TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by rbros, Dec 25, 2020.
  1. Jan 4, 2021 at 8:27 AM
    #61
    Saltyhero13
    Saltyhero13 Throbbing Member
    No worries. Well worth the time and effort. Its in the instructions but a torque wrench will be needed as well to tighten everything to spec.
    d_kinneyjr[QUOTED] likes this.
  2. Jan 4, 2021 at 8:35 AM
    #62
    Enzof104
    Enzof104 Have Trailer will Travel
    Paul
    Danbury CT
    2015 SR5 TRD OR DC, because bed size matters...
    Ironman Foam Cell Pro Lift. 2018 retro fit LED headlights, TRD grill, TRD rear sway bar.
    It really wasn’t too challenging. Didn’t even have to jack the truck up.
    The top hanger bolts on the frame where a bit of a PITA on 5 year old truck. Some liquid wrench and a breaker bar did the trick. Couldn’t use my impact wrench on that one because it was too tight of an angle. Other than that, straight forward and took less than an hour from start to clean up. Make sure you have some cardboard on the ground so you don’t scratch up the finish on the bar.
    TundraPJ and d_kinneyjr[QUOTED] like this.
  3. Jan 4, 2021 at 2:53 PM
    #63
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    Installed mine this weekend. It was an easy install. You want the truck on the ground (i.e., suspension loaded) when you do the installation. There is more than enough space to move around under the truck. The video above is good to watch and the instructions included with the sway bar are clear and easy to follow. You do need a torque wrench...the 22mm upper end-link to frame bolts are torqued to 84 ft-lbs and the lower 19mm end-link bolts and the 19mm bushing u-bolt bracket bolts get torqued to 48 ft-lbs. (going from memory....so confirm the specs).
    Since my truck only had 50 miles on it (not exposure to the elements yet), I was able to easily remove the forward 19mm frame hitch bolts with a 18” long 1/2” breaker bar....no impact gun needed.
  4. Jan 8, 2021 at 1:27 PM
    #64
    Big Erv
    Big Erv New Member
    2021, 2WD-Max Cab-SR5 w/ Tow package and brake controller.
    Just added it to my 2021 2WD
    What a difference. Easy to install. Highly recommend
    Tundra234 and Saltyhero13 like this.
  5. Jan 9, 2021 at 10:17 PM
    #65
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Bought my 2021 2 weeks ago and just installed both front and rear bars. Absolutely amazing upgrade. You will notice a difference immediately and every time you turn.
    Installation was pretty much as easy as it can get and it comes with instructions. Torque wrench required. Use antiseize on contact points.
    thunderstorm likes this.
  6. Jan 10, 2021 at 5:45 AM
    #66
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It's still a noticeable improvement, but not as dramatic as the rear.
    WxRaider[QUOTED] likes this.
  7. Jan 10, 2021 at 8:26 AM
    #67
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    I think the front is worth getting for sure. It compliments the rear well, though I would say you feel it more when you take tighter or faster turns. If you can only get one for whatever reason, I would do rear.
    Tundyfundy likes this.
  8. Jan 10, 2021 at 8:31 AM
    #68
    Saltyhero13
    I think it is but it's an upgrade to the existing bar. For me adding the rear bar was a 75% improvement, the front bar is a 25% improvement to handling. A noticeable upgrade.
    Vang530 and WxRaider[QUOTED] like this.
  9. Jan 10, 2021 at 11:06 AM
    #69
    Tundra-dude
    Tundra-dude New Member
    2020 Tundra SR5 CrewMax
    Does the Tundra come with a front sway bar without a rear sway bar? Are folks just adding the rear and using the original OEM front sway bar? I assume the TRD sway bars are stiffer front and rear? Trying to follow how folks are doing the upgrades. The handling on curves could be improved and if there isn't a front sway bar from the factory I assume that is where to start? If it comes with a front sway bar then I think I'll added the rear TRD based on the improvements folks are seeing. I have a 2020 SR5. Thanks.
  10. Jan 10, 2021 at 11:10 AM
    #70
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    All Tundras come from the factory with a standard sway bar on the front of the vehicle. Most are adding a rear sway bar and that's it, a few are swapping out the front for either a Sequoia (stiffer) sway bar or a TRD sway bar (stiffer yet) in addition to the rear sway bar. Hellwig makes an adjustable bar for the rear, I'm not sure if they make one for the front.
  11. Jan 10, 2021 at 11:18 AM
    #71
    Saltyhero13
    Recommend adding the rear sway bar first before considering upgrading/adding the front. The quality of the shocks makes a difference to the the experience as well.
  12. Jan 10, 2021 at 11:35 AM
    #72
    Tundra-dude
    Ok, thanks for the responses folks. That makes sense. On my old track car (Nissan 350Z) I had installed some aftermarket Hotchkis adjustable front and rear sway bars. This helped dial out the factory tendency to understeer and balance the handling out. Granted this is a truck. (It's my first truck too!) I'm really happy with it but there is something about how it handles even gentle sweeping curves that I'd like to improve. I'll start with the rear sway bar and see how it feels. I'm not expecting sport car results. Thanks again.
  13. Jan 10, 2021 at 12:02 PM
    #73
    Saltyhero13
    You can probably find an OEM (nonTRD) Front Sway fairly cheap if your truck doesn't have one.
  14. Jan 10, 2021 at 12:03 PM
    #74
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Yup. I've seen them on local ad sites for $50.
    Saltyhero13[QUOTED] likes this.
