Trd pro grill and hood bulge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cidthekid, Jan 31, 2016.
  1. Jan 15, 2017 at 6:17 AM
    #151
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    You are correct. I had the same question and @Roman said that they catalog just hasn’t been updated to show 2017.
  2. Jan 15, 2017 at 7:49 AM
    #152
    NJMIke
    NJMIke New Member
    2016 Tundra Double Cab SR5
    Rial cast wheels. Looking for TRD Pro grill with chrome surround
    First time, it took me about 40-50 minutes to remove the existing grill, remove the centers from both original and the new one and switch and reinstall the grill. When you raise your the hood, there are (4) 10mm bolts and (2) plastic fasteners across the top that need removed. After removing, you loosen the top of the grill from the truck then, from the bottom of the grill, pull out each side straight towards you. Keep the bottom of the grill from resting on the bumper below so you don't scratch the black plastic piece on the bumper like I did. This is all good practice since removing the grill is the best way to replace headlight bulbs and fog light bulbs. I've removed mine several times and it now takes me less than 5 minutes. Also be careful when removing the center to avoid breaking some of the plastic clips molded into the parts. Don't worry it you do snap 2-3 of them since there are more than enough to hold the parts securely even at highway speeds. Even the dealers manage to break them sometimes.
    NewImprovedRon likes this.
  3. Jan 15, 2017 at 7:59 AM
    #153
    cbrock01
    cbrock01 New Member
    2017 Silver Sky Tundra 4WD
    @NJMIke Thanks for the prompt advice. Judging from your truck picture. You have the same mod I have in mind. Looks great!
  4. Jan 15, 2017 at 8:10 AM
    #154
    NJMIke
    NJMIke New Member
    Since that picture was taken, spring 2016, I had a guy run a stop sign as I was crossing the intersection and I T-boned him at low speed. One of the headlights, the grill and most of the bumper was damaged and need replaced. Had the body shop replace both headlights with the TRD Pro headlights, the hood bulge & main grill with surround painted to match my truck. What the hell, someone else was paying for it and those parts in painted finish VS chrome were actually a little lower in cost. Only chrome on the front of the truck now is the center of the headlight and the bumper ends.
  5. Jan 16, 2017 at 7:02 AM
    #155
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That is correct. The entire grille must be purchased as that is the only way Toyota will sell it.
    I used a small flat head to remove the surround from the insert, and had it apart in about 5 minutes without breaking anything the first time I swapped them. It's not hard, you just have to be as gentle as you can to not break a tab. Even if you do break one or two, it's not a big deal.
    NewImprovedRon and Bigmoo like this.
  6. Feb 1, 2017 at 12:54 AM
    #156
    ant-13
    ant-13 New Member
    2015 Tundra TRD Off Road
    @Roman Is it true that the TRD grille is now available in barcelona red with the 2017 models. I have a 2015 SR5 in barcelona red and really love the look of the TRD grille and am thinking about getting one but would want it to be color matched. Would this one fit on my 2015? Thanks for the help!
  7. Feb 1, 2017 at 6:22 AM
    #157
    Roman
    Roman
    Franklin, TN
  8. Feb 3, 2017 at 9:17 PM
    #158
    Momo
    Momo New Member
    kal
    2017 Pro
    none yet
    hi Roman..Is there anyway I can get Doors handles color matched(Blazing Blue)?
  9. Feb 6, 2017 at 7:12 AM
    #159
    Roman
    Roman
    Franklin, TN
    Sure, I can have a set painted for you. Shoot me a PM with your email address and if your truck is a double cab or Crewmax, and I'll send you a quote.
  10. Feb 10, 2017 at 12:53 PM
    #160
    Mehoff
    Mehoff New Member
    Definitely one of the threads I'm looking for. Just picked up (or on the truck now) a 2015 platinum Tundra that needs some love. Want to put the TRD Pro grill on it, but don't want color matched. Anyone know if they make matte black, or if the color matched black looks okay against a gray car?
    Also, any leads on a place to get it in Los Angeles; the shipping from Cool Springs is a killer.
