TRD Pro Tolerable Daily Driver Build
Discussion in '3rd Gen Builds (2022+)' started by 4wd TRD PRO, Aug 12, 2022.
  1. Aug 12, 2022 at 2:30 PM
    4wd TRD PRO
    4wd TRD PRO [OP] New Member
    Just wanted to share with y’all some unique mods to make this rig a great daily for myself. I say for myself because I’m function>form usually but this truck is so damn nice that I’m working on being more function=form for this build.
    Taco-Spike likes this.
  2. Aug 12, 2022 at 2:46 PM
    Taco-Spike
    Two Trucks
    Welcome!
  3. Aug 12, 2022 at 3:04 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Why would you sea foam a brand new truck?
    Taco-Spike and Occidentalis like this.
  4. Aug 12, 2022 at 3:25 PM
    4wd TRD PRO
    First up is the Toyota bed extenders, both the old school and new AMPish ones. They work great as extenders and they work great folded into the bed keep your stuff like groceries, supplies and tools from sliding around the bed. Now on to the crappy part. If you have a awkward load or a bunch of shit then often you can’t use the bed extender either way. I have found myself strapping it down with a separate strap to the top of whatever load I am caring and I have also put it in the back seat numerous times. It often reminds me of the Dyno ribs that flipped the Flintstones car over. Now having owned 14 Toyotas and Two raptors I came to the conclusion that the Ford bed extender is the best. So I installed one into the Tundra because…well because I do things like this all the time. Try to make something good even better.
    First off I took the ford bed extender and sized it up and sure enough it will fit sizes wise. Then i took the factory Toyota bed extender adaptors out of the truck, measured, drilled out the rivets, makes the center where I wanted to mount the ford bed extender to it and then drilled the Toyota adaptors out to hold the bolt that ford used to screw into their actual bed.
    After that I got some nuts that would fit ford bolts, then I cut some off the threaded ends the ford bolts off so they would stick out past the Toyota brackets just enough to hold the new nuts. After that it was cake! Now keep in mind I mounted it 3/4 of an inch higher so that when they finally make a BedRug for the tundra the extender will fit perfectly flat.
  5. Aug 12, 2022 at 3:26 PM
    4wd TRD PRO
    Sea foam is a color we use to have on a Lexus LX. The new lunar rock color reminds me of it so that’s what I call it.
  6. Aug 12, 2022 at 3:50 PM
    MadMaxCanon
    Haha I bet I'm not the only one to make that mistake
  7. Aug 12, 2022 at 4:52 PM
    4wd TRD PRO
    I had to look up what “putting sea foam in your car” entailed……..Fixed. Lol
    MadMaxCanon[QUOTED] likes this.
  8. Aug 12, 2022 at 8:45 PM
    MadMaxCanon
    Too funny
  9. Aug 15, 2022 at 5:29 PM
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    I call it CeMINT. It’s like cement…but minty. LoL
    That said, my LR with red interior Pro is on the truck heading for my dealer now. :cool:
  10. Aug 31, 2022 at 5:00 PM
    4wd TRD PRO
    Just installed a tailgate table from Allpro Off-road. So nice to be able to sit a drink down or use it as a work bench.
    Roctane84 likes this.
  11. Aug 31, 2022 at 5:24 PM
    Roctane84
    Roctane84 Tread On Them
    Louisiana
    ‘22 TRD Pro Solar Octane (SOLD)
    Hey, thats actually pretty useful. I like it.
  12. Jul 14, 2023 at 6:05 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    I bought VLED for the rear. Wondering how they match the OEM blue
