TRD sway bar?
Discussion in '2.5 Gen Tundras (2014-2021)' started by CH1NO, Apr 2, 2020.
  1. Apr 2, 2020 at 10:27 PM
    CH1NO
    CH1NO [OP] New Member
    TEXAS
    2016 SR5 CM
    Should I leave my truck with the front stock sway bar?.... Or maybe just add the front TRD sway bar or both front and back? Does it really make a difference???
  2. Apr 2, 2020 at 11:52 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    The back certainly helps. I don’t think adding the trd front would make much Difference from stock it’s just a little bigger diameter and red
  3. Apr 3, 2020 at 3:22 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I did both at the same time, so I can't tell you how much of a difference each one makes individually, but the front trd sway bar is a sold piece of steel compared to a tube for the stock one. Weight difference is 15lbs stock vs ~ 30 lbs trd. So, I would say the front also helps and I know I could tell a difference in the amount of roll the first turn I took after installing them. Overall I feel like both are worth puttingo on.
    I would do it now if you're going to do it with a newer truck because with the front sway bar, you only get the trd bar and have to reuse all the existing hardware. It was easy with mine since it was brand new, but when we went to do my dads 2016, it was a PITA getting the sway bar end links off since they were rusted. After about 45 minutes of everything we could think of to get them off, they finally did. We were both relieved because the cost of 1 end link is almost the price of the sway bar, which seems ridiculous to me.
  4. Apr 3, 2020 at 4:01 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    If you take it off-road leave the rear off. For highway driving, hauling and towing It is a big help.
  5. Apr 3, 2020 at 4:33 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The rear bar is what I consider a must have item, and Hellwig makes a rear bar that is beefier than the TRD bar.
  6. Apr 3, 2020 at 4:37 AM
    timsp8
    NY
    I have an are cap and decked drawers, so I have a lot of weight in the bed and I think the rear helps. I don’t roll much when going around curves. Got the front too during the 40% sale but can’t say I saw a difference. I wouldn’t have done the front if it wasnt for that sale.
  7. Apr 3, 2020 at 4:40 AM
    The rear makes a big difference but not sure about the front. I put the Hellwig on the rear of mine.
    Rica25, CH1NO[OP] and Rex Kramer like this.
  8. Apr 3, 2020 at 5:08 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I installed the rear one first and immediately noticed a difference. I later installed the front one and noticed a slight difference.
  9. Apr 3, 2020 at 7:25 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    The rear for sure is a difference but the front I dont think is to much of a difference.
  10. Apr 3, 2020 at 11:20 PM
    CH1NO
    TEXAS
    2016 SR5 CM
    Thanks everyone for the info, gonna pull the trigger on this mod once I find a good deal on it.
    InsaneAuto86 and Pot Hole like this.
  11. Apr 4, 2020 at 3:45 AM
    Vin63
    Vin63 New Member
    2022 Tundra SR5 DC
    one of my next mods! Rear Trd sway bar
    InsaneAuto86 and Rica25 like this.
  12. Apr 4, 2020 at 3:57 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    that rear sway bar is a huge improvement with on-road handling. you really notice it with freeway speed lane changes. there is far less body roll all around. do it :)
  13. Apr 4, 2020 at 5:24 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Sway bar links: It really helps if you have a set of Oxygen/Acetylene torches. Vice grips on the boot side, yes they will fit in there. You are trying to grab the nut lange on that side so it does not spin. Heat the nut up red hot, and remove with ease. Removing the rubber boot is a plus because it can get stinky. Do this in a well ventilated area. Of course if all else fails, you can just cut the nut off. Cutting with torches is awesome, but takes some practice. I could cut the nut off the sway bar and you would never know I had a torch do it........yea I'm that good. A tube sway bar, that's new to me, must investigate.....never heard of such a thing. Did Toyota go cheap on me?
    Rica25 and omgboost like this.
  14. Jun 27, 2020 at 4:09 AM
    Pot Hole
    Pot Hole Where dem Mallards at?
    Mount Ulla, NC
    2020 White Limited TRD
    TRD skid plate, Stainless Running Boards, JDA Astar turn signal bulbs, VLEDs footwell lighting, Wet Okole seat covers, Weathertech Window Deflectors, more to come!
    If you do, post it up. I want to do the same thing
    Rica25 likes this.
