TRD Pro Exhaust Thumping Noise?
Discussion in 'Performance and Tuning' started by CujoTRD, Dec 21, 2020.
  1. Dec 21, 2020 at 10:29 AM
    CujoTRD
    CujoTRD [OP] New Member
    2021 Jeep JL Rubicon 6spd
    Sup guys,
    Anyone notice a "thumping" exhaust noise at low rpm's when driving?
    When I am going ~35mph to ~45mph, in higher gears at ~1000-~1300rpms...the exhaust noise changes to a "thumping" noise almost as if you can hear every cylinder firing. No check engine lights, no rough idle at standstill. It's almost like a combination of a very mild "cammed" V8 and an unbalanced rotating fan blade. Sorry, it's the best I can describe it. I don't know if it's been this way since purchase, but I recently started noticing it...or is this a characteristic of the TRD Pro exhaust? My truck has 2800 miles.
    Thanks.
  2. Dec 21, 2020 at 10:36 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I think what you are experiencing is what some people call the "helicopter" sound that some people have with TRD dual exhaust. I don't have that sound with mine but maybe because I got it used or I just don't hear it?? Some people say it sounds better after the exhaust is "broken in" so maybe try to give it some more time. I'm sure there will be others that can chime in also.
    iHacker and CujoTRD[OP] like this.
  3. Dec 21, 2020 at 10:43 AM
    CujoTRD
    Interesting....so the exhaust needs breaking in??
    Rica25 likes this.
  4. Dec 21, 2020 at 10:45 AM
    tunamac
    tunamac New Member
    2016 CM 4x4
    It doesn’t “need” breaking in to function properly but it will sound different and *potentially* quiet down a bit as you put more miles on it.
    Best bet is to just be patient with it and see if you still don’t like it after 10-15k miles.
    Rica25 and CujoTRD[QUOTED][OP] like this.
  5. Dec 21, 2020 at 10:46 AM
    CujoTRD
    I guess I just need to drive it more....doh.
    Rica25 likes this.
  6. Dec 21, 2020 at 10:48 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Certainly sounds like you're describing the "helicopter" sound - which is a trait of the true dual exhaust. It does tone down a bit as the exhaust breaks in. My experience was about 2000 miles, but you're past that (at 2800 miles) so I don't know how much more it will tone down for you. I tried an H pipe and tailpipe resonators - documented in the thread below. I eventually sold it to another member and went back to single, because I didn't like the choppiness that you described/are experiencing.
    https://www.tundras.com/threads/added-h-pipe-and-resonators-to-trd-exhaust.49886/
    Rica25 and CujoTRD[OP] like this.
  7. Dec 21, 2020 at 10:51 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I have the same sound with mine and added a h-pipe just forward of the mufflers and that eliminated the helicopter sound.
  8. Dec 21, 2020 at 10:54 AM
    CujoTRD
    Thanks for replies! So, this is normal, nothing to be concerned about? I don't mind it if it's normal, just as long as nothing is wrong or potential issue.
    Rica25 likes this.
  9. Dec 21, 2020 at 10:56 AM
    BassBlaster
    BassBlaster New Member
    Jay
    2016 silver 1794
    Bilsteins front and rear
    Mine is at 68K miles and I barely notice the exhaust anymore. When I first bought it I felt like I couldn't even talk over it lol. Wouldn't know without hearing yours but I bet it's fine
  10. Dec 21, 2020 at 11:00 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    Completely normal - acoustics of true duals.
  11. Dec 21, 2020 at 12:20 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    The helicopter sound has reduced a lot for me, I have about 3500km on the truck now, that I also added intake, not sure the intake helped or not.
  12. Dec 21, 2020 at 12:28 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    That's what a true dual exhaust sounds like when sitting in the vehicle. Stereo V8 left bank and right bank doing it's thing.
    10TundraSR5 and CujoTRD[OP] like this.
  13. Dec 21, 2020 at 12:42 PM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    I got used to it when I had it on my 19. I swapped it to my 21 and it quieter to me. Its get better with time.
  14. Dec 21, 2020 at 1:42 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    I have never noticed a any odd sounds on the two tundras with TRD exhaust I have owned.