  15. Jan 11, 2021 at 5:53 AM
    #75
    coTony
    Tony
    Montrose, CO
    Hellwig makes 2 sway bars for the rear, one for stock height and another that is adjustable for lifts. The difference in the Hellwig and TRD are very noticeable and I prefer the Hellwig. Unfortunately they do not offer a front for the later models only the Gen 1
    Wynnded[QUOTED] likes this.
  16. Jan 13, 2021 at 8:56 AM
    #76
    jlarkin1918
    jlarkin1918 New Member
    Jared
    Western Massachusetts
    2020 SR5 TRD Offroad Crewmax-Cement
    OEM Spray-In Liner TRD Pro Black Badges & center caps GoRhino RB20 running boards Lomax cover
    How easy is the install for the TRD rear sway bar for the average DIYer? Considering just having the dealer do it when I bring it in for my 1 year service, any ideas what I should expect to pay for the dealer install including the parts?
    I’m sure I can do it myself but I need to weigh my time + pissing off the wife tinkering with the truck vs paying the dealer.
    French Avocado likes this.
  17. Jan 13, 2021 at 9:07 AM
    #77
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
  18. Jan 13, 2021 at 9:26 AM
    #78
    Enzof104
    Paul
    Danbury CT
    Watch the video. Unless you have a bad back and have a hard time sliding under the truck, it’s one of the easiest mods you can do. Especially if your truck is newer with limited rust or grime on the bolts.
    No promises but honestly it should take you less time to do it yourself than it would to drive to the dealership. Plus you’ll have the pride of the accomplishment = man card.
    post 59 has the video. YouTube has a few others that are good too.
  19. Jan 13, 2021 at 9:54 AM
    #79
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Its very easy to install the rear TRD sway bar if you have ever done any work on a car before. I would recommend the rear sway bar if you arent a hardcore offroader.
    I just so happen to have a stock front sway bar since i just swapped out to the TRD one, looking to get rid of it. I would let it go very cheap.
  20. Jan 13, 2021 at 11:12 AM
    #80
    jlarkin1918
    Jared
    Thanks for the input, now the question, where to buy it?
    The closest online dealer parts store to me is out of Boston and they wanted $100 in shipping to ship it across the state. My dealer can get it but they charge retail parts prices $259 I think , no online discounts and I still have to go pick it up. Not a huge deal, I might wait till warmer weather to do it myself anyway
  21. Jan 13, 2021 at 11:16 AM
    #81
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    Can get it on Amazon if I am not mistaken. Price fluctuates a bit between dealers even or private parties but take into account how much they want for shipping when looking at price. I just went to the dealer a few miles from my house. Wasnt worth my time to wait for it to ship from somewhere just to save 20 bucks.
  22. Jan 13, 2021 at 11:24 AM
    #82
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I’ve been watching it on sparks parts. It’s 209 minus 5% forum discount and about 25 in shipping. Seems to be about the best deal around now.
    tbutler and Enzof104 like this.
  23. Jan 13, 2021 at 12:13 PM
    #83
    Enzof104
    Paul
    Danbury CT
    THIS!!!:amen:
    they are great. best prices and fast shipping.
  24. Jan 13, 2021 at 12:26 PM
    #84
    Bammer
    Monroe, CT
    How do we get the forum discount?
  25. Jan 13, 2021 at 12:55 PM
    #85
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I ordered mine from McGeorge Toyota online parts in VA. The shipping is free for over $75 total. These guys are right there on pricing with Sparks and sometimes cheaper. Also, their parts service is second to none IMO:
    https://toyotaonlineparts.mcgeorgetoyota.com/
    VENUSDOOM likes this.
  26. Jan 13, 2021 at 5:43 PM
    #86
    racerex
    racerex New Member
    Will
    I flip between McGeorge and Sparks when buying OE parts for my four Toyota’s. I only hit up my local dealership parts department for oil filters. I purchased the TRD rear sway bar for my Tundra from Sparks....I seem to recall it being $209 and it slipped my mind to use the discount....stupid me.
  27. Jan 14, 2021 at 4:47 AM
    #87
    Badknees
    Badknees New Member
    South Carolina
    Exact same for me. Only problem for me with Sparks is I have to communicate via text messages which is a PITA, but maybe that's COVID related and won't last..
  28. Jan 14, 2021 at 7:39 AM
    #88
    jlarkin1918
    Jared
    Thanks but for me Sparks and McGeorge shipping costs put me pretty much back at my dealers full retail cost.
    I’ll keep an eye out the next few months and see if any of them drop and pull the trigger for a spring time project.
    10TundraSR5 and Bammer like this.
  29. Jan 14, 2021 at 8:00 AM
    #89
    Badknees
    Badknees New Member
    South Carolina
    McGeorge has (2) websites. The "online" site provides free shipping for any purchase over $75 when using the "FREESHIP" code at checkout:
    Sorry, I think I referenced the dealership site in my previous message. I think the total would be $218.50 plus tax. Not sure how that compares to Sparks with 5% discount.
  30. Jan 14, 2021 at 12:17 PM
    #90
    BGoodiE
    BGoodiE New Member
    Ben
    19 TRD SR5 OR
    NONE! Lasted about a month, Firestone bags, Decked system, ARE CX HD, WeatherTech mats/rainguards, TRD RSB...
    Wow I just got quoted $550 from my local dealer. So much for loyalty ya greedy *ucks. Buy a 36k dollar truck and you would think they'd hook ya up.
