trd pro headlights
Discussion in 'Lighting' started by Jasejaven, Aug 23, 2016.
  1. Aug 23, 2016 at 8:48 PM
    Jasejaven
    Jasejaven [OP] New Member
    Can anyone tell me if the trd pro headlights will directly fit into my 2016 tundra sr5 crewmax? also where I can get them at a good price? thank you all.
    Headlight Revolution likes this.
  2. Aug 23, 2016 at 9:26 PM
    ToyotaTundraMike
    2015 Tundra
    Roman likes this.
  3. Aug 23, 2016 at 9:29 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    +1 Yes and talk to Roman.
    Roman likes this.
  4. Aug 23, 2016 at 9:32 PM
    Yep
    Roman likes this.
  5. Aug 23, 2016 at 10:54 PM
    Jasejaven
    you guys are awesome! much appreciated. Ill be posting my build soon.
  6. Aug 24, 2016 at 6:18 AM
    I have it on my truck :spy:
  7. Aug 24, 2016 at 6:30 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Exactly...
    Roman likes this.
  8. Aug 24, 2016 at 6:47 AM
    ToyotaTundraMike
    2015 Tundra
    Gonna be adding some of these myself in the next few weeks, does anyone know if you have to set the leveling motor inside the truck to a certain position before swapping out the headlights or does it automatically adjust the new headlights to the setting that your leveling motor is currently on?
  9. Aug 24, 2016 at 6:50 AM
    Just leave as is and line up the beams on the lights when installed.
  10. Aug 24, 2016 at 6:57 AM
    ToyotaTundraMike
    2015 Tundra
    I haven't seen whats behind these headlights yet, are you saying I will be able to look at the old ones that come out and tell which position the new ones need to be on? I know I'm probably over-thinking it, just not sure how the motors actually work.
  11. Aug 24, 2016 at 7:07 AM
    You're over thinking this.
    Just put the new headlights in and aim the lights if the beams are uneven.
  12. Aug 24, 2016 at 7:21 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I did have to raise mine using the off white colored adjuster on the back of the headlight housing. Before removing my SR5 lights I marked my cutoffs with my stock lights, then installed the PRO lights, with truck in same spot I checked the new cutoff, which was lower. I'll assume Toyota aims the PRO lights lower due to the lift on the PROs.
    I marked where my tires were with sidewalk chalk, used masking tape on the wall in my garage for the cutoff.
    Sometimes the driver's side is lower, that's for oncoming traffic, you can keep it like that if you want.
  13. Aug 24, 2016 at 8:23 AM
    ToyotaTundraMike
    2015 Tundra
    Thanks guys!
  14. Aug 24, 2016 at 10:21 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  15. Aug 24, 2016 at 3:03 PM
    Jasejaven
    Is this for the pair. it looks like its just for the left light.
  16. Aug 24, 2016 at 3:52 PM
    Mine will be up for sale shortly ;)
  17. Aug 24, 2016 at 3:54 PM
    Jasejaven
    how much were you thinking?
  18. Aug 24, 2016 at 4:08 PM
    I'll PM you
  19. Aug 24, 2016 at 4:09 PM
    Jasejaven
    ok... im new to this. whats a pm. im sorry smh
  20. Aug 24, 2016 at 4:12 PM
    Private message. I just sent you one. Check your inbox
  21. Aug 24, 2016 at 4:15 PM
    Jasejaven
    haha got it....
  22. Aug 24, 2016 at 5:21 PM
    JAMES
    JAMES COLORADO TUNDRA
    2016 Colorado Tundra Crew Max MGM
    6" PC Stage II Coil Over 37x12.50x20 Toyo RT 20" Fuel Recoil Wheels N-Fab black Step Bars Splash 5% Window Tinting Clear Mask Protection Premium leather interior with 2-front Heat/Cool seats Viper 5806v Alarm w/ remote start Garmin 2589 Garmin Dash Cam Dual Flo-Pro 3.5 18" Glass Packs Black Chrome exhaust tips Bakflip Bed Cover Weather Tech Floor Mats Bushwacker Pocket style with matching paint TRD Pro Grill Tesla 12.1'' Head Unit Oh Shit handle on Drivers Side Under seating Storage 4.88 Gears NSV LED Light bar Upgraded Sound system with JL Audio Speakers and Sub
    Does the TRD Pro Headlights have the LED bars in them? And if so, does that replace the Yellow DRL's
  23. Aug 24, 2016 at 5:27 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    No, only 1794 and Platinum models have the LED bars.
  24. Aug 24, 2016 at 5:42 PM
    JAMES
    I really like that look with the LED bars. So, are they interchangeable from the 1794 and Platinum, while still utilizing the leveling motor....
  25. Aug 24, 2016 at 5:58 PM
    mdavis
    Michael
    Rock Hill, SC
    No, you can't just swap them in place of the SR5 headlights. You could make them work but you'd have to do some wiring.
  26. Sep 20, 2016 at 8:01 PM
    jay131866
    jay131866 New Member
    Has anyone found these (trd pro) cheaper than $500 anywhere? Ive seen nice aftermarket lights for half that, but ideally i would like the level adjuster to work. Just cant justify spending $500 to get a darker tinted headlight even though i love the look.
  27. Sep 21, 2016 at 6:32 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Have you considered buying a used SR5 set and opening them up/painting them? I've opened mine up for a retrofit and I will tell you it is a pain for sure, but it's a way to save money if you need to.
  28. Sep 21, 2016 at 7:05 AM
    jay131866
    No I didnt really consider that. Ive seen some people use the nightshades tint, but Im not really sure if i want to darken the actual lights. The TRD pro headlights look like they are tinted everywhere but the bulb area and appear darker around, but I havent really seen them up close in person either.
  29. Sep 21, 2016 at 7:10 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Only difference is the bezel is painted black. Lens on the Pro Lights are still clear.
  30. Oct 6, 2016 at 10:45 AM
    jay131866
    Has anyone put on the JDM DEPO Diamond black aftermarket headlights? They are fairly cheap on ebay in the $200's and look really nice but I don't know anything about the brand.
