TRD Pro grill 40" light install
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by 1UPPER, Nov 16, 2016.
  1. Nov 16, 2016 at 7:35 PM
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    I thought I would do a short write up for anyone wanting to install a 40" Light bar in the TRD Pro grill. If you don't mind cutting out the lower opening section of your grill it's a very clean look when done right. I chose to install a 40" Rigid Radiance light for mine. I like the features of having a low light backlight and the main spot lights on the radiance lights. You should be able to use another brand of light if the measurements are the same though. This install is fairly simple and you only need to use two 2" long bolts, spacers, locking washers and center bracket to stiffen the light for the light. You will also need to have a relay, fuse holder and a switch. If you chose the radiance light they sell a special harness separately for their light since it has two switches. IMG_4870.jpg
    Before the light was installed.
  2. Nov 16, 2016 at 7:40 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I went ahead and just used stainless washers for spacers on mine. This way I could keep adding shims to raise my light to the right height for the grill. If you look at the bracket in the photo you can see I notched mine a little bit. This is to help the grill surround sit tighter against the light. I trimmed the grill surround at least five times to make sure it fit very tight. It's easier to trim a little at a time and not have to mess up the grill.
    Watt maker and SuperSilverTundra like this.
  3. Nov 16, 2016 at 7:45 PM
    1UPPER
    TEXAS
    Flux capacitor!
    In the middle of the light bar you will need to install a bracket to stiffen up the light. I used a short self taper on the light bar itself and made sure it went into a fin only and not into the light housing. I will probably change out the back self taper to a bolt with a locking washer. This part of the light bracket is not visible after you install the surround. I did use all Aluminum and stainless parts to avoid rust. IMG_4936.jpg
    Here is the blue backlight after being installed. The blue is definitely not street legal! Lol. I just wanted it to match my wheels and the rest of my build.
  4. Nov 16, 2016 at 7:46 PM
    1UPPER
    TEXAS
    Flux capacitor!
  5. Nov 16, 2016 at 7:53 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The one thing I still need to do on mine is shorten up the center bracket support. My spot light is shooting the light to low at the moment. This will re focus the light up higher and put farther in front when I'm off-road.
  6. Nov 16, 2016 at 9:42 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
  7. Nov 17, 2016 at 5:55 AM
    Great job I have same you plan on doing one on bumper? Rough country makes a 30 inch single row with brackets for that spot ordered mine other day
  8. Nov 17, 2016 at 9:15 AM
    mjime714
    mjime714 New Member
    Michael
    Montebello, CA
    2017 Tundra CrewMax TRD Pro - Cement
    N-Fab Nerf Bars Toyota All Weather Mats Relentless Fabrication Bed Cargo/Cross Bars (3) WeatherTech Window Deflectors Cobra 75WXST CB Radio with 4' Firestik
    NICE!! Looks great!!
  9. Nov 17, 2016 at 9:39 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    We are currently running our promo still for ours. Buy the Baja Designs bar, get the mounts free. We have 2 bars left. There may or may not be a certain day of the year coming up where stuff is also on sale.
    stefan702 and TRD15559 like this.
  10. Nov 21, 2016 at 11:44 AM
    jwm9289
    jwm9289 New Member
    That looks sweet, where did you tie in the power?
  11. Nov 21, 2016 at 2:28 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I soldiered the wires from the light bar and ran them between the bed of the truck and cab and then along the underside frame into the engine compartment. Inside the engine compartment I have a 100 amp central fuse block off of my battery so I can run all my individual fuses for my lights. Then I ran each individual light control wire to a relay and then the wires from the relay run inside the truck to my switches. If you just want a single light or two you can just purchase a wire harness with the fuse, relay and switch. I made my own wiring harnesses since I'm running so many various lights and controls. I hope this answers your question.
  12. Nov 26, 2016 at 10:14 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Just posting on this for my reference for future install.
  13. Nov 27, 2016 at 1:35 AM
    PermaFrostTRD
    Northern NY
    Link/pics??
  14. Nov 27, 2016 at 2:13 AM
    Google search bar type in rough country Toyota Tundra led light bar kit
  15. Nov 27, 2016 at 2:15 AM
    Type in Google search Toyota Tundra 30 inch led light bar kit I meant
  16. Nov 27, 2016 at 2:17 AM
    Dirty deeds industries sells one that goes in hood bulge and I believe sdhq sells one or jus brackets for bulge
  17. Nov 27, 2016 at 4:48 AM
    PermaFrostTRD
    Northern NY
    What's Google search?
    *wank motion*
    Already was on Rough country's site, buck. No indication on their 30" single row led bar that it was designed to fit in a 2014 tundra bumper. And since you said you already ordered it "for that spot", I thought you'd be able to share a link or post a pic of yours installed.
    But be a knob instead. It's a good look.
  18. Nov 27, 2016 at 5:28 AM
    1UPPER
    TEXAS
    Flux capacitor!
  19. Nov 27, 2016 at 5:35 AM
    PermaFrostTRD
    Northern NY
  20. Nov 27, 2016 at 7:12 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great OP!
  21. Nov 27, 2016 at 8:12 AM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Man, that looks great. love the blue
  22. Nov 27, 2016 at 12:08 PM
    Easy cowboy I'll show hard to so when someone at work I'll post pics n what's Google search u ask hello Google search bar type in rough country Toyota Tundra 30 inch cree LED light bar kit
  23. Nov 27, 2016 at 12:32 PM
    davesnothere
    Dave
    Down South, Texas
    Is that light with the blue also a white light? I can't find anything on rigid site or Amazon, they all say single color
  24. Nov 27, 2016 at 12:42 PM
    NewImprovedRon likes this.
  25. Nov 27, 2016 at 1:41 PM
    stefan702
    stefan702 IG: 702stefan_
    Randy
    Las Vegas
    2015 Tundra TRD Offroad
    IG: 702stefan_
  26. Nov 27, 2016 at 4:19 PM
    1UPPER
    TEXAS
    Flux capacitor!
    No I used the light and hardware that came with the light off Amazon. IMG_5049.jpg
    stefan702[QUOTED] likes this.
  27. Nov 27, 2016 at 4:26 PM
    stefan702
    Randy
    Las Vegas
    IG: 702stefan_
    When you get a chance could you attach the Amazon link for the bar? :) thanks dude
  28. Nov 27, 2016 at 4:28 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The 40" light in the TRD pro grill is a Rigid Radiance light. All the radiance lights have a back light in either blue, green, red, amber or white and then they also have the main spot lights. So you can have two functions to your light. If you want you can legally run white or amber facing the front of the truck and red facing the rear of the truck.
  29. Nov 27, 2016 at 4:31 PM
    davesnothere
    Dave
    Down South, Texas
    Thanks man
  30. Nov 27, 2016 at 4:39 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Every time I try to get the link it sends me to my personal app account. So here is a picture of the light I ordered from Amazon for the hood bulge.
    Watt maker and stefan702[QUOTED] like this.
