Trd lowering leafs
Discussion in 'Suspension' started by Seanson, Jun 15, 2016.
  1. Jun 15, 2016 at 6:00 PM
    Seanson
    Seanson [OP] New Member
    2010 Tundra TRD Reg Cab Short Box
    Backslider likes this.
  2. Jun 16, 2016 at 12:31 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    This is the first ive heard of this^^^ i would make damn sure its meant for a 4wd truck. I have lowered a 4 wd tundra at work. Customer bought a kit that turned the rear to spring under using the same springs. It was kind of fun to install, because i always lift trucks... handled like a damn camry, it was cool.
  3. Jun 16, 2016 at 12:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The tundra leaf springs are practically flat as they are now. I am not sure how a new leaf spring would be flatter to lower unless its inverted.
    Like Jace said swapping to spring under would be the best way to lower.
  4. Jun 16, 2016 at 12:36 PM
    Seanson
  5. Jun 16, 2016 at 12:50 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah it looked similiar to that, no sure thats the exact one tho
  6. Jun 16, 2016 at 12:54 PM
    csuviper
    Broomfield, CO
    What about after flipping the axle, adding the Toytec shackles with 1"-1.5" lift to get back closer to level?
    Mountun Goat likes this.
  7. Jun 16, 2016 at 12:55 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    You get the adjustable shackles with the kit
  8. Jun 16, 2016 at 12:56 PM
    csuviper
    Broomfield, CO
    Oh, didnt know that.
  9. Jun 24, 2016 at 12:48 PM
    Seanson
    So I've been told removing a leaf will drop the end end to level it out. Anyone have an opinion on this ? I realize payload/towing will be effected, what will happen to handling ?
  10. Sep 26, 2019 at 9:32 AM
    Warreng
    Warreng New Member
    Digging up an old thread.
    Did you have any luck lowering just the rear?
    I would like to do the same.
  11. Sep 26, 2019 at 9:36 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I assume this means not 4x4
    Warreng likes this.
  12. Sep 26, 2019 at 9:42 AM
    Warreng
    Warreng New Member
    Damn.
    Still hope someone will reply who has leveled the rear of the truck in some way.
    I have read Removing overload spring will cause axle wrap. I would add airbags for hauling my sled but not sure that would help keep the axle from hopping.
    Mountun Goat[QUOTED] likes this.
  13. Sep 26, 2019 at 9:44 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Technically you could remove the overload spring and add traction bars to avoid axle wrap and hop.
    Warreng[QUOTED] likes this.
  14. Sep 26, 2019 at 9:45 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I used the complete kit from SOS Performance, along with a custom set of leaf spring from Alcan because my original leaf springs were toast. The results are better than expected, the truck rides and handles so much better and it sits level.
  15. Sep 26, 2019 at 9:47 AM
    Warreng
    Warreng New Member
    Anyway to do this without doing the SUA?
  16. Sep 26, 2019 at 9:49 AM
    Rex Kramer
    Georgia
    SUA?
  17. Sep 26, 2019 at 10:19 AM
    Warreng
    Warreng New Member
    Spring under axle.
    I dont really want to flip my axle...
  18. Sep 26, 2019 at 10:31 AM
    Rex Kramer
    Georgia
  19. Sep 26, 2019 at 10:35 AM
    Warreng
    Warreng New Member
    Rex Kramer[QUOTED] likes this.
  20. Sep 26, 2019 at 10:40 AM
    Rex Kramer
    Georgia
    I'm not sure about that URLs stability, you may want to print then read.
    Here is my '07 RWD, I lowered the rear the least amount possible and I left the front alone.
    I'm sure it will work perfectly well with a 4WD truck.
  21. Sep 26, 2019 at 10:42 AM
    Warreng
    Warreng New Member
    How did you get the “least amount of lowering possible”?
    If you increase the psi in the airbags will the rear lift up a bit?
    Sorry for all the questions
  22. Sep 26, 2019 at 11:20 AM
    Rex Kramer
    Georgia
    Attaching the leaf springs to the lowest hole on the shackle as pictured here gives you the least amount of drop, and yes the air bags will lift rear a bit as you inflate them.
    Edit: the higher up you go on the shackle, the lower it draws the rear end down.
    MyActualName likes this.
  23. Sep 26, 2019 at 12:03 PM
    Warreng
    Warreng New Member
    Awesome, thanks!
    Rex Kramer likes this.
  24. Sep 26, 2019 at 12:19 PM
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Did you have to shorten the exhaust too?
  25. Sep 26, 2019 at 12:31 PM
    Rex Kramer
    Georgia
    Yes, it's currently dumped in front of the axle.
    I recently picked up a new take-off tail pipe, and plan to install it when I install the Dirty Deeds cat-back Keith is making for me. I will have to shorten or bend this tail pipe, but it will reach beyond the rear axle either way.
    KTM Hauler[QUOTED] likes this.
  26. May 13, 2022 at 10:50 AM
    BIGRJ
    BIGRJ New Member
    RJ
    2011 TUNDRA CREW MAX 2WH
    TINT / AUDIO / MATS / MORE COMING...
    I have been looking at the SOS kit. It seems to be the most drop for the money. Will the TRD rear sway bar work on non TRD's models? Also, Has anyone tried the DJM kit that goes 3" in the front?
  27. May 13, 2022 at 11:17 AM
    Tundra1D6
    I had the DJM front kit and had issues with it. My oem 20” wheels made contact with the lower ball joint. It was promptly returned.
    Running the rear sway bar isn’t an issue with the sos bracket kit.
    Like others have mentioned I found the best combo to be bell tech springs if 2wd along with a TRD blue and red strut up front.
    Out back the sos flip with helper bags and sway bracket along with shorter yellow and blue bielstien shocks kept things tight. I went a step above and added caltracs to prevent axle wrap.
    If interested I have a complete kit available, everything needed. Interested pm me
  28. May 13, 2022 at 11:25 AM
    BIGRJ
    BIGRJ New Member
    RJ
    I would like more details on that .... I really want the maximum "static" drop w/out bags ..
  29. May 20, 2022 at 10:05 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Are you on the 1/3.75" drop or 2/4"? Got any more info on the Alcan leafs? I'll likely replace the factory leafs for beefier ones. Will be throwing a supercharger on next year!
