TRD Pro Squatting
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by alpinepro4, Apr 25, 2018.
  1. Nov 16, 2019 at 6:14 PM
    #121
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    :popcorn:
    Rica25 likes this.
  2. Mar 28, 2020 at 4:19 PM
    #122
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    Just an update, I went the same path with the Allan springs and installed them today. I have a pro that I added an ARE Z shell and decked system and it had sag. With the new springs it raised it exactly an inch just like the guys at Allan said it would.
  3. Mar 28, 2020 at 4:21 PM
    #123
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Started at 38 1/4 and ended at 39 1/4
  4. Aug 22, 2020 at 10:51 AM
    #124
    Rafer73
    Rafer73 New Member
    Rafe
    2015 black tundra trd pro dc
    Did you add CB shackles like OP?
  5. Aug 22, 2020 at 11:06 AM
    #125
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    No. I’m gonna see how it settles after some time to see if I want to lift it more or not. When I had them build the springs I told them I wanted 1” of lift and gave them my approximate payload.
    bmw345 likes this.
  6. Aug 22, 2020 at 11:19 AM
    #126
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The coachbuilder shackles ride so much smoother than OE, the 1 inch lift is worth it even if you don’t want it
    DZ_ and Beesta like this.
  7. Aug 22, 2020 at 6:19 PM
    #127
    MGM
    MGM New Member
    Shackles seem like the least expensive and most effective for the rear sag. But I just can’t get over the fact that if the truck is raised like at an auto shop or off-roading, then the leaf pack will hit the exhaust. The reason I haven’t installed them and always reminded when I look my truck rear sag.
  8. Aug 22, 2020 at 8:40 PM
    #128
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    .62 inch of lift isn’t too noticeable. I cut my tailpipe off though so I don't know how close that would have been
  9. Aug 22, 2020 at 8:51 PM
    #129
    Glennjermin
    Glennjermin New Member
    Glenn
    2014 Toyota Tundra SR5 Crewmax 4x4
    Icon Add A Leaf springs Bilstien 5100 shocks Freedom Off Road UCAs Snugtop rebel camper shell Prinsu Roof Rack Decked System
    What I did to get rid of my squat because I have quite a bit of permanent weight in the back, I went with the Icon Progressive AAL's. They did the trick and are a good buy in my opinion
  10. Aug 25, 2020 at 7:08 AM
    #130
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    My setup is similar to a pro and with my FWC it now squats and it sits directly on the Timbrens all the time. I’m looking to switch to a load supported by the leaf springs not a bump stop approach.
    Kinda putting three price point options on the table.
    Alcan spring replacement and toytec shackle
    dobinsons/OME/icon replacement and toytec shackle
    Custom leaf spring created from cutting down another oem set (I have a friend who did this for his tundra and he’s willing to do it for mine) and toytec shackle.
    Then would consider a rear sway bar if handling characteristics were still wanting.
    Hoping to sell the Timbren after this upgrade.
    My load consists of 1,000lb camper full time and then loading up my wife and toddler for the weekends with all our camping gear.
    Thanks for any insight provided.
  11. Aug 25, 2020 at 7:50 AM
    #131
    gosolo
    Ray
    NW Oregon
    I also have a constant static load of around 1100lb. For short term, I used icons helper packs. Toytec and Deaver both gave me very bad recommendations when I was doing research, which I did for about 2 years. Alcan fabricated custom leaf sets that compensate for the fact that I have about 300 more pounds on the driver side than the passenger side. Recommend Alcan in the strongest way.
    The big concern I’d have about doing that back yard custom set up, is the lack of engineering. You might hit it perfectly or you could end up too stiff or still a bit saggy. I almost went that route myself.
    jewsNbrews likes this.
  12. Aug 25, 2020 at 10:32 AM
    #132
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    How does the change in shackles result in a smoother ride?
    hagrid likes this.
  13. Aug 25, 2020 at 10:38 AM
    #133
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I put in for a quote. Looks like alcan would be 820+200 shipping. Lots of good reviews on this site, but google has a lot of dissatisfied reviews that have a common tune.
  14. Aug 25, 2020 at 10:58 AM
    #134
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    the poly bushings are stiffer than the oe rubber and they don’t have teeth cut into the side of them (have to see the oe insides to view).
    the idea is that the coachbuilder shackle is stronger and has better bushings, so it operates smoother and allows the spring to flex more naturally
    DZ_[QUOTED] likes this.
  15. Aug 27, 2020 at 10:59 AM
    #135
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Weighed the rig today...
    7420 Gross
    3500 steer
    3920 drive
    hopefully this helps get the right springs. Thinking 1” lift and weight help. Alcan comes with polybushings. I may not change shackle because I have 35” tire in stock location.
