TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by rbros, Dec 25, 2020.
  1. Jan 19, 2021 at 9:55 AM
    #121
    bwh
    bwh New Member
    What's the difference in the TRD FSB vs the stock FSB?
  2. Jan 19, 2021 at 9:57 AM
    #122
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I'm old school and not up on all the lingo. What does "NVH" stand for?
    EN2TUNDRA and JerryH like this.
  3. Jan 19, 2021 at 9:59 AM
    #123
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    Thicker bar, more resistance to flex. Better road manners but reduced articulation off road.
  4. Jan 19, 2021 at 9:59 AM
    #124
    Badknees
    Badknees New Member
    South Carolina
    I'm sure there are other experts here with a better answer, but I think the TRD FSB is solid steel whereas the stock one is not....and red too:)
    BravoDeltaRomeo likes this.
  5. Jan 19, 2021 at 9:59 AM
    #125
    realprotundra
    Gilbert, AZ
    Noise, Vibration, and Harshness.
  6. Jan 19, 2021 at 10:00 AM
    #126
    Badknees
    Badknees New Member
    South Carolina
    Thanks! I would have never figured that out!
    Matala, EN2TUNDRA, BGoodiE and 2 others like this.
  7. Jan 19, 2021 at 12:40 PM
    #127
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Anybody have any experience with the rear sway bar in deep sand?
  8. Jan 19, 2021 at 12:44 PM
    #128
    steve_liebchen
    steve_liebchen New Member
    Holly Springs Alabama
    2021 TUNDRA SR5 DC 4X4 MGM
    TRD RSB, Ranch Hand Grill guard, Husky Weatherbeaters, sill guards, console tray
    we have had this on 2, soon to be 3rd Tundras. TRD RSB. Best thing ever
    JerryH likes this.
  9. Jan 19, 2021 at 12:44 PM
    #129
    realprotundra
    Gilbert, AZ
    I do not but a rear sway bar should have no negative aspects in deep sand. If anything it would help keep the rear tires planted and hop less once it grabs any traction. The bar itself is higher than the bottom of the diff.
  10. Jan 19, 2021 at 12:45 PM
    #130
    JerryH
    SOMD
    Great. I’ve seen some that hang a little lower than others. Is there play when installing?
  11. Jan 19, 2021 at 12:54 PM
    #131
    realprotundra
    Gilbert, AZ
    Zero play in the height of the bar.
  12. Jan 19, 2021 at 1:05 PM
    #132
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    You can mount it like this too.
    Lots of pics in this big thread, showing clearance.
  13. Jan 19, 2021 at 1:09 PM
    #133
    realprotundra
    Gilbert, AZ
    You would either need a lift or shorter end links (or both) for that type of mounting.
  14. Jan 19, 2021 at 1:19 PM
    #134
    JerryH
    SOMD
    No lift, just stock limited.
  15. Jan 19, 2021 at 1:21 PM
    #135
    realprotundra
    Gilbert, AZ
    Does the truck in that image not have a shackle lift on it? Definitely has shorter end links and non-oem bushings in the springs.
    Edit:
    I see what you’re saying. With no lift you could likely make it work with some shorter end links and no other modifications.
  16. Jan 19, 2021 at 1:33 PM
    #136
    JerryH
    SOMD
    I just don’t want it hanging lower than the the diff
  17. Jan 19, 2021 at 1:33 PM
    #137
    JerryH
    SOMD
    Went ahead and ordered one. Can’t wait to feel the difference.
  18. Jan 19, 2021 at 3:07 PM
    #138
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Any deals on them anywhere?
  19. Jan 19, 2021 at 3:08 PM
    #139
    JerryH
    SOMD
    McGeorge ToyotA 218.50 no tax/shipping
  20. Jan 19, 2021 at 3:15 PM
    #140
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    That’s the best deal I found.
    Sparks was just under 200 with the forum discount but around 225 shipped to me.
  21. Jan 20, 2021 at 5:11 AM
    #141
    NCSkeeter
    I watched a YouTube video recommending anti seize in the metal to metal interfaces during install. Toyota doesn’t recommend it. Is there consensus here in the use of anti seize? Use of road salt is minimal around here so I’m not as concerned about corrosion as some are.
  22. Jan 20, 2021 at 5:18 AM
    #142
    Badknees
    Badknees New Member
    South Carolina
    For me, the center of the RSB sits just at the bottom of the rear diff. case on level ground with no bed load. The RSB arms are attached to the frame and the cross bar/bushings to the axle. The cross bar is shaped to clear the rear diff case and this "U-shaped" bend will pivot in the bushings and be pushed by the arms up above the bottom height of the rear diff. as the rear axle/leafs are extended. I'm not 100% certain as I haven't tested, but I don't think the axle/leafs will move upward enough for the arms to push the cross bar much below the rear diff. case (but I could be wrong). Check the picture above on post #101 from WGusler to see how much it moves up when the axle/leafs are 100% extended.
    JerryH likes this.
  23. Jan 20, 2021 at 5:53 AM
    #143
    Badknees
    Badknees New Member
    South Carolina
    I don't see why it would hurt to use it, but like you I'm not too concerned here in the Carolina's...
    JerryH likes this.
  24. Jan 20, 2021 at 9:10 AM
    #144
    realprotundra
    Gilbert, AZ
    Probably wouldn't hurt to use some anti-seize on the frame to end link connection. That being said, the torque spec will change when anti-seize is applied. Make sure you look up the "wet" torque spec for the fasteners you want to apply the anti-seize to.
    Saltyhero13 likes this.
  25. Jan 20, 2021 at 9:14 AM
    #145
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Just ordered my TRD RSB from the Mcgeorge dealer link from page 3. $218 shipped.
    BGoodiE likes this.
  26. Jan 20, 2021 at 9:27 AM
    #146
    Saltyhero13
    Saltyhero13 Throbbing Member
    Is it lubricant dependent?
  27. Jan 20, 2021 at 9:29 AM
    #147
    realprotundra
    Gilbert, AZ
    It is (in theory). In all reality, you are going to have to REALLY be cranking on that frame to end link connection to mess something up. Part of the torque spec is to ensure the bushings are properly compressed each and every time one of these bars is installed regardless of who the installer is.
    Saltyhero13[QUOTED] likes this.
  28. Jan 20, 2021 at 10:00 AM
    #148
    NCSkeeter
    Good point on the wet torque. I’m probably just going to skip the anti-seize. I don’t have any in the garage and the bar gets delivered today :bananadance:
    Ordered from McGeorge Monday and I’m getting it two days later with free shipping.
  29. Jan 20, 2021 at 6:19 PM
    #149
    Charliebrn
    NW Ohio
  30. Jan 20, 2021 at 6:32 PM
    #150
    TundraRV
    TundraRV New Member
    @Charliebrn when you get to checkout page, use "FREESHIP" in the discount code part under the price.
