TRD Pro exhaust resonator...
Discussion in 'Performance and Tuning' started by az1441, Feb 19, 2017.
  1. Feb 19, 2017 at 7:39 AM
    az1441
    az1441 [OP] 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    Anyone remove it?
    My current 2010 Tundra has dual super 44s with removed cats and it sounds so bomb...
    I want my Pro to sound similarly vulgar.. :)
  2. Feb 19, 2017 at 8:26 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I gotta ask........if you removed your cats, how do you pass smog?
  3. Feb 19, 2017 at 8:30 AM
    az1441
    Steeler Country
    I am exempt from emissions as I drive less than 5000
    040Tundra and NewImprovedRon like this.
  4. Feb 19, 2017 at 8:47 AM
    az1441
    Steeler Country
  5. Feb 22, 2017 at 8:07 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Just remove the rear cats. And give me a call. I'll buy em from ya. 760-877-4234
  6. Feb 22, 2017 at 8:11 AM
    az1441
    Steeler Country
    Done. I will do so
  7. Feb 25, 2017 at 6:53 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    You need to make pipes for that. We cut at a certain distance from your Drawing. You supply 2 slip fit pipes w/fittings with clamp on fitting that bolt to your BA pipes. We send you 2 cats you send us 2 pipes and cash. Win win.
  8. Feb 26, 2017 at 8:19 AM
    dirtydeeds
    Keith
    USA
    It's not quite that easy. But I can make an entire bolt on mid pipe.
    J4RR3N4 likes this.
  9. Feb 26, 2017 at 8:43 AM
    az1441
    Steeler Country
    Im pulling the cats off for sure. Deeds I'll hit you up if you want them. I'll post a video of the sound. If I don't like it I'm gutting it and putting dual super 44s in this. No cats.
  10. Feb 26, 2017 at 8:53 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Just for the rear cats wouldn't me that hard would it?
    az1441[OP] likes this.
  11. Feb 26, 2017 at 8:55 AM
    dirtydeeds
    Keith
    USA
    There's dual wall tubing in that area. It's easier to replace the whole pipe.
    040Tundra and az1441[OP] like this.
  12. Feb 26, 2017 at 10:51 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Kevin, how can we make a 2014-2017 run right with no cats? Wont they throw codes??
  13. Feb 26, 2017 at 10:59 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
  14. Feb 26, 2017 at 11:07 AM
    dirtydeeds
    Keith
    USA
    Removing rear cats won't throw any codes. Removing front cats would require simulators. Which could still throw codes. Best resolution is to run stock front cats.
