TRD Pro with Toyo R/T Tires
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Cohiba262, Jan 9, 2016.
  1. Jan 9, 2016 at 12:27 AM
    Cohiba262
    Cohiba262 [OP] New Member
    Daniel
    2019 Toyota Tundra TRD Pro
    Anyone runnings Toyo R/T Tires with stock set up on TRD Pro? Looking to swap out stock tires however the sizing doesn't appear to be the same as M/T 295/70R18. Not sure if its possible with the sizes they have!?
  2. Jan 9, 2016 at 9:37 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    35x12.50's on a near stock Off Road the wheels have a different offset then the stock. And I think your taller then mine so I don't see a problem with it.
    Flying Yota and dcsleeper408 like this.
  3. Jan 9, 2016 at 11:31 AM
    Cohiba262
    Daniel
    The Toyo R/Ts are .3" taller and .7 wider than M/Ts. Not sure if want to be the guinea pig on this one.
  4. Jan 9, 2016 at 12:16 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    Those are the R/T in the picture 35x12.50 they larger and wider then the tire your thinking of and fit. You are far from a guinea pig
  5. Jan 9, 2016 at 12:39 PM
    Cohiba262
    Daniel
    Any rubbing issues? Do you believe there will be any on a stock set up of a TRD Pro??
  6. Jan 9, 2016 at 2:13 PM
    jlee
    jerry
    Bay area CA
    Oh one or two.
    I removed my front splash shields and mud flaps and have no rubbing with normal driving. I touch the cab mount on hard bumps wile turning just a little.
