TRD Pro from Limited
Discussion in '2.5 Gen Tundras (2014-2021)' started by rxdoc1973, Jul 8, 2020.
  1. Jul 8, 2020 at 1:26 PM
    rxdoc1973
    rxdoc1973 [OP] New Member
    2020 Tundra Limited
    Catback Flomaster Outlaw exhaust TRD Gloss Wheels Havoc HS2 Hoop Step Nerf Bars Upgraded Stereo
    I installed a TRD Pro grille on my 2020 limited. The lights immediately came on that I needed to contact my dealer. The dealer looked and spent almost $300 to tell me that I need a different TSS sensor. I’m baffled by this. How many TSS sensors a could there possibly be on a 2020 Tundra? Seems like a waste of engineering to make more than one sensor on a truck when they all do the same thing. I’m completely at a loss. The dealer says I need to spend $720 plus tax to fix it. Toyota gives their same bullshit response of don’t change anything out
    on our trucks. Starting to wish I’d never bought this damn thing. Anybody have any ideas?? I’m completely at a loss. Toyota basically tells me they stand behind their dealers and whatever they say is right. I truly don’t know what to do.
  2. Jul 8, 2020 at 1:29 PM
    Pictures would help.
    What grill did you put on?
    Did you disconnect the battery?
    Can't tell where you mounted the TSS without pictures.
    Dealer is full of BS.
    T500 and Black Wolf like this.
  3. Jul 8, 2020 at 1:32 PM
    Omizzy84
    Omizzy84 Stay strapped or get clapped
    Omar
    New Haven, CT
    2017 White Tundra TRD PRO
    I agree. A bit more detail can help get a solution on this.
  4. Jul 8, 2020 at 1:34 PM
    When I said what grill did you use I meant 2017 or 2019+
  5. Jul 8, 2020 at 1:38 PM
  6. Jul 8, 2020 at 1:53 PM
    rxdoc1973
    2020 Tundra Limited
    Ah my bad. It’s a TRD Pro grille. And I installed it with the factory TSS sensor cover. So both the grille and the cover are Toyota original equipment. I didn’t relocate it put it where it’s designed to go on the pro which is basically the same spot as it was on the limited grille. I can take pics if you want but the grille is a factory TRD pro with the factory cover. I just don’t understand how they’re coming up with multiple sensors and that they can’t calibrate the sensor.
  7. Jul 8, 2020 at 1:56 PM
    rxdoc1973
    2020 Tundra Limited
    And yes I disconnected the battery for at least an hour.
  8. Jul 8, 2020 at 1:57 PM
    rxdoc1973
    2020 Tundra Limited
    I used the 2019+ grille btw.
  9. Jul 8, 2020 at 2:05 PM
    So if you did use the 2019 grill you have to relocate the TSS to the lower spot and attach it to the grill with that cover. It should work without any issues.
    Is anything blocking the sensor cover?
    I would still like to see a picture to rule anything out.
    Silly question, is the plug snapped into place completely?
    rxdoc1973[QUOTED][OP] likes this.
  10. Jul 8, 2020 at 2:08 PM
    rxdoc1973
    2020 Tundra Limited
    Nope nothing blocking it. My dad has been a mechanic for 45 plus years and helped me install it. We installed it exactly like the old one was installed. It’s just in the new location because of where the sensor sets. Is there any way it will reset itself after being driven? I can send some pics in a bit.
  11. Jul 8, 2020 at 2:11 PM
    Go to a different dealership and tell them you sensor is acting up. It should be fixed for free, you used genuine Toyota parts.
  12. Jul 8, 2020 at 2:12 PM
    rxdoc1973
    2020 Tundra Limited
    I definitely did.
  13. Jul 8, 2020 at 2:20 PM
    Omizzy84
    Omar
    New Haven, CT
    Definitely weird since all OEM parts and the grill you chose has the spot for it. Not knowing what the plug looks like did you check it to make sure none of the prongs were bent in the switch?
    rxdoc1973[OP] likes this.
  14. Jul 8, 2020 at 2:21 PM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    u should go back to the dealer and have them refund your money. if u used genuine parts they should be under warranty.
  15. Jul 8, 2020 at 2:27 PM
    rxdoc1973
    2020 Tundra Limited
    Nothing bent. I’m taking it to another dealership. Hoping they can fix it.
