TRICKY VIBRATION
Discussion in '2nd Gen Tundras (2007-2013)' started by El Nope-o, Nov 7, 2018.
  1. Nov 7, 2018 at 4:06 PM
    El Nope-o
    El Nope-o [OP] New Member
    2010 Tundra Double Cab
    Mostly Stock
    Ok ya'll, this is giving me a run for my money.
    2010 4.6L 4x4 Tundra Double Cab, 108,000 miles. Daily driver. No check engine lights or DTC's.
    Has a slight vibration/hesitation/stumble feeling that you can feel thru the seat, nothing from the steering wheel.
    Happens at 1,200 - 2,100 RPM's around 55-65MPH, while cruising. Under heavy acceleration nothing abnormal. Under slight easy acceleration it is apparent. Does not happen while coasting (with foot off gas).
    I first thought it was just worn out shocks and changed out the originals for the Bilstein 5100's I had in the garage. Wasn't it. Thought maybe the U-joints may have been going out as they were looking kinda beat up and slinging grease (or what was left of it) so I changed them. No go again.
    Swapped in a new air filter wondering it was starved for air, another loss. Checked rear wheel bearings by lifting truck off ground and trying to wiggle wheel assembly, seems firmly seated, no noises or leaks. Checked rear diff for signs of fluid leakage, all clean.
    Anyone have any ideas?
  2. Nov 7, 2018 at 4:08 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    Carrier Bearing?
    15whtrd likes this.
  3. Nov 7, 2018 at 4:26 PM
    El Nope-o
    Mostly Stock
    I looked at it while I had the drive shaft out yesterday doing the u-joints. I did not detect any noises while spinning it, although it flexed about 3/4" to 1".
  4. Nov 8, 2018 at 2:25 PM
    El Nope-o
    Mostly Stock
    It does not appear to be the carrier bearing. I jacked up the truck on all 4 corners, and put it in drive and gassed it. Put my phone under the truck to take a video. It stays nice and centered. Still felt the stumble/ hesitation.
    Checked the transmission mount and it's good. No check engine lights or codes. What else?
  5. Nov 8, 2018 at 2:54 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    How do your u-joints look?
  6. Nov 8, 2018 at 3:54 PM
    El Nope-o
    Mostly Stock
    Brand new, just replaced them Tuesday evening.
  7. Nov 8, 2018 at 4:32 PM
    Atomic City Tundra
    Devin
    New Mexico
    Doh! Missed that. Sorry.
  8. Nov 8, 2018 at 5:21 PM
    15whtrd
    15whtrd Mr. Blonde
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Hmm. The only discrepancy, is your test was without load.
  9. Nov 8, 2018 at 5:55 PM
    El Nope-o
    Mostly Stock
    Last weekend I towed a 2000 Malibu across the state. Felt it then too.
  10. Nov 8, 2018 at 7:14 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Fox 2.5 Coilovers w/ Resi Fox Triple Bypass 2.5x10 Fox 2.5 Rear Shocks w/Resi TC Spindle Gus TC Shock Hoop Camburg Upper Arms Camburg 1 3/4 shackles Deaver K37 K/N Intake Series 63 Bully Dog GT Platinum Magnaflow Exhaust KC FlexPods SDHQ Mounting Solutions Toyo 37-13.50-17 ProComp Vapor Pro Beadlocks 17x9 -5 PRO-NET!!
    Could be your pinion angle...
    15whtrd likes this.
  11. Nov 9, 2018 at 2:37 PM
    El Nope-o
    Mostly Stock
    Doubt it, the truck and suspension is stock, leafs are securely in place. Nothing has been changed or modified to induce this.
  12. Nov 9, 2018 at 2:48 PM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    But you said you dropped the shaft down right? If anything moved without you 1st measuring the pinion angle before you unbolted it then its more than likely off by a little after re-assembly. Just a thought...
  13. Nov 9, 2018 at 2:49 PM
    15whtrd
    15whtrd Mr. Blonde
    what I was saying is the test up on the jackstands was done with no load on the drivetrain. I’m curious what thecarrier bearing looks like under load. I suspect the carrier bearing is the issue. You said it moved about 3/4 to an 1”
  14. Nov 9, 2018 at 2:54 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, TC UCAs and Cam tab gussets, Auburn LSD, Coachbuilder +2s and shims, SABM, BHLM, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 35/12.5/17 General Grabber X3s, DT long tubes, xpipe with dual magnaflow 10436 mufflers.
    I had a similar issue for a while where I felt some random hesitation and it ended up being my fuel pump cutting out. Only found it by taking it to the dealer and having them plug into it and watch it while driving around.
    Atomic City Tundra likes this.
  15. Nov 9, 2018 at 6:10 PM
    El Nope-o
    Mostly Stock
    It did not appear to move on the video, but while bolted up in place I could move it about 3/4" - 1". I'll see if I can locate a carrier bearing locally and try that. At this point the carrier bearing theory is the only one that makes any sense.
    15whtrd likes this.
  16. Nov 9, 2018 at 7:03 PM
    Watt maker
    Watt maker Keepin' the lights on!
    Ronald
    2017 TRD Pro Tundra DC Cement
    1 of 255
    Could be torque converter shudder. Trying a complete change of trans fluid.
  17. Nov 9, 2018 at 9:44 PM
    landphil
    landphil C Eh N Eh D I Eh N
    Phil
    BC, Canada
    ‘08 TRD Doublecab 5.7L Quick Silver
    Still original spark plugs? Light throttle misfiring is a classic symptom of worn plugs. You’ll feel it before it ever thows a fault code too, in my experiences.
  18. Nov 10, 2018 at 5:07 AM
    El Nope-o
    Mostly Stock
    Plugs were changed last year.
    landphil likes this.
  19. Nov 10, 2018 at 5:12 AM
    El Nope-o
    Mostly Stock
    This was felt before I pulled down the driveshaft. Driveshaft was reinstalled in the same position and the carrier bearing in the same position. Pinion angle would be unaffected.
    15whtrd likes this.
  20. Nov 11, 2018 at 10:10 AM
    lilharv321
    lilharv321 New Member
    My 07 had similar issues at 55 mph and would go away at 75-80, did the carrier bearing and it did nothing. Checked the wheels bearings for wiggle and they had none but it did end up being my front right wheel bearing. Replaced it and everything was good.
    El Nope-o [OP] likes this.
  21. Nov 11, 2018 at 12:20 PM
    El Nope-o
    Mostly Stock
    Changed out the carrier bearing out this morning, quick test drive feels good. I'll be able to tell for sure after driving to work tomorrow morning as I'll have the drive time and plenty of speed variations.
  22. Dec 31, 2018 at 6:55 AM
    rebmo
    rebmo 2010 DC 4.6L 4wd
    SE Wisconsin
    Outside chance but check your parking brake for hang up issues. The mechanism under the drivers side passenger seat hung up on mine and did not fully disengage the parking brake. at 45-50mph the truck would shake at times and dealer could not figure it out (extended warranty). I felt the rear wheels and the drivers rear was hot. I cleaned and lubed the parking brake linkage and the problem went away. It came back after the first winter (after fixing) and cleaned and lubed the mechanism again and problem gone. I now coat it good with fluid film along with the underside of the truck prior to each winter and have not had any issues. The shaking felt like a bad wheel or driveshaft but could not feel through brakes or steering. Took a while to figure out but found a post somewhere on the parking brake sticking and the hot wheels. That led me to check it out and sure enough that was the issue.
