TRD dual exhaust - detailed installation
Discussion in 'Performance and Tuning' started by Netmonkey, Mar 18, 2017.
  1. Sep 13, 2017 at 4:24 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    awesome.... glad this was helpful.
  2. Sep 14, 2017 at 12:23 AM
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
    What did you try to even them out? Mine was dealer installed and the passenger side is over an inch lower, very noticeable. When I brought it up to them, they just said that's how it comes and showed me a couple of trucks on the lot that looked the same. I let it go then, but it still bugs me.
    RLHULK likes this.
  3. Sep 14, 2017 at 4:30 AM
    Netmonkey
    Georgetown, TX
    you can get a new rubber hanger for the passenger side. a new one wont be as stretched out and may bring it up a little bit.
    here is the part number:
    PTR03-34103
    http://www.trdusa.com/parts-detail....ries=Performance Engine&subcategories=Exhaust
  4. Sep 14, 2017 at 4:54 AM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Very nice write up!!! Congrats
  5. Sep 14, 2017 at 5:30 AM
    bigshug1
    bigshug1 New Member
    Curious - can you tell us what the part number is for this exhaust?
    I'm assuming it's PTR03-34160...but I want to be certain.
    THANKS!
  6. Sep 14, 2017 at 5:45 AM
    Netmonkey
    Georgetown, TX
    mjgonz1 likes this.
  7. Sep 14, 2017 at 5:58 AM
    bigshug1
    bigshug1 New Member
    Well dang...I was getting all excited about the pricing before I realized I needed two different part numbers
    I appreciate the info!
    NCinCO likes this.
  8. Sep 14, 2017 at 6:25 AM
    Netmonkey
    Georgetown, TX
    yeah, it aint cheap. there are less expensive options out there. you can search this site for exhaust vendors.
  9. Sep 14, 2017 at 7:57 AM
    BayRunner
    2017 Tundra Platinum
    The tailpipe and muffler are connected by flanges and 3 bolts (14mm) and when loosened, there is quite a bit of play and movement. Try loosening the bolts, pull down on the tailpipe at the flange (will raise the opposite end) and then tighten the bolts.
    RitcheyRch likes this.
  10. Sep 14, 2017 at 4:41 PM
    NcTundra4x4
    NcTundra4x4 New Member
    Wes
    Concord
    '17 Sr5 Crewmax Sunset Bronze
    Mini-lift.18" XDs. BFG KO2s 305/65/18. TRD Pro Grill.
    Put a hose clamp around the rubber hanger and tighten it up. It will compress the rubber slightly and make it a little less forgiving on bumps, but works. I did this on my 350z with the Nismo exhaust. Been that way for 9 years now with no problems and it's lowered and a bumpy ride. One side was about a 1/2" to 3/4" lower until I put the clamp on.
  11. Sep 14, 2017 at 4:44 PM
    SilverRider
    Las Vegas
    I need to give all of this a try. Thanks for the replies. It's been bugging me way to long.
    NewImprovedRon likes this.
  12. Sep 14, 2017 at 4:56 PM
    Netmonkey
    Georgetown, TX
    Great idea :)
  13. Sep 14, 2017 at 5:01 PM
    NcTundra4x4
    Wes
    Concord
    Let me know if it works. I've got the TRD pipes section sitting in the garage. Waiting to buy the muffler section. Imagine I may run into the same issue once I go to install it. Sounds to be like a common issue...
  14. Sep 14, 2017 at 6:16 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    I was actually getting ready to install mine now, but thought I would run to the car wash first to clear away all the dirt and mud clumps. Now it's too hot to touch. I wasn't thinking. :facepalm:
    Creatures 1982 and be77solo like this.
  15. Sep 14, 2017 at 7:03 PM
    Areith762
    Areith762 Go Avs!!!
