TRD rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sixpack, Oct 11, 2016.
  1. Dec 13, 2016 at 7:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    True that!!
  2. Dec 14, 2016 at 8:44 PM
    geno0506
    geno0506 New Member
    Michael
    Dumb question,
    Can I put a TRD sway bar on my 2017 CM 4X4 CM before I put a new suspension, tires and wheel or would it be best to way being the truck will be leveled or would that matter.
    Would it help any now, before I get the level and wheels!
  3. Dec 14, 2016 at 9:04 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't know, but I don't think it will matter, it should be as beneficial with the stock setup or a small lift. ..
    geno0506 likes this.
  4. Dec 14, 2016 at 9:11 PM
    GNX6
    GNX6 New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
    The extra washers are to be used only if you don't have a factory hitch. They are to provide the extra thickness needed for the links to be in correct position if the hitch is not there
    geno0506 and MotoTundra like this.
  5. Dec 14, 2016 at 9:59 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You can install it anytime. It's gonna help stock or smallish lift.
    geno0506[QUOTED] likes this.
  6. Dec 14, 2016 at 10:16 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks
    I plan on a 2 - 2 1/2" front level, about the stance on the PRO
  7. Dec 14, 2016 at 10:17 PM
    geno0506
    geno0506 New Member
    Michael
    I have the Toyota tow package!
  8. Dec 14, 2016 at 10:18 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You'll just end up with 4 extra washers. I've got the tow package too.
    MotoTundra and geno0506 like this.
  9. Dec 14, 2016 at 10:19 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks for the help, was the install easy! I did the TRD PRO dual exhaust without a lift or shop, did it in the driveway on my back, what a bitch but I did it!
    sorry didnt mean to high jack this tread!
  10. Dec 14, 2016 at 10:21 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No worries. Glad to be of assistance.
  11. Dec 14, 2016 at 10:46 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yup. It's easy. I did mine in my driveway at night with a work light. I took my time following the directions, it was a breeze. I heard of some having a hard time removing the frame bolts, so I used a breaker bar right from the start on them, they loosened up no problem.
    geno0506[QUOTED] and 831Tun like this.
  12. Dec 15, 2016 at 12:22 AM
    geno0506
    geno0506 New Member
    Michael
    Thanks, I'll get a breaker bar, I bought the torque wrench for the TRD exhaust but didn't know how to use it so I just went old school and tightened by sense lol
    MotoTundra[QUOTED] likes this.
  13. Dec 15, 2016 at 5:48 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    If anyone wants a rear sway bar on a bigger lift like 6"-8". You can send the two end links to ekstrom designs and he will extend them for the additonal lift. He usually charges $75 for this but you will need to repaint or re powder coat them after he is done. I did this on my truck and I still notice the difference of having the rear sway bar on my 7" lifted truck.
  14. Dec 15, 2016 at 6:31 AM
    ToyotaTundraMike
    2015 Tundra
    Got my sway bar on order and its already supposed to be here tomorrow (thanks Roman).
    Pondering whether I want to go ahead and throw it on there myself in the next few weekends whenever I have some spare time or just let Toyota put it on there @ my upcoming tire rotation in a few weeks.
    Any special tools needed for this job? How long should it take me in beers? 1-2-3?
  15. Dec 15, 2016 at 6:43 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    1 beer. 19mm, 22mm and a good breaker bar. Easy job! And a torque wrench.
  16. Dec 15, 2016 at 7:38 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    If you still have the torque wrench you can always loosen all the bolts a bit, then correctly torque them in the right order.
    It's easy, we can explain how to use it. I know we did in another thread, not sure who started the thread, if it was you, disregard.
  17. Dec 15, 2016 at 8:03 AM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Just go down to your local harbor freight, buy an electric impact wrench for like $40-$50 bucks, I use it all the time,.great for taking your wheels on and off especially during winter (winter wheels). It takes 5 seconds each to get the 2 frame bolts off. The rest of the time should only take you 30 mins or so, it's so easy. Don't pay toyota If you don't have to.
    Also you don't even have to take your wheels off to remove the frame bolts, I just jacked up the truck a little and access was super easy.
  18. Dec 15, 2016 at 8:10 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's good advice. I have an air impact wrench but rarely use it for small jobs like this because I don't want to fill up the compressor for something that I can quickly do by hand. If I had an electric one I bet I would use it more often, saving time.
  19. Dec 15, 2016 at 8:37 AM
    #49
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I bought one last year to change the tires on one of my trailers and it made the job easy. Now I use it all of the time (used it to remove the tow hooks when I installed my TRD Pro Skid Plate and the frame bolts for the Sway Bar). Very handy.
  20. Dec 15, 2016 at 10:04 AM
    #50
    bigoltater
    KC
    Leveling Kit,33'BFG
    I to had straighten out the truck bed (major OCD) since toyotas QC is so stellar, the impact wrench was so nice to loosen them up so fast. It's definitely money well spent. How's the skid plate install going chuck BTW.
  21. Dec 15, 2016 at 10:08 AM
    #51
    geno0506
    geno0506 New Member
    Michael
    Thanks Moto, I did start it,
    I do have a impact for my compressor!
    But I brain is like scrambles eggs trying to figure it out, lol I tried to set it to the N-fab and trd exhaust specs but don't think I did so I just tightened till it felt right.
    I probably will stop by a auto zone or shop and have them show me.
    If you have time, I can PM you if thats ok I just cant seem to get it, lol!
  22. Dec 15, 2016 at 11:16 AM
    #52
    MotoTundra
    MotoTundra The Ocho
    Don
    No problem. This 8 minute video should do the trick. I know it's 8 minutes but it's probably less time than driving somewhere.
    https://youtu.be/AriiR1i0DmI
  23. Dec 15, 2016 at 11:31 AM
    #53
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Done. Last hardware kit was complete and install is done (finally). I do have some extra bolts now and can send that middle one to you if you need it. PM me your address and I'll send it to you.
    Here's what is in the kit:
    and installed plate:
    bigoltater[QUOTED] likes this.
  24. Dec 15, 2016 at 11:49 AM
    #54
    geno0506
    geno0506 New Member
    Michael
    Thanks brother!
  25. Mar 8, 2020 at 8:58 AM
    #55
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    Installed an A.R.E. Cap on my truck yesterday. Weighs about 200 lbs. Extra up top weight has really increased body roll. Thinking of installing trd rear sway bar to help. Any thoughts?
  26. Mar 8, 2020 at 10:02 AM
    #56
    GNX6
    GNX6 New Member
    2014 Crewmax
    the extra washers I think were to shim the frame mounts if you did not have a hitch.
  27. Mar 8, 2020 at 10:05 AM
    #57
    GNX6
    GNX6 New Member
    2014 Crewmax
    The sway bar is a great upgrade even without the cap. I load the heck out of my truck and it does great. BFCF165C-1EBC-4216-BB39-AB1ED25D8373.jpg
    Paulismydog[QUOTED] likes this.
  28. Mar 8, 2020 at 10:31 AM
    #58
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats and will a future upgrade! Thx.