  11. Feb 10, 2017 at 3:48 PM
    #161
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    According to many other Toyotas sites the Bulge Assembly Hood 76180-0C030-C1 is Black Mica but Cool Springs with the same part number is black 202. I am so confused.
  12. Feb 11, 2017 at 5:33 AM
    #162
    Roman
    Roman
    Franklin, TN
    Toyota does not make any of the grilles in flat black.
    76180-0C030-C1 is the part number on the black hood bulge with paint code 202.
  13. Feb 17, 2017 at 12:22 PM
    #163
    sdstahl
    sdstahl New Member
    Roman, is the Toyota insert a different color of black than the surrounding grill and grill bulge for the 202 color code?
  14. Feb 17, 2017 at 2:13 PM
    #164
    Roman
    Roman
    Franklin, TN
    They look like this:
    The insert is a flat black color, and the surround is painted.
    Patriot and NewImprovedRon like this.
  15. Feb 17, 2017 at 4:15 PM
    #165
    sdstahl
    sdstahl New Member
    Thank you Sir. Is the grille still not available in Attitude/midnight black?
  16. Feb 17, 2017 at 6:54 PM
    #166
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
    I just ordered a 202 black pro grille from you today. Are these in stock? I didn't see any sort of stock indicator when ordering. Hell... maybe the pic of the one you posted above is on its way to me. :D
  17. Feb 17, 2017 at 7:17 PM
    #167
    07tacoswb
    07tacoswb New Member
    2016 Super White Tundra Crewmax XSP-X
    I got my shipping notification for my super white pro grille today. I'll have it Tuesday. Can't wait. Thanks Roman.
    Roman likes this.
  18. Feb 18, 2017 at 9:58 AM
    #168
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    I just got a 17 Tundra last night. Does the pro grill come color matched in Quicksand? Thanks guys.
  19. Feb 19, 2017 at 8:43 AM
    #169
    fcs1965
    fcs1965 New Member
    are the inferno pro grills on back order?
  20. Feb 19, 2017 at 10:20 PM
    #170
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    Yes it comes color matched in Quicksand. I've had mine for about a month now.
    Tacotundra[QUOTED] likes this.
  21. Feb 20, 2017 at 7:54 AM
    #171
    white offroad
    white offroad New Member
    Anthony
    North Carolina
    So White is back in stock @Roman ?
  22. Feb 20, 2017 at 2:53 PM
    #172
    Roman
    Roman
    Franklin, TN
    Correct, at least not from Toyota. I can have it painted for you, though.
    No sir. They are all still on back order. I am getting them quicker than I had been, though. It's only taking 1-2 weeks now, where last month it was 3-4 weeks.
    It sure does. :D
    Pretty much all of them are, unfortunately.
    Not quite yet. All of the ones I have been getting in have been ordered by someone already.
  23. Feb 20, 2017 at 8:06 PM
    #173
    Tacotundra
    Vegas
    2022 Tundra
    @Roman will be contacting you soon. Thanks
    Roman likes this.
  24. Feb 21, 2017 at 3:12 AM
    #174
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    Received mine last night and put it on, took maybe 20 minutes for both.
    Barcelona Red. Thanks Roman!
    Roman likes this.
  25. Feb 21, 2017 at 11:37 AM
    #175
    Boodles07
    Boodles07 New Member
    2017 DC OFF ROAD Quicksand
    Does any of this void the warranty? Guessing dumb question?
  26. Feb 21, 2017 at 11:50 AM
    #176
    OldmanTundra
    OldmanTundra New Member
    2016 Magnetic Gray Tundra, (Platnium)
    None Yet
  27. Feb 21, 2017 at 12:15 PM
    #177
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    If you do let me know I might want yours.
  28. Feb 21, 2017 at 12:48 PM
    #178
    Roman
    Roman
    Franklin, TN
    No sir. :)
  29. Feb 21, 2017 at 6:41 PM
    #179
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    No, they are played out IMO.
    PapaGrizz, joem1cha3l and Newm like this.
  30. Feb 21, 2017 at 7:05 PM
    #180
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I think your truck looks great like that ! A unique grill is always a good thing.(especially when it looks good)
    15whtrd and AnonVet like this.
