TRD Pro towing travel trailer
Discussion in 'Towing & Hauling' started by Tdalk458, Nov 24, 2020.
  1. Jul 27, 2021 at 6:30 PM
    #61
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Why is there so much trailer in front of the first axle?
  2. Jul 27, 2021 at 6:53 PM
    #62
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    What price did you get quoted for the trans cooler?
  3. Jul 27, 2021 at 8:40 PM
    #63
    Tdalk458
    Tdalk458 [OP] New Member
    Tom
    2021 Lunar Tundra TRD Pro
    I didn’t dial in the WDH. I was just generally testing on a friend’s trailer.
    They quoted me $675 for install if I provide the kit. Haven’t looked into the kits yet so I’m open to suggestions on that. I’m waiting for another quote as well. Do kits for prior years work or is there one made for 2021’s?
  4. Jul 28, 2021 at 3:29 AM
    #64
    Clemsonman14
    Check out the genuine cooling systems kit put together by one of the members here. Almost all Toyota oem parts. Runs close $1000 for the full kit. The kit works for all 2019-2021 where the cooler was removed.
    https://www.tundras.com/threads/tundra-transmission-cooler-kit.60550/
    diablodalton and bflooks like this.
  5. Jul 28, 2021 at 4:29 AM
    #65
    bflooks
    bflooks New Member
    Metrowest MA
    Genuine Cooling Systems is the go to solution for us 19+ owners. I'm towing an 8k lbs trailer and it keepa my temps 25-40 degrees cooler than without it. 200-215 max on long climbs.
    Seems a 4-5 hour install is the average for shadetree mechanics. Do what you wish with that information when shopping installation costs.
    diablodalton likes this.
  6. Jul 28, 2021 at 10:18 AM
    #66
    crewmaxlmt
    scott
    $675 to install a cooler is way too much. Where are you located?
  7. Jul 28, 2021 at 10:40 AM
    #67
    Tdalk458
    Tom
    I figured so as that was was from the local dealership, Capitol Toyota. I’m in Salem, OR. I called another local mechanic to see what they would charge and am waiting to hear back.
  8. Jul 28, 2021 at 10:47 AM
    #68
    crewmaxlmt
    scott
    I installed mine myself and it took me way too long. I could do it in probably three hours now, even less if I had a lift. I know somebody in Oregon City that would install it for around $200 if you are interested.
  9. Jul 28, 2021 at 10:51 AM
    #69
    Tdalk458
    Tom
    Awesome, thanks! I will definitely let you know. Any recommendations on kits?
  10. Jul 28, 2021 at 11:00 AM
    #70
    crewmaxlmt
    scott
    I went with Nick's kit from Genuine Cooling Systems. The only thing that it not factory is the cooler.
  11. Sep 21, 2021 at 9:39 PM
    #71
    Tdalk458
    Tom
    Just wondering if anyone with a Pro (preferably ‘19-‘21) has any experience towing travel trailers? What was your experience like?
  12. Sep 22, 2021 at 4:27 AM
    #72
    AircareTundra
    AircareTundra New Member
    JT
    Yes. 2020 Pro. Added shackles to the rear to help with any squat. Use an equalizer WDH to tow my trailer which weighed in about 6500 pounds. Truck is much more stable platform than my 2015 Silverado 1500 was. I normally use manual S4. And I also leave the tow/haul button on. Truck pulls fine. I have no idea about transmission temps but have never seen any warning lights while towing on the hills of the east coast. Love the truck!!
  13. Sep 22, 2021 at 4:29 AM
    #73
    AircareTundra
    JT
  14. Sep 22, 2021 at 4:55 PM
    #74
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I believe the transmission warning light doesn’t come on until around 300F. I would highly recommend getting something like a Scan Gauge to monitor both of the transmission sensors.
    Tdalk458[OP] likes this.
