TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by rbros, Dec 25, 2020.
  1. Jan 24, 2021 at 7:13 AM
    #211
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Energy Suspension would be where I'd look, if you haven't already. Delrin bushings might be interesting too, that stuff is hard.
  2. Jan 24, 2021 at 9:56 AM
    #212
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Well, I swapped my 20” wheels with 18” snows for the winter... no change in bed bounce at all. Doubt the RSW will make a difference. I get it pretty bad on one long stretch of concret on the way to work.
  3. Jan 24, 2021 at 10:58 AM
    #213
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    so do you have the RSB installed? Does it make the ride rougher in general?
  4. Jan 24, 2021 at 11:53 AM
    #214
    2mchfun
    I have no trd sway bar and won't have either. However, I have the yellow sumo springs on the truck and body roll is history! Plus that If I want to off road, just pull out the hi-lift, raise a little and unscrew the sumo springs. Key is to have second set cut down to screw on for bump stops. Full factory articulation in minutes. Plus the leaf springs will suffer much less wear and will likely never be flattened much over time. She corners like a Porsche and can haul a ton with minimal squat.
    W3agle likes this.
  5. Jan 24, 2021 at 11:54 AM
    #215
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Energy Suspension and Prothane were the first places I checked but neither list anything for our Tundras.
    Wynnded[QUOTED] likes this.
  6. Jan 24, 2021 at 12:01 PM
    #216
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It may be necessary to call them. There's a remote possibility that they might have something for another application that would be appropriate.
  7. Jan 24, 2021 at 12:07 PM
    #217
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I had a similar question on another thread. It is my understanding that bed bounce is caused by frame flexing and the RSB will have little to no effect. I should add that I don’t have issues with bed bounce myself and the RSB only improved handling and I feel no difference in ride.
  8. Jan 24, 2021 at 12:14 PM
    #218
    2mchfun
    Better shocks will help with bounce. If you are really picky, a Lexus is another option.
  9. Jan 24, 2021 at 12:44 PM
    #219
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    ok cool that was another question I had....my ride, mainly in the rear is still a little stiff even with the shackles and upgraded shocks so I definitely don’t want that to be worse if I go with the RSB.
  10. Jan 26, 2021 at 10:51 AM
    #220
    Charliebrn
    NW Ohio
    A fairly easy install...
    831mic, EN2TUNDRA, Fastlane47 and 4 others like this.
  11. Jan 26, 2021 at 12:53 PM
    #221
    2112OFFROAD
    2112OFFROAD New Member
    socal
    2020 Tundra CM 4x4 Off Road
    Looks good, how long it take you to wrap it up?
  12. Jan 26, 2021 at 1:36 PM
    #222
    Charliebrn
    NW Ohio
    I got it yesterday (they shipped it quick!) and painted the brackets. Took my time putting it on and spent maybe an hour. Having it up on ramps made it comfortable to do, but wasn’t absolutely necessary.
    having everything fluid filmed probably helped, as the old frame bolts came off without any trouble.
  13. Jan 26, 2021 at 1:38 PM
    #223
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    A cheap mod I did in my 2002 long bed ranger was putting 4 30 lb dumbbells on the inside of the rear bumper cavities. It really helped with the bed bounce. Not sure if it would work with tundy's though.
    2112OFFROAD likes this.
  14. Jan 26, 2021 at 5:30 PM
    #224
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    Dang on, give it up to McGeorge!! Package came quick and really well boxed together. Five stars for McGeorge beating the price of the damn dealer 5 feet from my house. All pieces appear as they should. Got a date with the truck and garage on Saturday. Boom.
  15. Feb 16, 2021 at 9:03 AM
    #225
    Mojo2021
    Mojo2021 New Member
    DFW
    2021 Black Tundra SR5 SX, DC...
    Just ordered one.
    Appreciate a heads-up, gents.
