TRD Exhaust - Ceramic Coating
Discussion in 'Performance and Tuning' started by 4Runner, Jun 2, 2018.
  1. Jun 2, 2018 at 6:01 PM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Installed the TRD exhaust and now I want to paint it black. Anyone done this? Can I just remove the exhaust and go straight pipe while the shop is working on it or will that cause issues? Thanks.
  2. Jun 2, 2018 at 6:07 PM
    4Runner
    Columbia, SC
    So no mechanical impact? I don’t want to do any damage. My other option is to purchase another TRD exhaust, just the tail pipe portions, have them coat it and then swap. Just hate to spend the $500.
  3. Jun 2, 2018 at 7:30 PM
    ZPMAN
    Minnesota
    I did see someone had blacked out there trd rear tail pipes, didn't look bad. Might be 1upper.
    1UPPER likes this.
  4. Jun 2, 2018 at 7:57 PM
    4Runner
    Columbia, SC
    Apparently the next version of the TRD PRO will be black. Trying to get out out first. Sounds like no issue going straight pipe for a week.
  5. Jun 21, 2018 at 8:37 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
  6. Jun 21, 2018 at 9:02 AM
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    That’s looks awesome. How much was the TRD tip? Was it a pain to spray paint or simple? Looking to do this as well to match my black out look
  7. Jun 21, 2018 at 12:05 PM
    havasuTRD
    Brett
    Ok cool. I’m gonn keep the stock exhaust but probably paint and get the TRD tip
    Watt maker likes this.
  8. Jun 21, 2018 at 2:39 PM
    ToyotaTundraMike
    2015 Tundra
    Won't have any problems at all. I left mine off for a few days after installing my BAMuffler. Gonna be loud though.
  9. Jun 21, 2018 at 3:01 PM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    If you leave the tailpipes off on a TRD exhaust the exhaust is directed up towards the bed of the truck and if ran like that prolonged could heat up your spare tire pretty good. Take a look where they join together and you will see what I mean. May not be an issue, but I wasn't willing to risk it on mine.
    I wouldn't be worried about it being louder, when I took my pipes off it actually got quieter...
  10. Jun 21, 2018 at 6:02 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    When you took your pipes off it got quieter???:crazy:
  11. Jun 21, 2018 at 6:28 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    I just got a used TRD exhaust set and noticed its all rusty looking on the pipes was thinking of painting it black. That sure looks good. What kind of paint did you use?
  12. Jun 21, 2018 at 6:36 PM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    I had also painted mine with high heat paint. No issues. Did it on 3 different sets.
  13. Jun 21, 2018 at 6:53 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Regular paint worked on mine. I don't think tail pipe gets hot enough to require high temp paint. If unsure just hit it with a IR thermometer.
    Pudge likes this.
  14. Jun 21, 2018 at 6:59 PM
    Krezz
    Kevin
    Can was like $15, meh lol. Now I can rev my truck in the drive way for an hour :rofl:
  15. Jun 21, 2018 at 7:04 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    They get pretty hot.
  16. Jun 21, 2018 at 7:05 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    Anyone know what the dual exhaust runs?
  17. Jun 21, 2018 at 7:11 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Here is a pic of when I painted my rear exhaust. I sanded the exhaust, clean it with alcohol, used a high temp primer and then used a high temp flat black paint. It was very easy to do and made a big difference on looks. 93A3563A-A6DF-4174-967B-AD8A12AF5FF2.jpg
    Tundra1078, atrinh15 and Watt maker like this.
  18. Jun 21, 2018 at 8:24 PM
    ZPMAN
    Minnesota
    One other thing to consider about not having exhaust out a tail pipe is the moisture and acid's from the exhaust will promote rust on the under carage, especially in colder climates.
  19. Jun 21, 2018 at 8:40 PM
    fullofbs
    fullofbs Project SnowFlake
    I painted mine. Like the look much better
  20. Jun 22, 2018 at 10:11 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    I was as surprised as you. Maybe it was the resonance or something but I threw on Dirty Deeds dumps and it was noticeably quieter. So much to the point I took the whole thing off and went with his 6" system and cut it at the axle. Give it a shot on yours just disconnect the tailpipes in the driveway and start her up, you'll see.
  21. Jun 22, 2018 at 3:08 PM
    ATXHusker
    ATXHusker New Member
    Chad
    Austin TX
    2016 TRD Pro CM Quicksand
    Ranch Hand brush guard, TRD rear sway bar, TRD air filter, Husky front mats, Weathertech rear mat, LED interior lights, tow mirrors, Salex console organizer, key ring light mod, AJT key fob, Gator bed cover
