went to multiple gas stations so it’s not the pump.
  2. Mar 13, 2020 at 4:21 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
  3. Mar 13, 2020 at 4:36 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Tow it to the dealer. Let them fix it. Should be under warranty no?
  4. Mar 13, 2020 at 4:39 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
  5. Mar 13, 2020 at 5:25 PM
    ZPMAN
    Minnesota
    Do you have children?
  6. Mar 13, 2020 at 5:34 PM
    Tundra174x4
    Cody
    Yea still under warranty, hope I don’t get the run around
  7. Mar 13, 2020 at 5:34 PM
    Tundra174x4
    Cody
    Yes lol
  8. Mar 13, 2020 at 5:35 PM
    Tundra174x4
    Cody
  9. Mar 13, 2020 at 7:11 PM
    GNX6
    GNX6 New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    I found a tampon stuck wedged in the filler neck check ball once. (Chevy)
    1lowlife and Tundra174x4[OP] like this.
  10. Mar 13, 2020 at 7:51 PM
    Erp1986
    Erp1986 New Member
    Erik
    San Diego, Ca
    18 Tundra CM SR4 4x4
    Same thing happened in my 2018 crew max. The check valve on the filler neck gets stuck. In order to fix it the dealer swaps out the tank with fuel pump and filler neck. Should be covered under warranty.
    Trooper2 and Tundra174x4[OP] like this.
  11. Mar 13, 2020 at 8:23 PM
    Tundra174x4
    Cody
    I have an appointment tomorrow, I doubt they will fix it in one day though
  12. Mar 13, 2020 at 8:26 PM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    Insert your pump nosle upside down. Ie, have the bottom handle facing up. That should do trick. I use to have this issue lots with my Mustang Gt.
  13. Mar 13, 2020 at 9:01 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    OP - Aside from the known issue with the valve; Have you recently used any fuel additives?
    I ask bc I once had the little paper tab from the cap of a bottle of fuel additive fall out of the cap and float perfectly into the filler. Couldn’t do that again if I tried 10M times!! But I digress.
    I had to disassemble the filler hose from the tank. There’s a large mesh screen about 1-1/2” down in the tank inlet (that the filler-hose attaches to). Fortunately I was able to get it out.
  14. Mar 13, 2020 at 9:08 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Then they need to give you a loaner..
    Good luck..
  15. Mar 13, 2020 at 9:40 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    This will also happen if you are trying to fill up when your tank is SUPER LOW... especially when driving well after the “0 miles til empty.” This has happened to me before and I will usually stop pumping, turn the truck on for about 30 seconds, then fill up again.
  16. Mar 13, 2020 at 10:46 PM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    ^^^^^. This
    It’s a known issue. Pain in the effing A. Keeps happening to mine. Lasts about a week and then randomly goes away. I have to trickle in the gas.
  17. Mar 14, 2020 at 7:50 AM
    Tundra174x4
    Cody
    Never added anything besides normal fuel
  18. Mar 14, 2020 at 7:51 AM
    Tundra174x4
    Cody
    Yea I’m pretty upset, truck only has 30k miles and I’m dealing with this!?
  19. Mar 14, 2020 at 7:58 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    try twisting it gansta style???? to the side, sometimes this helps, but if its under warranty, then that works best.
  20. Mar 14, 2020 at 8:22 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I found a gas can lid and a lego in a filler tube before .
    ZPMAN and blackdemon_tt like this.
  21. Mar 14, 2020 at 9:57 AM
    ZPMAN
    Minnesota
    PeakIT[QUOTED] likes this.
  22. Mar 14, 2020 at 10:00 AM
    PeakIT
    PeakIT Old Member
    Utah
    ZPMAN[QUOTED] likes this.
  23. Mar 14, 2020 at 10:24 AM
    ZPMAN
    Minnesota
    I use them at work all the time ($300+) but would be nice to have one at home for $14 lol
  24. Mar 14, 2020 at 6:53 PM
    newguy
    newguy New Member
    I had 30,000 miles when it first happened too. BUT, I was one month over the warranty. Didn’t cover it of course.
  25. Mar 14, 2020 at 6:55 PM
    newguy
    newguy New Member
  26. Mar 15, 2020 at 12:07 AM
    ZPMAN
    Minnesota
    Will do, came out to $15 with shipping and will receive on the 26th.
  27. Mar 16, 2020 at 9:06 PM
    Tundra174x4
    Cody
    Update- they are installing new gas tank tomorrow and covered under warranty
    ZPMAN likes this.
