Trimming front bumper liner and mudflaps
Discussion in '2.5 Gen Tundras (2014-2021)' started by Netmonkey, Mar 13, 2020.
  1. Mar 13, 2020 at 4:42 PM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    So, in preparation for an upcoming lift and larger tires, I decided to trim the front bumper liner. I searched this forum and found 2 threads about others who have done this:
    https://www.tundras.com/threads/where-do-i-trim-this.11691/
    https://www.tundras.com/threads/trimming-fender-liner.23406/
    What I found when I attempted this is that my liner was different than in most of the pics in those 2 threads (literally a different mold. I couldn't exactly match where to cut). I think it has to do with the plastic end caps vs the metal end caps. Also, the clearances are different between the 2 end caps.
    So, here is how I went about it.
    With the old tires (295 55 20), I had about 3 inches of clearance to the liner:
    Here is what the liner looks like before trimming:
    Removing the liner is is easy once you figure out the trick. Removing all the screws is easy, but it took me 20 minutes to figure out how to get past these damn clips. Apparently, the clips on the metal bumpers is different than on the plastic bumpers. For these, there is an insert in the clip that recesses into the hole on the end cap. You have to pry the clip up to release the insert. So, release the top clip, rotate the opposite end of the liner down, release the bottom clip, then rotate the opposite end down again. Then the liner just pops right out:
    I took the minimalist approach with trimming and started by drilling 2 holes for where the screws would go through:
    I went back and forth with placing the liner on the truck, drawing out a cut line, trimming, and then repeating. Here is my first cut line:
    After all the cuts have been made:
    Liner back on the bumper:
    Here is the liner back in place and all bolted up:
    I gained about an inch of clearance. At about 4 inches of clearance now:
    About 2 inches of clearance at full lock:
    I also removed the mud flap and there is a ton of clearance for the new tires:
    After i got the new tires on, I was able to trim out a portion of the mud flap to accommodate them:
    Here is the mud flap on with the new tires:
    Thanks for looking :)
  2. May 16, 2020 at 2:11 PM
    BamaMan44
    BamaMan44 Roll Tide Roll! Bama Fan till I die! & Go 'Hawks!
    Andre
    Tucson
    Trailbreaker - 2017 Black CrewMax SR5 4x4
    Thanks for this thread! I just used it to trim mine.
  3. May 17, 2020 at 7:05 PM
    guzcruz7
    guzcruz7 New Member
    2020 Tundra Platinum
    Thanks for the shared info, very useful, I was just about to consider the body mount chop on my truck and now that I see this posts, that’s definitely out of the pictures. Do the treads/posts delete? Or can I just save this link?
    last question, what size tires are you running now? What size suspension? Etc
    Netmonkey[OP] likes this.
  4. May 17, 2020 at 8:27 PM
    Netmonkey
    Georgetown, TX
    You can save the link or subscribe to the post.
    I have 295/60/20’s with a 3.5” lift.
  5. Jul 3, 2020 at 10:53 PM
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Thanks so much for this! My next weekend project for sure. May I ask what tool did you use to do the trimming?
    Netmonkey[QUOTED][OP] likes this.
  6. Jul 4, 2020 at 5:45 AM
    Netmonkey
    Georgetown, TX
    I used tin snips for the large cuts and I used a sharp utility knife for the rounded cuts and for smoothing out all the cuts.
  7. Jul 17, 2020 at 4:03 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I just wanted to say thanks for the great write up with pictures! I took advantage of the cooler temperatures this morning and trimmed my fenders and mud flaps. The fenders came out great but got a little carried away on the passenger mud flap, oh well I’ll find a replacement.
    Just wanted to let you know this was a God send, I put new 275/70/18 over a month ago on my 15 Tundra and was getting the slightest rub turning when going over bumps or breaking. I was so bummed with the rubbing, besides being sick with the rona:( I’ve been sick 27 days and counting.
    Just having to worry about rubbing was driving me nuts and this fixed the issue and saved my sanity giving me little me time outside was great!!!!
    An easy project sure helped the spirits!!!
  8. Jul 17, 2020 at 8:06 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    Did you Trim your skid plate?
  9. Jul 17, 2020 at 8:10 PM
    kittyhawk
    Dave
    Nope, I didn’t think of it. what pard do I need to look at?
    I’ll take a look tomorrow morning. thanks for the heads up.
  10. Jul 17, 2020 at 8:23 PM
    PeakIT
    PeakIT Old Member
    Utah
    The edge will have tire marks on it and make a loud noise locked thru any decent sized driveway dip. People bend the edge of them with a big crescent wrench about 1” or .5” up
    this one isnt mine. I need to do mine. You can also cut them off with a cutoffwheel .
    kittyhawk[QUOTED] likes this.
  11. Jul 17, 2020 at 8:35 PM
    kittyhawk
    Dave
    Thanks, I’ll look at it. that’s an easy fix.
