Trd pro grill and hood bulge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cidthekid, Jan 31, 2016.
  1. May 9, 2016 at 8:22 AM
    #91
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I can definitely get them for you. Just shoot me your email address in a PM, with the info on the truck (parking sensors or no, CM or DCB) and I'll get a quote over to you.
  2. May 12, 2016 at 7:34 PM
    #92
    Proth
    Proth New Member
    Preston
    2016 Tundra 1794
    Nice thank you. Yes the chrome is crapola. I want to do the TRD PRO grill too and hood bulge.
  3. May 15, 2016 at 9:49 PM
    #93
    Tundra2016
    Tundra2016 New Member
    Luis
    2016 Black Tundra Limited
    TRD Pro Grill, NFAB Nerf Bars
    I have a 2016 Limited Crewmax. I was told that the TRD Pro grill would not fit my vehicle because the TRD Pro grills are a bit more narrow than the OEM on my Tundra. Is this correct? If not how do I go about getting one in black to match the color of my Tundra?
  4. May 15, 2016 at 10:03 PM
    #94
    15whtrd
    15whtrd Mr. Blonde
    You were misinformed it will fit
  5. May 15, 2016 at 10:10 PM
    #95
    Tundra2016
    Luis
    that's what I thought but just wanted to double check. Thanks for the reassurance. Where did you get yours?
  6. May 16, 2016 at 6:05 AM
    #96
    Ya. It'll fit fine.
    Hit up @TRDSparks or @Roman
  7. May 16, 2016 at 9:34 AM
    #97
    Roman
    Roman
    Franklin, TN
    Yep, it's the same part. Let me know if you want to grab one.
  8. May 16, 2016 at 11:03 AM
    #98
    Tundra2016
    Luis
    How much? Is it the two piece (grill+ insert above)?
  9. May 16, 2016 at 5:57 PM
    #99
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    If you're talking about blacking out just the middle insert then I believe your cost would be $250.02 plus shipping. If you're talking about removing all of the chrome then you're talking about $250.02, and another $183.15 for the black hood bulge plus shipping.
  10. May 16, 2016 at 6:03 PM
    #100
    Tundra2016
    Luis
    Thanks for the info
  11. May 20, 2016 at 8:56 PM
    #101
    r4z0r51o
    Dave
    Before ...
    After ...
    Loving my new look!
    darkknight2014, Roman and 15whtrd like this.
  12. May 21, 2016 at 2:12 PM
    #102
    15whtrd
    15whtrd Mr. Blonde
    Looks good bud!
    r4z0r51o likes this.
  13. Sep 23, 2016 at 10:01 AM
    #103
    Clayphace
    Clayphace New Member
    Lumberton, Tx
    Does anyone have pictures showing the differences in the "blacks" from the stock black color and the trd pro black color?
  14. Sep 23, 2016 at 12:50 PM
    #104
    Roman
    Roman
    Franklin, TN
    They're the same paint code, 202. The Platinum and 1794's are painted Attitude black which is paint code 218.
    NewImprovedRon likes this.
  15. Oct 2, 2016 at 8:36 PM
    #105
    McLovin
    McLovin New Member
    Harry
    Maryland
    17' QS CM Limited, 14' MGM T4R SR5 Premium,
    @Roman can you get quicksand? I think it's 4V6. Thanks.
  16. Oct 3, 2016 at 7:02 AM
    #106
    Roman
    Roman
    Franklin, TN
  17. Oct 3, 2016 at 7:08 AM
    #107
    McLovin
    McLovin New Member
    Harry
    Maryland
    Roman[QUOTED] likes this.
  18. Oct 3, 2016 at 12:01 PM
    #108
    Roman
    Roman
    Franklin, TN
    No problem. The easiest way to get a shipping quote is to add them to your cart, and then input your zip code for the quote. If I had to guess, it will probably be around $65.
  19. Oct 3, 2016 at 1:34 PM
    #109
    McLovin
    McLovin New Member
    Harry
    Maryland
    Ok, great. Thanks for the info. Talk to ya soon.
  20. Oct 17, 2016 at 12:57 PM
    #110
    tony919
    tony919 New Member
    tony
    Freehold NJ
    2014 Tundra Platinum CM
    Id like the trd pro "TOYOTA" for my truck I have a 2014 tundra platinum so the surround is already painted the truck color....is the trd just plain black plastic? what would I need?
  21. Oct 17, 2016 at 1:02 PM
    #111
    Roman
    Roman
    Franklin, TN
    In your case, all you would need is the Pro grille itself, nothing else. What color is your truck?
  22. Oct 17, 2016 at 1:10 PM
    #112
    tony919
    tony919 New Member
    tony
    Freehold NJ
    I have the black metallic...it has a blue speckle to it....is it something I can do myself? Do you have a video of it being done to follow? THANKS
  23. Oct 17, 2016 at 1:18 PM
    #113
    Roman
    Roman
    Franklin, TN
    You can definitely do it yourself. All you would need is the Pro grille, which you can buy here:
    http://parts.toyotaofcoolsprings.com/oe-toyota/531000c260c0
    I don't have a video, but it's not difficult to do. There's four screws on top of the grille you'll need to remove, along with two plastic clips on the ends of the top part of the grille. Then, you'll pull the entire grille assembly toward you to remove it from the truck. It's held in by several clips on the beck of the bottom portion of the grille. Once you get it off, remove the four screws on the back of the grille. This is where it gets tricky. You'll have to pry the tabs apart from the back of the grille that hold the insert and the surround together. Just be careful as they can be brittle and break. Do the same thing to the Pro grille, swap the surrounds over, and do everything in reverse.
  24. Oct 17, 2016 at 1:26 PM
    #114
    tony919
    tony919 New Member
    tony
    Freehold NJ
    can you work on the shipping cost...its 65 bucks :eek:
  25. Oct 17, 2016 at 1:55 PM
    #115
    Roman
    Roman
    Franklin, TN
    Shipping is typically based strictly on the size and weight of the box, which it's a big box, accidental damage insurance, and how far away you are. However, if you use the code SHIP20 at checkout, it will give you 20% off of shipping (~$13). It's a big box, so it costs quite a bit to ship.
  26. Oct 19, 2016 at 6:24 PM
    #116
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
    @Roman I see your the dude to talk to about parts!! :)
    NewImprovedRon and T-Rex266 like this.
  27. Oct 20, 2016 at 6:12 AM
    #117
    Roman
    Roman
    Franklin, TN
    Something like that. :D
  28. Oct 25, 2016 at 6:12 AM
    #118
    GayFish
    GayFish Member
    2016 Super White SR5 CM 5.7L 4X4
    @Roman Is there a part number for just the PRO Grill insert, without the surround? Guy on craigslist near me is selling a SR5 style grill with the white surround and bulge for $150.
  29. Oct 25, 2016 at 7:22 AM
    #119
    Roman
    Roman
    Franklin, TN
    No sir. The Pro grille is only sold as an assembly with the insert and painted surround together.
  30. Oct 27, 2016 at 8:20 AM
    #120
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Is there a hood bulge from Toyota that comes in the Silver Sky color that doesn't need to be painted? No chrome.