  15. Jun 27, 2020 at 5:23 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I paid $214.57 shipped to my door from BAM wholesale last month. Was cheaper than Sparks by a few bucks. Google for the active BAM shipping coupon too. Did regular shipping but arrived in 4 days.
    Ne1tHeRe, Rica25 and Pot Hole like this.
  16. Jun 27, 2020 at 5:37 AM
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    I got the Sport model so it came with front and rear sway bars. I helped a friend move and he had a 16 SR5 and it didn't have sway bars in the front or the rear. Going from mine with sway bars to driving his without (and a load in the back), big difference. At first i thought it was just because it was an older truck (mine only has 16K miles on it), but I realized it was the lack of sway bars.
    Off road, I like the articulation freedom of no sway bars, but I rarely get into that serious of off roading any more. And, when I do, it is in the FJ.
    Pcmc19057, TelemarkTumalo and Rica25 like this.
  17. Jun 28, 2020 at 7:25 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    IMO both made a nice improvement in handling.
  18. Jun 28, 2020 at 7:36 AM
    iNKBOi
    iNKBOi Colorado Boi
    Ben
    Vail, CO
    2008 Radiant Red Double Cab SR5 TRD Off-road and now 2020 TRD Pro Army Green Crew
    Love the sway bar! One of my favorite mods. I even matched the sway bar angle when I built my bumper.
  19. Jun 28, 2020 at 7:58 AM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    I put the rear TRD way bar on my 2nd gen and noticed a huge improvement. I would recommend starting with the rear, then adding the front if you think you need it. For a couple hundred bucks I would highly recommend the TRD rear sway bar.
    RitcheyRch and Cpl_Punishment like this.
  20. Jun 28, 2020 at 8:00 AM
    ekinnee
    ekinnee New Member
    North Central Texas
    2020 Tundra Quicksand SR5 TSS
    I'm on road 99% of the time and coming from my TA 392 Challenger, the body roll is super noticeable. I've been heavily considering adding/upgrading bars.
  21. Jun 29, 2020 at 6:45 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    The front stock sway bar is very light and tubular. The the front TRD sway bar is a hunk of heavy solid steel. I can't see how it can't improve in handling.
  22. Jun 29, 2020 at 7:13 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I love mine on my TRD Sport, I drive it like I stole i around on-ramps and off-ramps! LOL
  23. Jun 29, 2020 at 7:14 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Don't knock on it until you have it LOL.
  24. Jun 29, 2020 at 7:15 AM
    Dano8855
    Dano8855 New Member
    2018 Tundra Limited
    Not knocking it. I have TRD swaybars on the front and back and I think there is nice improvement in handling.
    phabej[QUOTED] likes this.
  25. Jun 29, 2020 at 8:06 AM
    snappy924
    snappy924 New Member
    Garrett
    Pasadena, California
    2017 Tundra Crewmax 4x2
    Bilstein shocks, Tembren bump stops,
    How difficult is it to install the sway bars? Thank you
  26. Jun 29, 2020 at 8:13 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    One of the better install videos out there.
    https://youtu.be/cZdVjObkTLs
    AggiePhil and Bammer like this.
  27. Jun 29, 2020 at 8:13 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I did both front and rear at the same time along with airbags and 5100 when it was only 500 miles on the clock. Compared with no sway bar, it's a big improvement.
  28. Jun 29, 2020 at 8:14 AM
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    The rear was crazy easy. I did it in nearly no time. But my hardware wasnt rusted or corroded. I second the vote of installing the rear and seeing whats what. I doubt ill install the front one. I haul/tow a lot and i can tell the difference.
    I used my battery powered impact, but you could do it with hand tools.
    73341326_2675723972494003_8597150399050285056_o.jpg 78635340_2675724065827327_5474802418598281216_o.jpg
  29. Jun 29, 2020 at 8:43 PM
    trowski
    trowski New Member
    The instructions note that if you have the OEM hitch that you're supposed to skip the washer against the frame where the top link attaches. Not sure how much difference it makes, but I thought I'd mention it.
  30. Jun 29, 2020 at 10:37 PM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    I did rear a few years back and was happy with the results.
    Did the front last month and could tell right away the ride was a little stiffer and the recovery on a big dips on the freeway was faster while towing my 27' travel trailer. very happy with the results.
    phabej likes this.
