TRD dual exhaust rust problem !!
Discussion in 'Performance and Tuning' started by hi_rawb, Apr 8, 2019.
  1. Apr 8, 2019 at 11:30 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I sanded down the pipes and painted the whole system with VHT satin clear coat. Looks great and it's clear. Curing the VHT on-vehicle was a simple process.
  2. Apr 8, 2019 at 12:18 PM
    13igtymer
    13igtymer New Member
    2016 toyota tundra crewmax limited
    Dumb question here. How do you cured it on the vehicle?
  3. Apr 8, 2019 at 12:19 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    click that link on my post. it should show it on there. under "items on vehicle"
  4. Apr 8, 2019 at 12:29 PM
    Dust
    Dust Wow, It's Big!
    Riverton, NJ
    14 Barcelona Red Metalic Limited CrewMax 4x4
    Borla and forget it! Have the #140332 setup 304 stainless polished muffler and tips $950. TRD is nice, but the Borla sounds sweet, not obnoxious with no drone. Rust like the pictured TRD setup is a non issue. Plus replacement parts are available and don’t forget million mile warranty! Just my .02
    Tundradrenalin and Faht Nocker like this.
  5. Apr 8, 2019 at 12:55 PM
    Tundradrenalin
    Virginia Beach, VA
    After it's fully dried, 24 hours.
    10 minutes idle.
    20 minutes off.
    20 minutes idle.
    20 minutes off.
    30 minutes normal driving.
    That's the directions VHT has on the can.
  6. Apr 8, 2019 at 1:00 PM
    Faht Nocker
    Woody
    Milky Way
    or get the engine enamel paint and call it a day. That paint can go to 500 degrees and mufflers get around 300-400 or so I believe.
  7. Apr 8, 2019 at 5:30 PM
    13igtymer
    Which brand would be the easiest to use? I'm thinking of using a clear coat just in case I mess up.
  8. Apr 8, 2019 at 6:08 PM
    Faht Nocker
    Woody
    Milky Way
    just spray and wait to dry... no curing. low gloss black on Amazon
    hi_rawb[OP] likes this.
  9. Apr 8, 2019 at 6:16 PM
    AZTundra
    Paul
    Phoenix, AZ
    I just purchased the TRD Exhaust since they had it 40% on the 4/4 sale. I'm going to be installing it next weekend. Since it's in new condition it sounds like I should prep it now BEFORE the rust sets in?...question is living in AZ we don't have the same road conditions and weather as others. Should I be okay installing as-is since I live in the desert or am I still prone to the rust down the road? What would you guys recommend?
  10. Apr 8, 2019 at 6:40 PM
    Rod67
    Rod67 New Member
    Rod
    2019 SR5
    Arizona shouldn't be an issue - but it is pretty easy to coat it anyway before installation.
  11. Apr 8, 2019 at 6:40 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Can’t hurt to paint, and will be much easier off the car. Plus the black pipes look cool. Either way, enjoy the exhaust.
  12. Apr 8, 2019 at 6:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. Looks like I'll be coating them before installing.
    Faht Nocker likes this.
  13. Apr 8, 2019 at 7:13 PM
    hi_rawb
    hi_rawb [OP] New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    I wish I would’ve known! I would’ve done the same.. so you kno what I’m doin this weekend ..
    Still debating what paint to use. Can I use the same paint to paint the exhaust tips ?
  14. Apr 8, 2019 at 8:29 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Yes, you can use the same paint. I painted my tips semi-gloss though.
    hi_rawb[QUOTED][OP] likes this.
  15. Apr 8, 2019 at 9:30 PM
    hi_rawb
    rob
    Bay Area
    2018 Trd Sport
    Looks good! Thanks man
  16. Apr 9, 2019 at 1:17 AM
    Duckslayr
    Duckslayr New Member
    671 Ltd Cement
    I got the black tip trd exhaust, and I painted the tailpipes and mufflers before install. Check out dirty deeds article on how to paint chrome tips.
    http://dirtydeedsindustries.com/articles/
    I didn’t have to do the tips but I used the same process. It looks clean and matches everything in the undercarriage. I used 4 coats krylon
    https://m.lowes.com/pd/Krylon-High-...ay-Paint-Actual-Net-Contents-12-oz/1000248383
    Just be aware that even after the baking process stated above the next time you drive your truck for longer than 30 minutes the paint will be smoking. After that burn in it shouldn’t smoke anymore.
    Max Power and Krewcial like this.
  17. Apr 9, 2019 at 4:09 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Like the info on this site!!! Ordered dual exhaust yesterday and looks like I will be painting in the near future.!:)
  18. Apr 11, 2019 at 7:28 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
  19. Apr 24, 2019 at 7:14 PM
    #49
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    Painted the exhaust system tonight using the same process. Planning to install it this weekend. Thanks for the post !
    What the!? and Duckslayr[QUOTED] like this.
  20. Apr 24, 2019 at 9:14 PM
    #50
    MMichaelJJ
    MMichaelJJ New Member
    14 Platinum CM
    How many coats / cans?
  21. Apr 24, 2019 at 9:22 PM
    #51
    Krewcial
    Don
    I used 3 cans with 4 coats.
  22. Apr 25, 2019 at 4:18 AM
    #52
    ToyotaTundraMike
    2015 Tundra
    VHT Header Paint. Did my pipes 2 years ago and still look good.
  23. Apr 25, 2019 at 4:19 AM
    #53
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    My TRD sway bar is rusted badly... I thought by us buying TRD products, they would be of a little better quality.
    Max Power likes this.
  24. May 6, 2019 at 3:13 AM
    #54
    MMichaelJJ
    14 Platinum CM
    This is what I used. Pretty good match to the OE black TRD tips. Three cans.
    Cesartt, Y0TA PR0, AZTundra and 2 others like this.
  25. May 7, 2019 at 1:10 AM
    #55
    MMichaelJJ
    14 Platinum CM
    I installed my TRD exhaust tonight. It’s frustrating that the tips aren’t level. I was aware it was a problem and even put in a cardboard spacer to try to get the spacing the same for the tips.
    I also replaced the rubber hanger on the passenger side. That didn’t work either. The driver’s side still sits up higher than the passenger side.
    Dumb.
