TRD Pro Front Camera mounting
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by rag9836, Feb 4, 2022.
  1. Feb 4, 2022 at 3:50 PM
    rag9836
    rag9836 [OP] New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    A while back I purchased the FRAC Harness for the front camera. Finding a good spot to mount the camera was a pain as I didn't want to cut into the grill.
    Any how... had a sub par mount for a while, then found this bracket. It's a perfect fit, not cutting or drilling. By far the best solution for mounting a camera with the TRD Pro grill.
    https://www.yotaleds.com/products/tundra-trd-pro-grille-bracket
  2. Feb 4, 2022 at 5:19 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Have you mounted it up yet? Any install pics?
  3. Feb 4, 2022 at 5:49 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    Yep. Interested - thx. Send pics!
  4. Feb 4, 2022 at 6:44 PM
    rag9836
    Robert
    Riverside, CA
    Just got it… I’ll mount it up tomorrow. Here’s the placement. It’s a perfect fit
    Shadowfax1 and bulldog93 like this.
  5. Feb 4, 2022 at 9:04 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Curious how it mounts I just swapped to this grill and need to find a home for the front camera. Ordered this bracket and another to test fit.
  6. Feb 4, 2022 at 9:19 PM
    rag9836
    Robert
    Riverside, CA
    Comes with a washer that holds it in place
    bulldog93 and reywcms like this.
  7. Feb 5, 2022 at 2:33 AM
    FISHN43
    FISHN43 New Member
    Ohio
    Thats gonna look clean. Nice find!
  8. Feb 11, 2022 at 5:53 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Curious as to what camera you have. And how is the quality of the camera?
  9. Feb 11, 2022 at 10:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    My mount should be here today we'll see how it goes.
  10. Feb 11, 2022 at 11:00 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Thanks, I ordered the one for the '14-'17 gen heritage grille. I'm curious to see how well the camera angle is.
  11. Feb 14, 2022 at 10:37 AM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Just a heads-up. If you use this camera, which seems to be the most common used for the front, it won't work with the yota leds bracket without modification. The threaded shaft of the camera is not long enough to go through the bracket, then grille and then the washer. Also, if you don't use a spacer, the camera is not far enough away from the grille. I had a member make me a 3D printed spacer. I had to drill 2 holes in the bracket and the washer and used longer bolts to make it work. I mounted the camera to the bracket with the included nut. Hope this makes sense.
    NATIKA Backup/Front View Camera,IP69K Waterproof Great Night Vision HD and Super Wide Angle Metal OEM Style Reverse Rear View Backup Camera for Cars Pickup Trucks SUVs RVs Vans (Black)
    And this relates to the TRD Pro grille. Mine is a 2019.
  12. Feb 14, 2022 at 12:27 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    I just got mine in and yeah wont work 2020 pro
  13. Feb 14, 2022 at 12:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Same I mounted it somewhere else for now.
  14. Feb 14, 2022 at 1:19 PM
    g6t9ed
    I don't get mine until tomorrow. You guys are getting me worried.
  15. Feb 14, 2022 at 1:41 PM
    TL TRDPro LR
    Troy
    SoCal/Idaho
    Well I guess I’m out then!
  16. Feb 14, 2022 at 1:49 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    It will work. Just need a spacer. I can send the specs for a 3D spacer if you have a printer or know someone who does.
  17. Feb 14, 2022 at 1:50 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    Can you send me the spacer I can have my buddy make it. Do you have pictures of yours mounted up?
  18. Feb 14, 2022 at 1:51 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
  19. Feb 14, 2022 at 1:53 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    How do you have that mounted on the back?
  20. Feb 14, 2022 at 1:54 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
  21. Feb 14, 2022 at 1:55 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    Looking for the file on the spacer. It was given to me by another member on here.
  22. Feb 14, 2022 at 1:56 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    Im good with that haha. If you have the file for the spacer that would be awesome.
  23. Feb 14, 2022 at 1:59 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    I am trying to find it. I ended up having the member make me one. I have sent him a DM.
  24. Feb 14, 2022 at 8:32 PM
    Badge618
    Badge618 New Member
    Lassen County, Ca
    bulldog93 likes this.
  25. Feb 14, 2022 at 9:03 PM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
  26. Feb 14, 2022 at 9:39 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Be sure to have it printed in PETG or similar material to withstand the elements.
    If you have the regular (non-PRO) honeycomb grill, the YotaLED plate for those grills will work just fine. The spacing on the honeycombs are taller and there's enough room for the camera. On the PRO grill, the honeycombs are shorter/wider, and that's what causes the issue. But the shim gets it pushed out and angled forward a little more and gives good coverage. I've been running it now for over a year and I use the hell out of the front camera.
  27. Feb 21, 2022 at 4:53 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    For those who don't have access to a 3d printer. Does anyone sell these shims?
  28. Feb 23, 2022 at 7:42 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
  29. Feb 23, 2022 at 7:59 AM
    TRDnoob
    TRDnoob New Member
    2013 Platinum 4x4
    I got my buddy to print me the spacer. I had to drill the mount out because I guess they changed the hole size from the one that Rainman designed his for. I just got my bolts in and will probably try and get it mounted this weekend.
  30. Feb 23, 2022 at 8:21 AM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    I don't know anyone that has a 3D printer.