  15. Sep 22, 2021 at 6:27 PM
    #75
    AircareTundra
    JT
    Excuse my ignorance.......but I see your suggestion and I have also read some of the other posts on this forum regarding monitoring Trans temps etc...etc...
    My question is this:
    Is this stuff totally plug and play into the trucks port where they plug in to obtain codes etc....etc.....or do I have to place sensors somewhere within the closed system of the transmission, torque converter, drain pan etc...etc...?
    Thanks for any intel for the mechanically uninclined.
  16. Sep 22, 2021 at 9:55 PM
    #76
    A-A-Ron
    Aaron
    Seattle
    The Scan Gauge I had just plugged into the port. Used the Velcro from the kit to mount it on my steering column. The hardest part was finding the right codes to plug in. It will be reading from the two sensors that are already in the transmission. I believe there is a thread on it somewhere on this forum.
  17. Sep 23, 2021 at 7:12 AM
    #77
    Blue Thunder
    Washington
    I have the ScanGauge II and love it. E8D33698-5C83-467F-B1F3-95ACC28A8EF1.jpg
    Top left is the tranny pan temp, top right is the torque converter temp.
    jordoncloutier likes this.
  18. Sep 23, 2021 at 7:30 AM
    #78
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    I had the daystar cradles on my Tacoma and loved them. Full articulation... my buddies gave me a hard time before we went wheeling and after they saw the rig in action they were very impressed. I had zero limitations with the cradles. That said... I was a little tired of checking air and bought the "Roadmaster's Active Suspension" which also received great reviews from my Tundra Buddies. I tow a 3500lb OPUS 4 off-road trailer that has a fully articulating hitch, which is not compatible with hitch distribution systems. My other Jeep Buddy has a pretty cool hitch distribution system where the springs sit on top vs. below for better ground clearance. (just thought I would share that)
  19. Sep 24, 2021 at 9:48 AM
    #79
    MuscleGeek
    MuscleGeek New Member
    Mark
    2021 Tundra TRD Pro
    Hello. I read through the thread and didn't see my exact (or close) situation. I bought the PRO and am waiting for an Opus OP2 to be delivered. Single axle off road popup camp trailer. I plan on dispersed camping over some pretty rough roads...
    Specs are:
    I am told the camper will handle anything the truck can. Any advise for the truck?
    TIA!
  20. Sep 24, 2021 at 10:02 AM
    #80
    TRDSPEC
    TRDSPEC New Member
    21 Pro is worse at towing than the 16 SR5 TRD I had.
    I don't tow a large travel trailer but a boat with trailer that probably together weighs 7000lbs. Pro was darty, bouncy, and just did not handle the load well due to cushy suspension. The 16 SR5 towed this same boat like it wasn't there.
    Added firestone airbags and rear swaybar to the Pro and the problems are now solved. But this is for a medium sized load. If it wasn't a boat I might have went the weight distribution hitch route.
  21. Sep 24, 2021 at 12:20 PM
    #81
    Tdalk458
    Tom
    That’s my dilemma. Part of me thinks I’ll be ok with just the WDH (5000 lb trailer) but the other part thinks I should air bags just in case. Of course, I don’t want to spend money on them if I don’t have to. I haven’t had a chance to tow a trailer with the proper set-up to test it.
  22. Sep 24, 2021 at 12:21 PM
    #82
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Do you carry stuff in your bed when towing?
  23. Sep 24, 2021 at 12:38 PM
    #83
    Tdalk458
    Tom
    Not much, most of the stuff would be in the trailer. Probably not more than 200 lbs in the bed.
    I’ll be renting a trailer. Single axel Keystone, 5000 lbs gross.
  24. Sep 24, 2021 at 2:16 PM
    #84
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    in my experience, thats the difference in my decision to add sumo springs for towing my trailer. The WDh doesn’t account for the stuff in the bed. With firewood, camp gear, coolers, and the bikes, my bed load is around 500-600lbs. So the sumos take care of that and then the wdh does it’s thing. Prior to the sumos, my truck sagged too much for my liking. The wdh alone would have been plenty if I didn’t load down my bed with other gear
    My truck is leveled btw
  25. Sep 24, 2021 at 3:23 PM
    #85
    Tdalk458
    Tom
    Great to hear, thanks! I called my local Les Schwab and they can install Firestones or Airlift for about $700. I may do that just in case since it’s not too much.
