TRD Pro Fox Shocks
Discussion in 'Suspension' started by Navi, Mar 16, 2022.
  1. Mar 16, 2022 at 12:31 PM
    Navi
    Navi [OP] New Member
    2019 CrewMax Limited
    Ordered TRD Pro suspension couple of weeks ago, should be arriving today or tomorrow. Wondering how much I should expect to spend at independent shop to get them installed??
    I found a thread here from 2017 and it was appx $500 on the high side, that included alignment; time to install was 4-5 hours as this is OEM product.
    Is all of that still accurate today? or have rates gone up since that post in 2017?
    My hope is to stay between $400 - $500 total.
  2. Mar 16, 2022 at 12:38 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Should take no more than 2hrs to install (without alignment). I'd expect $200-300 for labor plus $100, so you are about right for what you want to spend. Call around.
    Navi[OP] likes this.
  3. Mar 16, 2022 at 12:45 PM
    Navi
    Cool, thanks.
  4. Mar 16, 2022 at 12:48 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    My quote from independent shop was $1,000, was hoping for 600. Toyota was 1,200. - both said 6hr job.
    Tried to DIY and broke a control arm. So it was 1,200 plus the tow, plus the control arm.
  5. Mar 16, 2022 at 12:54 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Best bet is to call your own actual local places. someone may quote you their mechanic that's a tree shade mechanic at a super low price. next guy may quote you from his privately owned shop that is expensive. around me, ballpark would be about $125/hour. but lots has changed in 5 years
  6. Mar 16, 2022 at 12:56 PM
    Navi
    Was this Dealer or Local shop? sorry to hear about the problem.
    are you happy with the product? would you buy again?
  7. Mar 16, 2022 at 12:57 PM
    Navi
    I'm hearing $140/hr at the Dealer. will be calling to find rates at local shop and will post results
  8. Mar 16, 2022 at 12:58 PM
    1UP
    1UP Truck Gang
    I bought Falcons. Happy with the upgrade. Went with Toyota, but the local shop was 200 less. I figured 200 in savings wasn't worth someone without a brand backing up their work going in and doing it.
    My DIY attempt was awful. I'll never attempt to load springs again.
  9. Mar 16, 2022 at 12:59 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I paid 400 for the assembled front shocks & TRD sway on my Sequoia. The back is super easy on a Tundra, I did all of it myself on my Tundra.
  10. Mar 16, 2022 at 1:00 PM
    1UP
    1UP Truck Gang
    I did my entire Jeep suspension lift, but the shocks were preloaded with the springs.
    Tundra kicked my butt.
  11. Mar 16, 2022 at 1:05 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    When you said independent shop, thats what i referenced. prices at the dealer will be higher generally. but including your price, shop location, and estimated hours/work to be done will help others as well that know how the search function works ( a rare occurrence if we're being honest)
    Navi[QUOTED][OP] likes this.
  12. Mar 16, 2022 at 1:12 PM
    Navi
    I tend to agree but the dealer near me is incredibly expensive. Have not got a quote for this exact work but other work is ridiculously I priced
    1UP[QUOTED] likes this.
  13. Mar 16, 2022 at 1:13 PM
    Navi
    I’ve seen your Sequoia build, good stuff. My wife drives a 2018 TRD Pro Sport
    e30cabrio[QUOTED] likes this.
  14. Mar 16, 2022 at 1:14 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    My guess is you will get quotes around $750
  15. Mar 16, 2022 at 1:14 PM
    Navi
    I will post up the details for sure. And I checked the search bar myself I could only find a couple of posts from 2017 on the specific topic
    Fotnot[QUOTED] likes this.
  16. Mar 16, 2022 at 1:16 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    at least you attempted (and partially exceeded)
    Black Wolf and Navi[QUOTED][OP] like this.
  17. Mar 16, 2022 at 1:18 PM
    Navi
    True, another problem is they are referred to as four or five different things I noticed as inwas searching
  18. Mar 16, 2022 at 1:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Just wondering, why not install it yourself?
  19. Mar 16, 2022 at 1:34 PM
    Navi
    It’s been along time since I’ve worked on vehicles so I guess just apprehensive based on my skill set currently. From what I can tell it’s four bolts on each side on the front and two on each side on the back.
    And I’m sure you’ll laugh at this, I don’t have any instructions to know how to do it. I checked the DIY manuals here but didn’t see anything but I could’ve missed it
  20. Mar 16, 2022 at 1:39 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Well, you've got your UCA that you'll have to remove from your spindle, 4 bolts at the top of your factory coilovers, 1 bolt at the bottom of the LCA, use a 2x4 and push down the LCA to get the coilover out. If the TRD shocks you have are pre-assembled, then you can go ahead and it'll just be plug and play.
    Install the coilovers, get the LCA bolt through the bottom of the coilover, bolt up the 4 top to shock mount, then re-install UCA. Torque to spec and you're done!
    Check this video out:
    https://www.youtube.com/watch?v=hpFb6f8rJjU&list=PLTTVroralTRXMBd5sGM78coFh5sstdTSL
    jhardy1979 and Navi[OP] like this.
  21. Mar 16, 2022 at 1:41 PM
    Navi
    Everything comes pre-assembled on this one. So I’ll have two pieces in the front two pieces in the back ready to bolt.
    i’ll check out the video.
    would be awesome to do
  22. Mar 16, 2022 at 1:57 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I installed my coil overs with a friend's help and I am pretty much a mechanical rookie. It wasn't terrible and there are plenty of good youtube videos and threads here on the forum to help. I did not disconnect my UCA, but did the LCA instead. It made getting things in and out pretty easy and didn't have to worry about supporting the wheel/brakes while doing it.
    I found this thread helpful
    https://www.tundras.com/threads/lcas-won’t-go-back-up.37561/
  23. Mar 16, 2022 at 2:07 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    I charge $400 if everything is already assembled. I don't do alignments, so that would be farmed out or done on your own. But like JonClark said, it is pretty easy to do with help. Believe it or not, the rears are a pain if you don't have the right tools, lol. Main thing to remember is on the front, make sure to remove the sway bar completely and it will be a lot easier
  24. Mar 16, 2022 at 2:11 PM
    Navi
    How long did it take?
  25. Mar 16, 2022 at 2:14 PM
    Navi
    Guessing your not in Atlanta?
  26. Mar 16, 2022 at 2:18 PM
    havasubud
    Earl
    Corona, California
    Nah, I'm in Southern Comifornia
  27. Mar 16, 2022 at 2:22 PM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Fronts probably took 4-5 hours once we got started. Again, I am a rookie at things. The rear took me a lot longer, as i was swapping out shackles as well and both sides were ceased up and took a lot of beating and banging. I could have had the rear done in less than an hour if all i was doing was swapping the shocks.
    I will try to find it, but I was able to find the Toyota service instructions online for installing the TRD suspension and that is what I used during my install. It was really helpful, as it had all the torque specs included.
  28. Mar 16, 2022 at 3:08 PM
    Navi
    Way bigger than expected...
    7FB03118-6041-476E-958A-939DF3BA34BB.jpg C18E55C1-D496-48D3-AE67-745E8681568C.jpg
  29. Mar 16, 2022 at 3:17 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Yup. What he ^^^ said. I just did all 4 corners in my driveway. Had preassembled coilovers (genuine Toyota TRD Off Road) for the front. Had a buddy help. We were maybe 4 hours all in from setting out tools to hands washed and maintenance log updated. I had copies of all the factory service manual exploded diagrams with the torques ready to go.
  30. Mar 16, 2022 at 3:19 PM
    Navi
    4 hours is not bad at all. good savings
