TRD Pro suspension vs. Toytec 3-1
Discussion in 'Suspension' started by veg hed, May 26, 2016.
  1. Jun 1, 2016 at 5:23 PM
    veg hed
    veg hed [OP] Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I completely agree...I'm sure the Pro will be fine with what I'm going to do with my truck. I really like to look of the Fox and I've read a lot of good stuff about them but it will probably be overkill for what I'm doing, which is occasional off road. The price for the Pro suspension is daunting. :(
  2. Jun 7, 2016 at 6:42 AM
    veg hed
    veg hed [OP] Thug
    Utah
  3. Jun 7, 2016 at 6:55 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    No experience with either but @jberry813, @jlee both have Kings and seem to be happy with them.
  4. Jun 7, 2016 at 7:20 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The OME BP-51 looks like a great suspension setup for the tacomas and 4 Runners. The price is high though.
    Icon and King are the best but looking at the two kits here the King is the better of the two with the rear 2.5 with resi.
  5. Jun 7, 2016 at 8:12 AM
    veg hed
    veg hed [OP] Thug
    Utah
    Yeah, I don't have much experience with Icon or King but it seems like people are happy with them. The Kings with the resi not only look bad ass but the price is comparable to the TRD Pro suspension. I might pull the trigger on one of these set ups this week so some last minute research will help.
    And yeah, I've kind of been nerding out over @jlee BAMF build thread. He is doing a lot of stuff I want to do with my Tundra.
  6. Jun 7, 2016 at 9:43 AM
    csuviper
    Broomfield, CO
    There are progressive, linear, and digressive shocks.
    • Progressive shocks start out soft and get stiffer quickly as the shaft speed increases.
    • Linear shocks uniformly increase stiffness as the piston speed increases. It is similar to the progressive valving but does not make dramatic changes at higher speeds.
    • Digressive is just the opposite of progressive. It starts out stiff, then it tapers off.
    Icon is digressive and King is progressive
    FirstGenTundra and TheBeast like this.
  7. Jun 7, 2016 at 8:35 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    With Fox, King and ADS you can rebuild/ re-valve your own shocks. I believe the Pro would have to be sent in for any changes but it's sweet from what I've read. There's someone selling theirs $1,700 at Tundra Classified on Facebook.
  8. Jul 3, 2016 at 7:08 PM
    TheBeast The Beach
    hoping for BOSS kit v2.0 with reservoirs..I think that will be the kit I'll get when they release it.
    Law323 and T-Rex266 like this.
  9. Aug 29, 2016 at 11:28 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I have fox 2.5 resi coilovers and 2.0 rear resi shocks love the set up I'm at 3.25-3.5 lift up front using a shim with very little preload I'd go with fox or king before pro suspension any day.
  10. Aug 31, 2016 at 2:04 PM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    Custom Rock rails, ARE truck cap with Rhino-lining
    The Pro suspension is a 2.5 inch lift in the front with a 2 inch lift in the back. The difference makes it level, but it's still a short lift (that's covered by the factory warranty) but it still gives you more than a stock Tundra.
    Having said that, I've found that the shocks are VERY soft and when there is some weight in the back (in and around 800 lbs or more), you can see it dip noticeably.
    I'm looking at either adding an air bag leveling lift or swapping out the rear shocks to the ICON shock system that allows me adjust the shock for when I have cargo
  11. Aug 31, 2016 at 4:25 PM
    xtyfighterx
    Ty
    North Idaho
    Pro is only 2inch lift up front nothing in the rear
  12. Aug 31, 2016 at 5:29 PM
    Jamyers13183
    Jamyers13183 New Member
    Houston
    Fixed it for you
  13. Sep 1, 2016 at 11:57 AM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    Guys I don't know what to tell you..I got my 2016 TRD Pro in May and it's a 2.5 in the front with 2 in lift in the back as stock and Yes, I've put it side by side with a regular Tundra and the difference is obvious.
