TRD OR Locker control.
Discussion in '3rd Gen Tundras (2022+)' started by BaldMenace, Apr 2, 2023.
  1. Apr 5, 2023 at 3:00 PM
    Coppertune
    Coppertune New Member
    Because most ppl rarely use 4L. It's so quick to just flip to 4H, and then hit the locker if a bit of extra traction is needed. Going to 4L requires you to stop, put it in N, then get going again.
    Silver17 likes this.
  2. Apr 5, 2023 at 3:03 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    On the first gen Tacomas this was called the grey wire mod. You just grounded a wire and you could control the e-locker at any time, not just in 4 LO. I mostly used it in 2 HI to rip around in the desert.
    I wonder if it's as simple as it used to be on Tacomas.
    Coppertune likes this.
  3. Apr 5, 2023 at 3:11 PM
    LS1Steve
    LS1Steve New Member
    Sand dunes baby!
    AZBoatHauler likes this.
  4. Apr 5, 2023 at 3:17 PM
    mass-hole
    mass-hole New Member
    I've used the one in my F150 in 2wd more than I ever did in 4hi or lo. Why?
    1. Because I can
    2. It makes drifting better
    3. I dont have to wait around for 4wd lo to engage
    4. It makes drifting better
    PERRY1060, Silver17 and AZBoatHauler like this.
  5. Apr 5, 2023 at 3:58 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Not allowing the locker to be engaged in any drive mode is some annoying nanny BS. Typical Toyota move, right up there with turning off the truck when opening the door after a remote start. Whoever thinks of these things could F up a wet dream.
    OnThaLake and Coppertune like this.
  6. Apr 5, 2023 at 8:00 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Personally, I'd wait for an aftermarket product. Probably the cheapest route as well. The Tacoma and Tundra setup appear to be identical in their general operation, and I do know the Tacoma uses pulse width modulation to activate the solenoid. This is where you might run into issues trying to actuate the factory locker with a hard wired setup. It very well may be possible, but I also suspect sending xx voltage to that solenoid could *potentially* cause some issues, i.e. overheating, considering its OEM operation. At first glance, the system seems pretty simple, but Toyota added a dose a complexity with how the solenoid is actuated, and how the locker status is read by the 4WD ECU. So I guess the real question is, why does Toyota use PWM to activate and hold the solenoid, and if not necessary, how robust is that solenoid and will it welcome a straight 12vdc without issue? IDK, but for the cost of a third member (assuming they can be swapped) I would go with Eaton or ARB unless I got one hell of a deal on the OEM setup.
    Page 22 (nothing for MY22+ as of now):
    https://www.eaton.com/content/dam/e...ormance-differential-application-guide-en.pdf
    OnThaLake likes this.
  7. Apr 5, 2023 at 9:03 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    You make a really good and wise suggestion. The locking carrier sub assembly is $479 which is surprisingly reasonable. That is assuming it is complete assembly and direct bolt in. I actually prefer a LSD so I should research those options also. Appreciate your input.
    SC4333[QUOTED] and Coppertune like this.
  8. Apr 6, 2023 at 7:02 PM
    SC4333
    SC4333 New Member
    Grant
    Wow, that is dirt cheap compared to what I assumed it would run. Interesting.. Once upon a time you could get an OEM mechanical LSD in the second gen Tacoma. Not sure if they did the same for the Tundra around that time or not. It was shorted lived and only lasted from 05 to 07 IIRC. I'm sure with traction control advances at the time, dropping the mechanical LSD was a no brainer to the Toyota bean counters.
  9. Apr 6, 2023 at 7:54 PM
    OpieTaylor
    OpieTaylor New Member
    I think they had to do that to keep from getting sued if a child or thief jumped in the vehicle after remote start, but the owner was too far away far to prevent.
    22whatwedo likes this.
  10. Apr 6, 2023 at 8:00 PM
    mass-hole
    Just make it turn off when the brake is pressed like every other car
    Retroboy1989, Rockgate and OnThaLake like this.
  11. Apr 6, 2023 at 8:29 PM
    OpieTaylor
    I don’t have remote start but I thought other models you have to insert the fob/key into the vehicle to operate it which would be an equivalent fail safe against unintended consequences, and a Toyota fob can stay in your pocket, but have to restart via push button after entry from remote start.
    Makes since if they could use the brake to kill the vehicle if the fob is not inside when the brake is pressed though. Must be a fob 1 and fob 2 issue, my wife’s car will allow you to lock a fob into the car if you are locking the doors from the other fob. It will not allow you to lock a door with door locks if only 1 fob is around because it knows your locking the only keys in the car.
    In that case you remote start, and a kid or thief jumps in a coincidentally the other fob is in there so the car does not shutdown when brake is pressed, and Toyota gets sued.
    Seems like factory remote start is only used to pre cool or heat the car and not intended to make operating the car easier or more efficient.
  12. Apr 6, 2023 at 9:17 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Lol
  13. Apr 7, 2023 at 3:43 PM
    Wintersun
    Wintersun New Member
    Auto LSD is nothing more than "spin control" with the brakes being applied to a wheel that is spinning much faster than another one. It is not anything at all like a limited slip differential. To get a locker on any truck you need to go to Ram or to Ford pickup.
  14. Apr 7, 2023 at 4:01 PM
    OnThaLake
    OnThaLake New Member
    It's a bit of a marketing fib to include the acronym "LSD" because D=differential. I'm pretty sure over the years I've seen this approach labeled ALS or ABLS. Those acronyms would be more accurate.
    Automatic Limited Slip
    Automatic Braking Limited Slip
  15. Apr 7, 2023 at 4:13 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Wonder if an actual aftermarket e-locker would somehow mess with the oem nanny
  16. Feb 26, 2025 at 6:32 AM
    ElevatedIntegrations
    ElevatedIntegrations New Member
    Kameron
    2024 Wind Chill Pearl TRD Limited
    None... Yet ‍
    Rockgate, BlackNBlu and Retroboy1989 like this.
  17. Feb 26, 2025 at 6:56 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Wow this is much more complicated than the older Toyotas. Interested to see how it goes. I remember the "grey wire mod" on the old Tacoma.
    Gone are the days where we could do the "fog light anytime mod" that required only bypassing a relay.
    I am also annoyed with Toyota for this one.... Make it available in 4hi, atleast.
    Any chance this is a Techstream setting?
  18. Feb 26, 2025 at 7:34 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    In for updates.
  19. Mar 15, 2025 at 5:51 AM
    #49
    osu1978
    osu1978 New Member
  20. Mar 15, 2025 at 6:44 AM
    #50
    Retroboy1989
    Northern Utah
    Seems pricey to unlock the use of hardware the truck already has from the factory.
    I'm curious if the factory diff lock light comes on with experimental designs logic box.
