TRD sway bar bushings
Discussion in '2.5 Gen Tundras (2014-2021)' started by Yota707, Jul 9, 2020.
  1. Jul 9, 2020 at 8:49 PM
    Yota707
    Yota707 [OP] New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Does anyone know if I can buy replacement bushings only for the TRD rear sway bar? I bought a used sway bar and wanted to replace them with new. Maybe @Roman knows
  2. Nov 19, 2020 at 6:03 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Bump on this thread as Im now in search of some bushings as well. Not having any luck with online searches.
  3. Nov 19, 2020 at 7:05 PM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    Unfortunately Toyota only sells them with the complete hardware kit. There is after market company’s that sell some that are similar to OEM
  4. Nov 20, 2020 at 4:54 AM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    Well thats nice. The only hardware kit I have found is about 175 and only comes with the end links not the middle bushings that attach to the axle. Do you still have a p/n from your searches?
  5. Nov 20, 2020 at 11:42 AM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    I used these
  6. Nov 20, 2020 at 12:30 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    And what did you use for bushing goop/lubricant?
  7. Nov 22, 2020 at 5:34 PM
    Jettech
    Jettech New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    Thank you so much. I will give them a try. My noise is coming from the sway bar moving back and forth in the bushings and causing a slight knock feeling and noise. Hopefully this will fix the issue.
  8. Jun 22, 2023 at 2:35 PM
    squid
    squid New Member
    Pacific Northwest
    2014 crewmax
    Trd sway bar, trd shit knob, Bakflip MX4
    Did this fit the rear sway bar? Im looking for some rear bushing with no luck.
  9. Jun 22, 2023 at 9:16 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    If you end up buying the hardware kit, I might pick up the end links from you, I'm tendering purchasing a front/rear swaybar setup, but the truck that had them was lifted and the original rear swaybar links are missing, so that could be of interest to me.
