Trimming for clearance questions
Discussion in 'Wheels & Tires' started by Krautman73, Jan 6, 2019.
  1. Jan 6, 2019 at 7:10 AM
    Krautman73
    Krautman73 [OP] New Member
    Austin, Tx
    2018 SR5 Crewmax TSS
    6" Maxtrac suspension lift 20x10 KMC XD Buck 25s with -24 offset 35x12.5x20 BFG KO2s Cherry Bomb Extreme muffler 2/1 Stubby antenna
    Hey folks,
    I experienced some major rubbing after throwing on my new rims and tires. I found some info regarding pushing the bumper forward utilizing washers, but with my -24 negative offset, a half inch wouldn't be enough. After spending the day with the cut off wheel and Dremel, there's no more rub, but I'm now concerned about a few things...
    I deleted the front portion of the wheel well liner for now, and taped over where the fog lights are, (ghetto I know), but I know that's not going to cut it long term. For the rear, I had to trim the rounded off portion, (not sure what the name of that part is), but not sure if I'll need to weld something to cover up the hole? Thanks in advance for your help...
    Alexstundra likes this.
  2. Jan 6, 2019 at 7:14 AM
    As far as your cab Mount I would buy the Cab Mount chop kit. It's a plate that weld's over your cab Mount after you cut it to seal it back off
  3. Jan 6, 2019 at 7:15 AM
  4. Jan 6, 2019 at 7:16 AM
  5. Jan 6, 2019 at 7:24 AM
    TheBeast The Beach
    you could probably put your fog cover back on. trimmed and pushed forward. it will do a better job than the tape there.
    I cut mine and pushed it forward, it's held with zip ties. Does the job.
    CMC on rear with plates
    Prostar 190 likes this.
  6. Jan 6, 2019 at 7:26 AM
    TheBeast The Beach
    what are the specs on the new tires?
  7. Jan 6, 2019 at 7:27 AM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I did the same trimming as you in front fender liner. So far haven’t had any issues with my fog lights being exposed. I don’t like it though so I’ll be getting an aftermarket bumper.
  8. Jan 6, 2019 at 7:37 AM
    You pretty much have done a quasi cab mount chop but you should actually not leave that mount exposed and get some CMC plates from Relentless Off Road and finishing it. Getting a decent aftermarket front bumper will solve the fender liner issue. You won't have any. :thumbsup:
    Krautman73[OP] and Prostar 190 like this.
  9. Jan 6, 2019 at 8:20 AM
    Krautman73
    Austin, Tx
  10. Jan 6, 2019 at 8:21 AM
    Krautman73
    Austin, Tx
    Thanks bro, that setup looks nice. The tires are 35x12.5x20
    TheBeast[QUOTED] and Prostar 190 like this.
  11. Jan 6, 2019 at 8:22 AM
    Krautman73
    Austin, Tx
    Yeah, I'm leaning towards a replacement bumper as well down the road
    Black Wolf and Prostar 190 like this.
