TRD Front Sway Bar 2020 LTD, non Off-road
Discussion in 'Suspension' started by Steve20LTD, Dec 31, 2020.
  1. Dec 31, 2020 at 10:21 AM
    Steve20LTD
    Steve20LTD [OP] New Member
    Went to purchase the front sway bar and the retailer and dealer said my VIN does not list a front sway bar as an option. I've purchased the rear and I've read that the front make the biggest improvement. Any thoughts why certain VINs will not work with the TRD front sway bar? Other ideas how to improve the handling? Dealer mentioned just replacing the End Links in the front.
    @Roman I hear you are the resident expert.
  2. Dec 31, 2020 at 10:46 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Dec 31, 2020 at 11:30 AM
    Steve20LTD
    What trim level do you have? Did it make a big difference? Do you also have the rear?
    Thanks for responding
  4. Dec 31, 2020 at 11:42 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My dealer was able to put one on my 2019 SR5, no issues or problems bringing it in.
    Try a different dealer I'd they don't want to sell you one
  5. Dec 31, 2020 at 11:57 AM
    maxdriver
    maxdriver New Member
    ‘23 GRolla, sans ‘19 Tundra
    I believe the rear sway provides the most improvement. Body roll should be noticeably reduced.
    Saltyhero13 likes this.
  6. Dec 31, 2020 at 12:01 PM
    Saltyhero13
    I'm in a 1794 with the Offroad package. I replaced the front sway bar with the TRD front sway bar I provided in the link. There is a slight thickness and weight difference between the two. As far as sway control, it is noticeable but not as noticeable as when I put the TRD rear sway bar in. The rear bar really dialed in the body roll.
    I still think the TRD front sway bar upgrade is worth it but you can always get the rear and upgrade the front later if you need it. I suspect you already have a front sway bar it's just not the TRD version; if so the upgrade won't be as dramatic off a difference as the rear installation.
    maxdriver likes this.
