TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Oct 23, 2022 at 1:26 PM
    #91
    YotaGang0404
    YotaGang0404 New Member
    James
    South Florida
    2022 Tundra SR 4X4
    Good observation, just sold the 2011 and have a 2022 SR that I’m eagerly awaiting for delivery. Need to update my profile info!
    I was inquiring for the new truck which comes without fender flares. Aside from different wheels and tires, I know fender flares would be a big appearance enhancement and would love to get some of the flares if they bolt up easily enough.
    GODZILLA[QUOTED] likes this.
  2. Oct 23, 2022 at 1:43 PM
    #92
    18" TRD Off Road Wheels
    Ah, that explains it. Thank you, I learned something today. I didn't know the SR didn't have the flares. I thought all the 3rd gens did, and the Pro just got wider ones. :thumbsup:
    YotaGang0404[QUOTED] likes this.
  3. Oct 23, 2022 at 4:23 PM
    #93
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    Well just like you they sent me 2 of the same flares. They sent me 2 for the front instead.
    I have all the lights wired and ready but now have to wait for the correct side.
    ryanwgregg and iiawah808 like this.
  4. Oct 23, 2022 at 4:43 PM
    #94
    Prohit
    Prohit New Member
    It was dark when I got home but these should give you an idea
    D873BB45-BA71-4683-95F8-10CEBF6D4FEB.jpg BC71117D-1A3B-44E2-8BD3-FB28434AAEBF.jpg 54378003-45C4-4E59-ADBB-104429E1EFAC.jpg
    =JSG=, Yaboy, Carguy912 and 2 others like this.
  5. Oct 24, 2022 at 4:47 AM
    #95
    curttel
    curttel New Member
    Thanks!!
  6. Oct 24, 2022 at 6:43 AM
    #96
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Any word on the front amber markers and light bar part #? I'm sure those are under tight wraps
  7. Oct 24, 2022 at 6:53 AM
    #97
    Prohit
    Prohit New Member
    Marker lights part # is 81730-YY010 22165
    nothing comes up when searching unfortunately. There is still the bracket that holds the marker lights. I am on the hunt for that or will just make my own.
  8. Oct 24, 2022 at 6:59 AM
    #98
    Prohit
    Prohit New Member
    Agreed. The tailgate comes as a whole although those LEDs are different. But like you said, very doubtful they will be sold individually.
    ryanwgregg likes this.
  9. Oct 24, 2022 at 6:59 AM
    #99
    Prohit
    Prohit New Member
    awesome. Not cheap but great there’s an oem solution.
  10. Oct 24, 2022 at 8:10 AM
    #100
    curttel
    curttel New Member
    Same thing happened to me. They sent me two left front flares. The 102 was in the box for the 002.
    I open the boxes at the dealer and discovered it.
    They are trying to order me the correct one.
    We'll see.
    Buellride[OP] and ryanwgregg like this.
  11. Oct 24, 2022 at 9:13 AM
    #101
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Ryan, this is fantastic....I have to assume that the part number: 90980-12416 is JUST the plug connector(female) and you will have to order the pins as well? Or could we be lucky and that part number includes everything?
  12. Oct 24, 2022 at 9:29 AM
    #102
    Buellride
    Olympia
    THE BOULDER
    I completely agree with you Ryan, though I cannot fully justify spending $600 to get an OEM harness solution when undoubtedly it will require some splicing anyway into an existing harness or into the fuse box. Since I am only going for the flare marker lights and not the "raptor" front or tailgate lights...that is a little steep.
    Decided that spending $38 or so for the OEM connectors with pigtail is a worthy "experiment" over trying to do a DIY version. I ordered 4 of these:
    Home » Shop » Connectors / Harnesses » Sumitomo » 2 Way TS 025 Plug Connector Pigtail for ABS Applications 90980-12416 (bmotorsports.com)
  13. Oct 24, 2022 at 9:33 AM
    #103
    Buellride
    Olympia
    THE BOULDER
    Fair enough, you know much more than me :thumbsup:. I am just trying to get the "cool guy" lights running (eventually).
  14. Oct 25, 2022 at 8:23 AM
    #104
    Prohit
    Prohit New Member
    So I received the second set and AGAIN received 2 of the same front drivers side. Can someone please confirm the correct part number for the passenger Side front?
  15. Oct 25, 2022 at 8:45 AM
    #105
    Buellride
    Olympia
    THE BOULDER
    I had the same problem but with the rear fender flares. @Prohit I already installed the front fenders on my truck (minus the wiring) so I can't tell you what the part number is on the inside...SORRY.
    I am checking with the dealer later this afternoon regarding my *new*/correct fender flare.
    These were the original part numbers on my order (I got the correct fronts)
    PT8713422002 1 $ 75.00 TUN FENDER FLARE BLK
    PT8713422302 1 $ 75.00 TUN FENDER FLARES BL
    PT8713422102 1 $ 75.00 TUN FENDER FLARE BLK
    PT8713422202 1 $ 75.00 TUN FEN DER FLARES B
    Carguy912 and ryanwgregg like this.
