Trim piece by windshield and wipers, paint it?
Discussion in 'Detailing' started by IowaGuy, Sep 3, 2022.
  1. Sep 3, 2022 at 8:14 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    The trim piece by the hood and windshield by the wipers is all faded on my truck as the AZ sun is really tough on things here. I have tried using black out products on it but they really don't last. Would cerakote do any good on this or has anyone painted this with Krylon Fusion for plastic. On a side note anyone know how to remove this piece?
  2. Sep 3, 2022 at 8:38 AM
    Have you tried this?
    War Machine and Taco-Spike like this.
  3. Sep 3, 2022 at 8:40 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Every other wash I wipe it down with Armor All.
    Taco-Spike likes this.
  4. Sep 3, 2022 at 8:45 AM
    Taco-Spike
    Two Trucks
    Cowl
    should be clips and maybe bolts that hold it in. I haven’t removed the tundra one before but I’ve removed them before from other vehicles and had to remove the wipers as well because it was over it
    but I hit mine with 303 after a wash along with the side mirrors
    texasrho83 likes this.
  5. Sep 3, 2022 at 8:50 AM
    Retired...finally
    There's a trick to removing the clips on the underside. I can't remember if it's holding the needlenose pliers horizontal or vertical. Once you tear up a few and brute force it out you'll see for sure. You're going to need one of these and it's not available right now but there are others just like it.
    https://www.amazon.com/HFS-Puller-B...0aa-495a-96df-bf7501fd0fc3&pd_rd_i=B08QHD4YR6
    While you're in there get some 1/4 hardware cloth and close off the vent area to keep the mice out.
    Rocko9999 likes this.
  6. Sep 3, 2022 at 11:34 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Big fan of Cerakote. Used it on my 06 4runner running boards and it brought them back to looking new. Great product for hard plastics and it lasts really long. I did my some of my Tundras plastics, mid section of front bumper, mudflaps, bed rail caps, over two years ago and it they still look great, no need to reapply yet.
  7. Sep 3, 2022 at 5:27 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Isn’t there a trick with heat gun to renew old black plastics like this piece?
  8. Sep 4, 2022 at 7:26 AM
    IowaGuy
    In Process
    Cowl, yes that is the word I was looking for. I have some cover all spray I will try and if that doesn't last then i might try the Cerakote or just paint it.
  9. Sep 4, 2022 at 8:47 AM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    +1. A couple years ago I took mine off to do the rat/mouse mesh. At the same time I plastidipped the cowl nice and black. It's held up for the last 2.5 years and still looks good. I want to redo the mesh but I broke several of the clips on the underside so I would need to find more of those first.
  10. Sep 4, 2022 at 9:46 AM
    briarpatch
    briarpatch New Member
    If you are going to paint it....this is what I would recommend over Krylon. I've used SEM trim paint with very good success on exterior plastics
    https://www.semproducts.com/product/trim-black
  11. Sep 4, 2022 at 10:31 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I've often thought about pulling the cowl and the wiper arms and repainting them..
  12. Sep 17, 2022 at 5:32 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    If you’re going to paint it with any type of coating be absolutely positive there are no silicons, oils, etc from the products you've been using all this time trying to bring the black back. It will not adhere. Will be looking at a headache long term if not prepped correctly.
  13. Sep 19, 2022 at 6:35 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Yep and I don't recommend it. Will end up looking worse in the long run.
  14. Sep 20, 2022 at 6:46 AM
    War Machine
    War Machine SSEM # 5 3MW
    Solution Finish is probably the best thing for restoring faded plastic. Cerakote doesn’t restore as well, but will definitely last a hell of a lot longer than anything else.
    r1-superstar and Ace96 like this.
  15. Sep 21, 2022 at 7:25 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    This is exactly what is happening to mine. 303 doesn't work on it. @War Machine Thanks for the tip. I'll give Solution Finish a try!
    War Machine[QUOTED] likes this.
  16. Sep 21, 2022 at 8:21 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