    I am thinking I am going to hold off on the install and order a new hanger for the passenger side first. I can see already if I don't, there will be a problem getting both sides to match.20170914_195857.jpg
  16. Sep 14, 2017 at 7:23 PM
    NcTundra4x4
    Wes
    Concord
    ^^ Yeah that's probably a good call. Reusing the passenger side hanger obviously would be stretched out over time holding the stock exhaust. A new one "should" make them the same on both sides??
  17. Sep 15, 2017 at 11:30 AM
    Areith762
    Areith762 Go Avs!!!
  18. Sep 22, 2017 at 6:03 AM
    strosek7
    strosek7 New Member
    2016 Black Tundra SR5 DC
    @Netmonkey in the picture of the hardware and heat shield....There are part numbers to both those bags i cant read. I need a replacement set as getting a exhaust off craigslist and want to replace hardware and seeing if you could give me those #'s on the 2 bags?
  19. Sep 22, 2017 at 6:17 AM
    #49
    Netmonkey
    Georgetown, TX
    sorry, I don't have those numbers. I threw away those bags months ago.
    EDIT.... actually, I have the high res versions of those pictures. I bet I could enlarge them and get the numbers off the bags. I will check later today when I get home from work.
    EDIT (again).... one of those bags is the hanger kit:
    PTR03-34103
    http://www.trdusa.com/parts-detail....ries=Performance+Engine&subcategories=Exhaust
  20. Sep 22, 2017 at 8:53 AM
    #50
    six7zero
    six7zero New Member
    Pacific Northfresh 503
    15 SR5 Crewmax
    Call your local Toyota dealer and just buy the exhaust hardware kit from them rather than paying for shipping and waiting. I don't think you can buy the heat shield separate front the the exhaust kit. Just use your stock one and you'll be fine or make one yourself. The other bag are the bolts n nuts with the gaskets. I bought mine use too from CL and the gaskets where still in good condition.
    https://www.tundras.com/threads/trd-heat-shield-needed.12836/
  21. Sep 22, 2017 at 2:02 PM
    #51
    Netmonkey
    Georgetown, TX
    here we go:
    gasket kit: PTR03-34104
    hanger kit: PTR03-34103
  22. Sep 26, 2017 at 4:46 AM
    #52
    strosek7
    strosek7 New Member
    THANK YOU!
  23. Sep 30, 2017 at 10:21 PM
    #53
    Areith762
    Areith762 Go Avs!!!
    Finally, after sitting in my garage for a month and a half, I got mine installed. Pretty easy. And they sound AWESOME!
    Netmonkey[OP] likes this.
  24. Nov 14, 2017 at 3:43 PM
    #54
    fdrsqer
    fdrsqer New Member
    2017 Tundra, TRD 4x4
    Great write up. Thanks for the info.
  25. Dec 9, 2017 at 8:50 PM
    #55
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Thank you! I used this today and it was very helpful. Thanks for taking the time to post this up. The exhaust sounds awesome.
    NewImprovedRon and Netmonkey[OP] like this.
  26. Jan 7, 2018 at 11:12 AM
    #56
    SuaveRC
    SuaveRC New Member
    Awesome write up. Does anyone know what the increase HP and torque gains are after the install?
  27. Jan 7, 2018 at 11:49 AM
    #57
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    So wait, how do I install it again?
    Just kidding. Well done, buddy.
  28. Jan 7, 2018 at 12:10 PM
    #58
    Netmonkey
    Georgetown, TX
    the TRD site claims 5-10 HP/TQ increase. but who knows... it is impossible to tell without a dyno. but it sounds better than the stock pipes and that's why I did it.
  29. Jan 7, 2018 at 12:34 PM
    #59
    SuaveRC
    SuaveRC New Member
    Thanks. I wonder if there is one comparable but less expensive. I have so much I want to do that I need to watch my cost. Lol. Like replace head unit, replace chrome grill and etc.
  30. Jan 7, 2018 at 12:39 PM
    #60
    Netmonkey
    Georgetown, TX
    yes, there are much less expensive options. checkout @dirtydeeds on this site.
    MurderTundra likes this.
