Trd rear sway bar fit 4.6 Tundra
Discussion in 'Suspension' started by Bigjoe7757, Jun 2, 2018.
  1. Jun 2, 2018 at 3:40 PM
    Bigjoe7757
    Bigjoe7757 [OP] New Member
    2021 Tundra CrewMax TRD Sport
    Hi folks, when I was going to order a trd rear sway bar for my 4.6 SR5 CM the description said for 5.7 models only. I searched the forum and the web to see if anyone had installed on a 4.6 truck to see if it would work but didn’t find anything. My concern is the 4.6 comes with the 9.5 rear rather then the 10.5, maybe the axel tubes are the same and it would fit without an issue but I’m trying to get some info before I order. Thanks in advance for any information.
  2. Jun 2, 2018 at 4:09 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I cant see what they wouldnt. But sure someone chime in. Good luck
  3. Jun 2, 2018 at 6:01 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Ask @Roman. The parts guru!
    Bigjoe7757[OP] likes this.
  4. Jun 2, 2018 at 6:05 PM
    Nick T
    Nick T New Member
    Nick
    The 9.5 axle tubes will be smaller, the u bolts and bracket are designed to fit the 10.5 snugly. You may have to fabricate a spacer to get the u bolts and bracket to fit. There are threads left on the u bolts once installed on a 10.5 so it might fit the 9.5 without modifications but if it does not fit snugly then any movement while the vehicle is in motion will reduce the effectiveness of the sway bar.
    Pudge and Bigjoe7757[OP] like this.
  5. Jun 3, 2018 at 4:45 AM
    camion2012
    camion2012 New Member
    2012 Tundra 4.6
    It fits fine on my 2012 4.6...I like it.
    Bigjoe7757[OP] and Black Wolf like this.
  6. Jun 3, 2018 at 4:50 AM
    Bigjoe7757
    Thanks this was why I was looking for , someone who had done this upgrade. No issues with the axel tubes being smaller or anything?
  7. Jun 3, 2018 at 4:56 AM
  8. Jun 3, 2018 at 5:00 AM
    camion2012
    2012 Tundra 4.6
    Nope, no problems at all. I just wish they were painted black!
  9. Jun 3, 2018 at 5:02 AM
    Bigjoe7757
    Thanks for yours and everyone’s comments and help.
  10. Jun 20, 2018 at 3:21 PM
    Bigjoe7757
    Installed a rear trd sway bar on my 2018 4.6 CM today with out an issue. Fit perfectly. The axel tubes must be the same diameter. Thanks again everyone for your comments
    TxLock21 likes this.