  16. Oct 25, 2022 at 9:02 AM
    #106
    Prohit
    Prohit New Member
    Both of these are the front part numbers
    PT871-34221-02
    PT871-34220-02
  17. Oct 25, 2022 at 9:03 AM
    #107
    Prohit
    Prohit New Member
    This was 2 different orders from 2 different dealers and they screwed up the same flare. I was hoping to have at least 1 complete set.
  18. Oct 25, 2022 at 10:18 AM
    #108
    curttel
    curttel New Member
    Was the wrong part in the box? I got a 102 (the left front) in the right front (002) box. Interestingly the 102 box had a 102 in it.
  19. Oct 25, 2022 at 3:10 PM
    #109
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    I hope this doesn’t happen to my order. I just placed an order and was notified by the parts department that they are on a national backorder. He asked if I still wanted to place the order. “Yes please!” Now the wait begins.
  20. Oct 25, 2022 at 3:18 PM
    #110
    Buellride
    Olympia
    THE BOULDER
    Went to my dealer to pick up the 2nd attempt at the rear flare.....I have the rear left hand/drivers side fender but needed the right hand rear flare. No joy, once again, the part number on the outside of the box was the correct part number but the fender inside was the left rear flare. Evidently there is a problem with the distribution center on the west coast.
    To my local dealers (Toyota of Olympia) credit, they will be contacting the distribution center directly (supposedly there 9 of them on hand) and have them OPEN the box and CONFIRM that the correct fender is inside the box PRIOR to shipping.
    More to follow.....On another note....
    Confirmed that the part number 90980-12416 is the correct plug for the TRD Pro marker lights. The only thing you need to do is pin it yourself....OR go the route I did and order the plug, pre-pinned and pigtailed from a 3rd party. The cost of the pre-pinned and pigtailed plus is $1 more than just the plug from Toyota. I get them tomorrow and will post pics (if they work).
  21. Oct 26, 2022 at 3:35 PM
    #111
    Buellride
    Olympia
    THE BOULDER
    The 90980-12416 is NOT the correct plug for the marker lights....disregard. The pin placement is correct but the plug itself is about 7 mm "tall" and it needs to be 5mm
  22. Oct 26, 2022 at 4:38 PM
    #112
    Buellride
    Olympia
    THE BOULDER
    Not the end of the world....I actually shaved down the plug to fit into the housing of the light. What a few bucks bought me was a well-made female pinout with insulation properly installed and a very positive fit into the housing (once you Dremel tooled down the outer housing of the connector). You do end up destroying the purchased plug....there is that.
    I mocked one of the rear lights up, tapped into the *green* wire of my LED headlights, grounded the other wire and the marker lit perfectly. I am going to shrink tube the plug once it is finally installed into the light to make it fully water tight.
    Going to return the Tap-A-Fuse, pin connector kits, crimper, etc. to Amazon. This is a MUCH better solution. I should have both front fenders wired and complete tomorrow.
  23. Oct 27, 2022 at 9:10 AM
    #113
    Buellride
    Olympia
    THE BOULDER
    One side finished...tapped into the green headlight wire (DRL), shielded and wrapped all wires and connections. Grounded into a screw near the brake modulator. Rewrapped all connections and zip tied. I know the hot lead needs to be better protected.
    Green1794, =JSG=, Carguy912 and 5 others like this.
  24. Oct 27, 2022 at 9:56 AM
    #114
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    So how much wider are the Pro flares?
  25. Oct 27, 2022 at 10:32 AM
    #115
    Buellride
    Olympia
    THE BOULDER
    Stock fenders are about 3/8" and the Pro flares are 1 1/2"....definitely helps with +X offset larger tires and the poke. Basically makes the "poke" disappear.
  26. Oct 27, 2022 at 6:17 PM
    #116
    twinturbo94
    twinturbo94 New Member
    2022 Tundra
    Would you have a picture of your fender without the flares installed by chance? I have an SR and want to see if the fenders are the same (the SR trim doesnt have flares at all)
    YotaGang0404 likes this.
  27. Oct 29, 2022 at 10:24 AM
    #117
    23trdarmygreen
    23trdarmygreen New Member
    Cody
    On order 2023 army green trd sport
    I know this is probably not the correct thread for this, but does anyone know the part# for the camo pattern front bumper cap piece. Having trouble finding it. Thanks
  28. Oct 29, 2022 at 12:11 PM
    #118
    Prohit
    Prohit New Member
    53931-0C230
  29. Oct 29, 2022 at 12:50 PM
    #119
    CamsRetriever
    CamsRetriever New Member
    Roseville, CA
    2022 Platinum CM MGM
    Did the Pro come with fender liners? If so, does someone know the part numbers?
  30. Oct 29, 2022 at 1:50 PM
    #120
    Prohit
    Prohit New Member
    you have a platinum, is yours missing?