  16. Feb 16, 2021 at 10:29 AM
    #226
    Charliebrn
    NW Ohio
    You know, not that I’ve had mine on for a couple weeks, I’m sort of amazed that Toyota didn’t put these in as standard equipment...and a little disappointed in them for not doing so. Even consumer reports complained about the feel of the ride, and this completely solves all my complaints. What a difference this makes in the handling.
    Cpl_Punishment and Rex Kramer like this.
  17. Feb 16, 2021 at 11:14 AM
    #227
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    so what were your complaints that it fixed if you don’t mind?
  18. Feb 16, 2021 at 11:29 AM
    #228
    Charliebrn
    NW Ohio
    The truck rolled a LOT... not just on serious curves but in any slight curve. At speed it was enough to make me slow down (unnaturally to me, anyhow) much more so than when I had my Titan.
    When towing my camper, I really felt it... to the point where I was white knuckling it in turns. Even when not in turns, the truck feels MUCH more planted...it’s hard to describe, but I’m not imagining it, even my wife commented on it.
    it should have been my first mod.
    shellshock likes this.
  19. Feb 16, 2021 at 11:46 AM
    #229
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Nice...do you notice any difference in ride quality, good or bad?
  20. Feb 16, 2021 at 12:00 PM
    #230
    Charliebrn
    NW Ohio
    Like I said, it’s hard to quantify, but outside of the rolls in any maneuver being gone, it’s a big difference in feeling “planted”. It didn’t stop “bed bounce” on one road that causes it for me, but it didn’t make it worse either.
    But that feeling planted translates to a lot more confidence on the road. We don’t have many rough roads nearby, so haven’t tried that yet, but the truck definitely behaves much more predictably.
  21. Feb 16, 2021 at 12:03 PM
    #231
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Cool, thank you! I am tryin to address the bed bounce as well and was hoping this would help but sounds like a useful mod none the less for how I drive it. Appreciate it
  22. Feb 16, 2021 at 12:05 PM
    #232
    Charliebrn
    NW Ohio
    Bed bounce... I think it’s the harmonics of the truck... I’ve thought about some stiff foam being placed between the cab and truck bed as a dampener ...
  23. Feb 16, 2021 at 12:23 PM
    #233
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    worth a try I guess....I hit a stretch of road the other day that is otherwise smooth in a car but I thought I was going to bounce off the road. Drove that same stretch loaded with some furniture a couple weeks ago and it was super smooth.
  24. Feb 16, 2021 at 12:28 PM
    #234
    Charliebrn
    NW Ohio
    Y’a know, I thought it was just the truck, but after paying attention, I can feel it slightly in my RAV4 too. 300 pounds of sand over the rear axle didn’t change it at all. I was hoping the sway bar would help, but no bueno. Still VERY happy with that mod though.
  25. Feb 16, 2021 at 12:28 PM
    #235
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    We could probably whittle it down to: Wheelbase + Pavement Undulations + Suspension Tuning = Bed Bounce (Harmonic Oscillations).
  26. Feb 16, 2021 at 1:01 PM
    #236
    steve_liebchen
    steve_liebchen New Member
    Holly Springs Alabama
    2021 TUNDRA SR5 DC 4X4 MGM
    TRD RSB, Ranch Hand Grill guard, Husky Weatherbeaters, sill guards, console tray
    the RSB is a must have- the factory bushings are plenty hard enough. Few folks really off road to where they don't need it
  27. Feb 22, 2021 at 8:14 AM
    #237
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I finally installed my TRD sway bar this weekend. The install was very easy and the handling is much improved. The rear rides a bit stiffer but that is a good thing for me. Money well spent.
  28. Feb 22, 2021 at 8:24 AM
    #238
    2112OFFROAD
    socal
    I got mine installed too, not any stiffer as far as the ride goes but a massive difference in handling. Not a slot car, but not a big fat pig anymore.
  29. Feb 22, 2021 at 8:55 AM
    #239
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Ordered mine last Thursday - looking forward to the install and hopefully see the same improvements as most who have done it.
  30. Feb 22, 2021 at 9:37 AM
    #240
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Waiting until the weather breaks, can't wait to get it on there !!!