    What I have noticed is they get a little louder and deeper the longer they are on the truck, most exhaust get louder with time as they burn in.
  15. Dec 21, 2020 at 2:30 PM
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    Yes, it is a common "trait" of the TRD dual exhaust. My theory is that is because of the side exit tips, creating an alternating "thump". Especially noticeable at low rpm and under mild load. Some hate it and replace. Others like me think it sounds like a symphony! I can't hear it enough.
  16. Dec 21, 2020 at 4:40 PM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    The uneven firing order and lack of a crossover (H or X pipe) to merge and balance the 2 banks creates the sound. I did like the throatiness of the TRD duals, but I spend a lot of time in the 55 to low 60 mph range and the choppy resonance got tiring to me. But I totally understand why people like the TRD exhaust.
    RitcheyRch likes this.
  17. Dec 21, 2020 at 5:02 PM
    PotentPotables
    Washington
    I drove Subaru's most of my life until the Tundra. The TRD exhaust is Subie unequal length header nostalgia from my perspective.
    RainMan_PNW likes this.
  18. Dec 22, 2020 at 2:37 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    I don't have the TRD Pro exhaust but have a buddy that has it on his truck. When I ride in his truck I definitely hear the "helicopter" sound from the exhaust (which is why I went with the DD 10" BAMF system). The TRD Pro exhaust reminds me of when you're riding quads in a group and two bikes have the same exhaust and they start resonating with each other and you get almost an echo or repeating sound between the two exhausts.
    @PotentPotables mentioned Subaru's unique bup, bup, bup sound. I loved that sound in my old WRX, but not sure I could handle the whop, whop sound from the dual exhaust on the Tundra.
  19. Dec 22, 2020 at 3:13 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Give me one more and I can throw together a dank dub step beat for all to enjoy.
    Perhaps a wub wub from a misaligned wheel spacer mod?
  20. Dec 22, 2020 at 3:32 AM
    OnespeedTRD
    Don
    San Diego
    How about a woo, woo from a whistle tip?
  21. Dec 22, 2020 at 3:42 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    First mod on my truck. Helped reduce the excessivly loud fan on startup.
    hagrid likes this.
  22. Dec 22, 2020 at 4:48 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Lol!!
  23. Dec 22, 2020 at 5:50 AM
    Bronzeback
    Bronzeback New Member
    Mine didn't go away after 15-20k miles so I replaced it with Corsa. No drone, no helicopter.
  24. Dec 22, 2020 at 6:24 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    The added h-pipe on mine seems to be working but then I haven't driven it much since adding it. If the drone and/or helicopter sound is still there I will go with either Corsa, Borla or back to stock..
    Bronzeback[QUOTED] likes this.
  25. Dec 22, 2020 at 11:27 AM
    CujoTRD
    Don’t get me wrong, I don’t hate the noise (actually sounds like a mild cammed V8 when it does it). I just wanted to know if it was normal.
  26. Dec 22, 2020 at 1:19 PM
    ChillTree
    ChillTree New Member
    2019 Tundra Platinum
    TRD Pro Rims
    and here im about to install the exhuast this weekend...we'll see how it goes. i dont remember my '15 Pro bugging me tho.
  27. Dec 22, 2020 at 2:34 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Install it and drive the piss out of it, enjoy it. I enjoy mine.
    TelemarkTumalo likes this.
  28. Dec 22, 2020 at 6:10 PM
    TelemarkTumalo
    Mark
    Bend, OR
    My second 5.7 with the TRD dual exhaust. I love it.
  29. Dec 28, 2020 at 11:39 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Hello,
    Give Keith Carty of Dirty Deeds Industries a call. He can probably help you on this. 760-877-4234.
    Thanks, Shawna
  30. Mar 1, 2021 at 4:36 AM
    2021 work truck
    2021 work truck New Member
    22 Tundra Crewmax 6.5
    33" Tires, Black Toyota Rims, TRD shocks
    Hey how has the H-pipe been for you? Thinking of adding this myself. I don't want to loose too much rumble, just some drone and pulsing at those certain rpms. Would you recommend this mod? Would you do it again?
    Thanks
