Trimming fender liner
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Mar 29, 2018.
  1. Mar 29, 2018 at 11:10 AM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    Had Toyota investigate my popping noise in the front end that I get occasionally while turning and they said I am rubbing.
    I have seen many posts about trimming or relocating the fender liner. Does anyone have before and after pics of this procedure?
  2. Mar 29, 2018 at 11:26 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I don’t. I just see where it was rubbing and used a dremmel to cut the liner. Some have used a heat gun to remold it.
  3. Mar 29, 2018 at 11:35 AM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    This may help.
    Avoid if you can the heat gun, better options available.
  4. Mar 29, 2018 at 12:38 PM
    Cfincke
    San Antonio
    Photo of what someone local did. Trimmed at the large bolts, pushed the liner to the front and drilled a new hole for the one bolt.
    When I did mine, I pushed the liner forward and drilled a new hole, not as much a s the photo. I then used a heat gun and a large socket it massage one spot I just rubbed on
    ToyotaTundraMike[OP] likes this.
  5. Mar 31, 2018 at 5:49 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I dont have a picture of mine. But there are 2 or 3 10mm/philps screws on the splash shield close to the front bumper when you remove them. And pull the splash shield back you expose the clips that the splash shield mount to. Pull the clips off and cut it back further about an inch. Replace clips a d re-install. No need for heat gun or torch.
  6. Mar 31, 2018 at 8:11 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    subbed for future reference. thanks for the pic
  7. Mar 31, 2018 at 8:51 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I agree with post #2. There should be marks where the tires make contact, just address those areas.
  8. Apr 8, 2018 at 9:56 AM
    ToyotaTundraMike
    2015 Tundra
    Well to anyone in the future wanting to do this here is my advice after trying both ways:
    Skip the heat gun. Tried to heat up the plastic at first and use the end of a hammer to push on it and reshape it but it just made it look like shit.
    Takes literally 2 minutes to pop them off. I used some shears to trim the bottom of the plastic then touched it up with my dremel. Turned out perfect, can’t even tell from just looking in there that I have done anything. Also trimmed the end cap a little and made it where they tucked in.
    TS1794, rflinn0, Z_P_Dubyuh and 4 others like this.
  9. Apr 8, 2018 at 10:23 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    nice work
  10. Apr 8, 2018 at 10:41 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    what size tires are you running ? 35" ?
  11. Apr 8, 2018 at 11:42 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I heated it up, used the fat end of a baseball and it rolled forward pretty good. I then made 2 new holes for the existing bolts, I guess I could have trimmed the excess but it be only impressing ants. I avoided using a hammer from previous posts.
  12. Apr 8, 2018 at 2:21 PM
    ToyotaTundraMike
    2015 Tundra
    Thanks! Only running 275/70 atm but anticipating going up a size next time around. Didn’t really have to do this mod as my rubbing was very very minor. My main goal was to prove the Toyota tech wrong who said the popping noise in my front end was from the tires rubbing. Now if I can only track down where the popping is actually coming from...
    notatallcool likes this.