  26. Sep 24, 2021 at 6:44 PM
    #86
    TRDSPEC
    TRDSPEC New Member
    Installation is 700? Do it yourself if you have some basic tools it's pretty easy.
    Don't forget to add the daystar cradles mentioned earlier.
    Tdalk458[QUOTED][OP] likes this.
  27. Oct 19, 2021 at 11:49 AM
    #87
    DrunkytheMonkey
    DrunkytheMonkey New Member
    RJ
    Jacksonville, FL
    2021 TRD Pro CM in Lunar Rock
    I am late to this party but my experiences may help someone down the line. I tow a 2021 Casita travel trailer that is ~3200 with 400# hitch weight. I installed the blue sumo springs (30 minute job) and the Anersen WDH. It tows a dream with a couple hundred pounds in the bed.
    I went with the Andersen WDH as it allows me to back up without fiddling with the WDH and its easy to adjust and GREASE FREE!
  28. Nov 17, 2021 at 11:23 AM
    #88
    Tdalk458
    Tom
    Hey all, just wanted to shoot out an update after my hunting trip. I was very impressed by my truck’s performance. Here are my thoughts on the items I was concerned about:
    Power- I never once felt like it didn’t have enough. I used tow/haul and had it in D the entire trip.
    Transmission- I did not have a temp. gauge or external cooler but was not worried about it. The highest ambient temp we went through was probably in the lower 50’s. I never smelled any hot fluid like odors.
    Trailer sway- We went through the Columbia River Gorge, which can be very windy at times, and I never once had any sway issues. I did have a sway bar on the trailer.
    Weight- I had a WDH and tried to adjust it best I could. We had quite a bit of weight in the bed of the truck (generator, propane tank, etc.) so it squatted quite a bit and caused the WDH bars to hang pretty low. They were probably only about 3” off the ground! We definitely hit when coming in and out of parking lots and a few times on some uneven terrain in the area we hunt. I went through a truck scale and have posted a photo of the axel weights below. I’m not sure if they are within specs so any feedback on that is very much appreciated. I’m pretty sure I was a little over weight on payload but combined weight was well within capacity.
    Conclusion- Other than the squat, I had no issues so I am now confident that all I need are air bags to eliminate the squat. I definitely feel better about towing. Any feedback is always appreciated!
    AircareTundra likes this.
  29. Nov 17, 2021 at 11:39 AM
    #89
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Looks like you're about 500 lbs over your GVWR. Any idea what your trailer GVWR is? Moving the stuff from the bed of the truck to the trailer (directly above the axle or slightly forward of it) would help both with GVWR/payload and squat. (I wouldn't put it behind the axle as that could affect stability.)
    I can't recall offhand what the rear axle rating of our trucks is. Sure you're not over it? Sticker inside the driver's door.
  30. Nov 17, 2021 at 12:25 PM
    #90
    Tdalk458
    Tom
    Trailer GVWR is 5000. My plan was to put more stuff in the trailer over the axle but it was a rental so I didn’t want to put the generator, propane tank and chain saw in there (potential spillage/leakage issues). That was about all we had in the truck besides my dad, myself and my rifle and maybe 50 lbs of clothes/gear.
    Payload is pretty weak at a little over 1000 pounds. Door sticker says 1235 and 137 in factory installed accessories. I also have a bed cover that weighs about 60 pounds.
    Looks like I’m good on front axel weight but about 110 over on rear.
    We weren’t quite sure what all we would need to bring with the trailer rental, since we were used to the old trailer we owned, but I think we could shed some weight and leave some items home.
    Now, if we shoot an elk, that’s a different story!