  16. Jul 8, 2020 at 2:28 PM
    rxdoc1973
    2020 Tundra Limited
    I called Toyota corporate and they gave me the song and dance about not changing parts out. I’m like they’re genuine Toyota parts. They read me the statement again. It was worthless.
  17. Jul 8, 2020 at 3:42 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    What lights are on?
  18. Jul 8, 2020 at 6:17 PM
    rxdoc1973
    2020 Tundra Limited
    The per-collision system light comes on and says to see dealer. The cruise control fails too.
  19. Jul 9, 2020 at 10:42 AM
    Solace_In_My_Tundra
    Solace_In_My_Tundra New Member
    Out there somewhere
    2020 MGM CrewMax
    Tonneau Cover TRD Pro Grille Bumper Shells Color matched Bulge Bilstein 5100 Ceramic Tint Black Tundra Inlay
    I wonder if the sensor location is lower on the trd pro grille since the trd pro comes with a 2” front lift. Is your truck leveled/lifted? I put a 2019+ trd pro grille on my 2020 SR5 and had no issues but this was after I had installed a leveling kit....I’m sorry for your troubles.
  20. Jul 9, 2020 at 10:47 AM
    rxdoc1973
    2020 Tundra Limited
    It is lower on TRD Pro grille. I’ve got it at a dealership and the tech said he’s done these before so my fingers are crossed he can get it to recalibrate. It’s taking a long time so that’s making me very nervous.
  21. Jul 9, 2020 at 11:03 AM
    316KS_Runner
    316KS_Runner There's no place like...
    Along the CT River
    2019 MGM CM Ltd
    Front 6112 @ 1.9 Rear 5160 | Falken Wildpeak AT3W 295/70R18 | TRD Off Road wheels | Compustar Pro R3 remote start | Baja Designs SAE fog lights | VLEDS V6 Triton Extreme (amber) front turn signals | Hot Tails Option A | 6” stubby antenna | Window tint 15% rear / 35% front | WeatherTech side window deflectors | RCI Front Skid | Talons Garage front and rear CAT Protection
  22. Jul 9, 2020 at 11:10 AM
    rxdoc1973
    2020 Tundra Limited
    I’m glad this is funny to you. I’m stressing out. I had no idea it was going to be such an ordeal to swap out a Toyota OE grille and OE cover. It really isn’t fun. Especially when they’re going to charge me through the nose to fix it if the calibration doesn’t work.
  23. Jul 9, 2020 at 11:25 AM
    Solace_In_My_Tundra
    Out there somewhere
    2020 MGM CrewMax
    is your truck leveled/lifted?
  24. Jul 9, 2020 at 11:39 AM
    rxdoc1973
    2020 Tundra Limited
    No it’s not. My wife couldn’t get in it if it were lifted. She’s got a form of muscular dystrophy and has a hard time getting in as it is.
  25. Jul 9, 2020 at 11:57 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    I believe plenty of people have done this swap. You need a TSS relocation bracket to not get the indication lights
    Black@Blue19 likes this.
  26. Jul 9, 2020 at 11:58 AM
    swank501
    swank501 New Member
    2007 single cab 4x4
  27. Jul 9, 2020 at 12:02 PM
    rxdoc1973
    2020 Tundra Limited
    So does this go on as well as the sensor cover? The tech said he thought he could calibrate it as it was as the sensor fits into the new grille.
  28. Jul 9, 2020 at 12:13 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Hope the tech gets it right for you. Keep us updated.
  29. Jul 9, 2020 at 12:17 PM
    swank501
    swank501 New Member
    2007 single cab 4x4
    The link to the instructions is on the link i posted. Here it is in case you did not see it:
    https://cfe6a278-4ea5-41b5-b0af-19d...d/652824_f8a7e3688a0d46e3b24a6b64fbecc9c1.pdf
    I have not done this, only trying to help with what others have done successfully.
  30. Jul 9, 2020 at 12:21 PM
    rxdoc1973
    2020 Tundra Limited
    The tech at the Toyota dealership in Wichita was able to get it to calibrate. Sounds like he had to do it twice but got it. Thanks all.
    usmealgle, TelemarkTumalo and FISHN43 like this.
