Trd pro 2” factory front lift
Discussion in 'Suspension' started by Tundramoney, Apr 4, 2018.
  1. May 21, 2021 at 2:08 AM
    Ad4mmd
    Ad4mmd New Member
    2012 Toyota Tundra TRD DC
    Camburg UCA Fox shocks TRD Front/Rear SwayBars TRD Air-box Intake Mod KN Air filters EBC Brakes TRD 3rd Gen wheels/tires JL Subwoofer 700watt PIONEER Nav HU Focal speakers 3way Dynomat Center Console Safe Led Interior Lights
    Hopefully not a dead thread. I was having this question to because I added Camburg UCA and fox coilover kit to level but still left a rake. Seemes like every dealership says well you lifted your truck so it will never be in spec and I am putting bad angles on the components. So I pointed out pros come leveled so how did Toyota over come this in alignments and components? Steering rack has just went seal leaking and inner tie rod has play and turning the axle produces rubber friction where its contacting itself. So After reading comments does toyota have another alignment for pros?
  2. May 21, 2021 at 5:41 PM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    You’re fine with your suspension with angles. Also with your Camburg UCA’s you will achieve better castor degree than the stock uca. Two places you should not put your trust or expertise with aftermarket suspension knowledge. That’s the dealer and 4WP.