  16. Aug 30, 2020 at 5:13 AM
    #136
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    You guys are overthinking this issue. The TRD PRO by design sits VERY level, actually too level. The easiest and cheapest way to fix the problem is by using taller shackles. This way you maintain the factory ride, and pick the ass up from 1-3 inches, depending on your needs. I went with Pro Form Fab +1.5 shackles for towing my boat. Perfect solution, rides great, looks great, tows great, nothing to wear out, no issues whatsoever. For less than $100 my PRO sits exactly how I wanted to, about 1.5" higher in the rear. BOOM, easy fix.
  17. Aug 30, 2020 at 6:28 AM
    #137
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Except for the fact that if you add a shell and some other weight in the bed the truck will sag and flatten the springs. At that point shackles aren’t gonna do the job. A few of us got the springs built to carry the added payload that the stock (weak) Toyota spring can’t handle.
    Skey44 likes this.
  18. Aug 30, 2020 at 6:48 AM
    #138
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Yes, note my constant load. Shackles aren’t gonna help with that.
    I do agree though for stock loads shackles are the easiest way to slightly lift the rear of the truck with few compromises (mostly interference issues, such as certain exhaust systems and a 35” spare tire can definitely get in the way of the shackles with beefy dimensions (CB/aluminum).
    I also agree I am probably overthinking it.
    COTundra23 and Hbjeff like this.
  19. Aug 31, 2020 at 8:09 AM
    #139
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Wanted to update. With the guidance of my FWC dealer, they do not believe I have an issue that requires a custom solution. They recommended Dobinsons (constant heavy load/55mm lift) spring pack. They’ve needed to use custom leafs before but mostly in bigger lifts with heavier loads. They setup a lot of Toyotas with these campers, leaning towards their advice and complete the Dobinsons lift kit with the rear leaf-pack. Also saves a lot of dough and I’d have them next week. Have a trusted installer who quoted an inexpensive labor cost for swap out. Getting close to pulling the trigger :spending:
  20. Aug 31, 2020 at 8:37 AM
    #140
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Epic threadjack opportunity.
    CopFiveO, Huckwheat, GODZILLA and 2 others like this.
  21. Aug 31, 2020 at 8:41 AM
    #141
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Lol
    hagrid likes this.
  22. Dec 20, 2020 at 7:58 PM
    #142
    Petergoose1
    Petergoose1 New Member
    2020 pro army green
    Any updates on alcans, deavers, shackles?
  23. Jan 8, 2021 at 11:32 AM
    #143
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    For anyone who has changed out their leaf pack, shackles, etc. to get additional height, has anyone had issues with their Fox TRD Pro rear shocks? I'm a little concerned that is I get the height up 1-2" I'm going to need a long travel rear setup. I'm not wheeling my track but I do plan on overlanding it on dirt/gravel roads and forest roads with minimal improvements. I'm not wanting to change my rear shocks.
    Bad Cow and Petergoose1 like this.
  24. Jan 8, 2021 at 12:32 PM
    #144
    Bad Cow
    Georgia USA
    Dude, 1-2 inches will not give you a problem with those Fox Shocks.
    Bootleg[QUOTED] likes this.
  25. Jan 8, 2021 at 12:35 PM
    #145
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    Food for thought. Not for everyone but a a good leaf option wit versatile weight options and are ready available right now. Not to expensive either.
  26. Jan 8, 2021 at 12:38 PM
    #146
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    I think this is the route I'm going with CB +1 shackles. I'm going to have a constant load of 500lbs+ and a trailer with a tongue weight of 350lbs. to tow across the country. Fingers crossed my rear shocks can handle it.
    The Juice[QUOTED] likes this.
  27. Jan 8, 2021 at 12:47 PM
    #147
    t-rey1
    t-rey1 New Member
    I added the Roadmaster springs and on the regular setting it got .5" lift in the rear
    H0s5WmkiHahDi9n0_GeLgryejpNXfRfbea6P1UNS_73b8eb7e638d3bc635f39e94cef7b3bfec5ec45c.jpg
  28. Jan 8, 2021 at 12:48 PM
    #148
    The Juice
    COLORADO NATIVE
    Which rear shocks are you running?
  29. Jan 8, 2021 at 1:21 PM
    #149
    Bootleg
    Bootleg New Member
    Brandon
    2020 MGM TRD Pro
    Stock Fox shocks. With my constant load I'm expecting just about 2-2.5" rear lift with Icons set to option 3 with the CB +1 shackles. Best I can figure, anyway. I've been getting analysis paralysis on this for three months now.
  30. Jan 20, 2021 at 8:42 PM
    #150
    Honz
    Honz New Member
    Black 2020 Pro CM
    Decked system Garmin Mini with Dongar Technologies adapter Nitto Exo Grappler 285/70R18 OEM Power Tailgate Lock OEM Black Door Sill Protector Center Console Organizer
    So I have had two independent shops tell me the Fox suspension is “position sensitive” and they don’t recommend lifting the rear end much more then an inch above factory height.
    Has anyone here heard this before?
